Old 05-01-2015, 08:25 PM   #393
Wolvenhaven
Drives: 2013 BRZ 6MT
Originally Posted by phrosty View Post
Did you mean to post a ~13 second log?
No, it should have been almost an hour. Now that I look at it I'm wondering wtf happened because I hit save after I got done. Looks like I'm going to have to go re-log it. What values should I have selected so everything is there since I have to redo anyway?
Wolvenhaven is offline   Reply With Quote
Old 05-01-2015, 08:28 PM   #394
IBill4You
Drives: 2015 Subaru BRZ
Can someone please take a look at these ecytek data logs and give some feedback??
Any responses will be added to a comprehensive review of a certain etune vendor.
There is a long ass one with a check engine light at the end with full power loss. The smaller one is some driving with two pulls.
IBill4You is offline   Reply With Quote
Old 05-01-2015, 09:18 PM   #395
steve99
Drives: FT86
Is your car boosted ?? it help to know what mods you have :-)
What looks suspect is Knock Corrections up to -5 degrees in longer log and advance multiplier dropping to 0.35 indicating regular and quite large knock events
are you running correct octane fuel for your tune ?
read the DTC code for the cel light that does not show up in logs.
IBill4You (05-01-2015)
Old 05-01-2015, 09:32 PM   #396
IBill4You
Full 2.5' exhaust, Boosted with BOV and EBC Omni Map sensor CEL Code P0068 supposedly running tune for 10psi on 93. Just filled up with 93 from 1/4 tank of 93.
Symptoms = bogging under WOT,
RPM increase when clutch pedal depressed unless selector moved out of gear
bogging below 3k rpm
CEL code resulted in loss of acceleration until car shut off. Would start and run poorly. Then would not start then would start and run okay.
I'm thinking either faulty MAP or bad tuning? Do the fuel trims appear okay?
Old 05-01-2015, 09:47 PM   #397
steve99
Drives: FT86
It looks like Long term fuel trim is disabled in your tune as it zero all the time or amazing good maf scaling.
http://engine-codes.com/p0068.html
could be a heap of things
bad MAP sensor settings in tune if your running aftermarket MAP sensor
faulty maf or map
intake leak boost leak ect.
did you clamp off hoses under intake manifold one might have blown off under boost.
around 3000 rpm is where your getting the knock up yo -5 degrees correction will cause some hesitation as ecu pulls timing and this is with Advance multiplier at 0.3 (it should be one) so ecu has already removed quite a bit of timing.
The Stock 02 sensor scaling does not read AFR richer than about 11.25, so without a wideband you cannot tell the actual afr your running. Boosted cars will run richer than 11.25, but stock sensor will not measure that.
you need to talk to your tuner about those issues.
all that stuff could be rersult of faulty sensor or air/boost leak
Old 05-01-2015, 10:03 PM   #398
IBill4You
faulty maf or map
I really appreciate the help here. During test drive number 1 I blew off one of the pcv hoses under the intake manifold. I then clamped the 3 under the intake manifold and 1 other by the oil filter. The long file with CEL was test run #2, and the short file is test #3. I have double checked all clamps and connections for obvious leaks. I have requested the tuner check over the logs and will have a revision by Wednesday I believe. I am new to the boosted scene and panic easily lol sitting on the side of an expressway today wasn't that fun. Looks like I need gauges sooner than I thought.
Thank you again Steve99
Old 05-01-2015, 10:44 PM   #399
phrosty
IAM, FLKC, FBKC, LTFT, AFR, AFR Commanded, Load, RPM, Throttle.
phrosty is offline   Reply With Quote
Old 05-02-2015, 11:08 AM   #400
Wolvenhaven
I have no idea what I'm looking at here, so will you guys help me.
uncatted JDL UEL header
3" JDL overpipe and catted resonated front pipe
3" resonated Perrin catback
Perrin intake tube
K&N air filter
Logged after flash(OFT Stg 2 UEL v2.063 93 octane):
Start 125 miles, End 154 miles
http://www.datazap.me/u/wolvenhaven/...l?log=0&data=1
Ok, take two now that I actually paid attention to the recorder. Cold start, warmup, surface street driving with 1 hard pull.
http://www.datazap.me/u/wolvenhaven/...2?log=0&data=1
Old 05-02-2015, 12:49 PM   #401
phrosty
It looks safe to me.
I've never seen OFT Stage 2 have a solid 12.0 Commanded AFR through WOT. Perhaps someone will know what's going on there.
Old 05-09-2015, 06:26 AM   #402
DarkSunrise
DarkSunrise's Avatar
Anyone up and care to give some feedback on a data log?
http://www.datazap.me/u/darksunrise/...s?log=0&data=1
Looks like my LTFT's are generally -6.25% at idle, and +4ish % above 6k RPM at full throttle.
Mods are:
- OFT stage 2
- JDL UEL catless header + OP
- Berk catted FP
- Perrin 2.5" resonated CBE
I confirmed there are no exhaust leaks (all gaskets are spotless), other than the header flanges which I just re-tightened but haven't checked the gaskets on.
2022 BRZ Build
2013 FR-S Build
Old 05-09-2015, 08:18 AM   #403
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Mods are:
- OFT stage 2
- Berk catted FP
I'd personally be doing a rescale. It's certainly safe the way it is since the ECU compensates, but you're running rich enough to peg the O2 sensor at WOT. You'll get better performance and use less fuel by doing a rescale.
Thanks for the reminder, I need to check my header flanges too. I retorqued everything else and forgot those.
The Following User Says Thank You to DocWalt For This Useful Post:
DarkSunrise (05-09-2015)
Old 05-09-2015, 10:17 AM   #404
DarkSunrise
Cool I'll try rescaling the MAF this coming week. Hopefully not too difficult!
I went a bit overboard with the header flanges to be safe (sick of chasing exhaust leaks!) and torqued them down to 30 lbs-ft. You can get a torque wrench in there with an extension and 14mm crow foot.
2022 BRZ Build
2013 FR-S Build
Old 05-12-2015, 07:18 AM   #405
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
E85
Stg2 petrol MAF scale
MAF scale modified above 3V
Some primary open loop fueling removed above 7000
http://datazap.me/u/wayne/v49-11?log...zoom=1111-1242
Hoping it's not too rich up top
Old 05-12-2015, 08:56 PM   #406
joneze93tsi
Drives: 14 BRZED
E85+OFT+OFH+Dry Flow & Shivtastic Modified Snorkel.
3rd & Part of 4th gear pull.
http://www.datazap.me/u/joneze93tsi/...1-2-6-10-11-14
Interesting going from factory header to OFH in that you don't feel the need to rev it out as much around town, has much more grunt down low. It almost fools you into thinking that it doesn't pull as hard up top as you don't hear the angry VVTI changes anymore around 4k. Just very linear.
joneze93tsi is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
