| CANADA Canada |
#15 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
As for my shift points, it's both. On OEM rubber (that's all I ran for the last three years) when hitting my marks I found myself running out of revs. Now that I FINALLY upgraded my rubber it is happening regardless of how good/bad I'm driving. Also, this year I decided to have the shift light turning on at 7000rpm. Not that I'm watching it or even notice it. I'm trying to be a little nicer to my baby. The important bit we both forgot about during our meeting was that I probably should have taken you for a spin so you could see for yourself what the header sounds like in car on the street. Last edited by BatStig; 05-01-2015 at 04:16 PM. |
#16 | |
Drop in filter, catless frontpipe and Q300 http://s616.photobucket.com/user/thi...t.jpg.html?o=4
#17 |
Yeah, I thought about that on the way home... ah well, next time!
#18 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Haha, sleeper Hyundai with UEL's. Yes, local guy
[ame="https://www.youtube.com/watch?v=Xg9TeGodpug"]UEL Header Hyundai Elantra free-rev - YouTube[/ame] |
#19 | ||
Drives: '13 FR-S Argento
The emissions tests I've had done on my OBDII cars (model year 2000 and 2003) require more than just "no CEL" to pass. The ministry is also checking all the emissions monitors on the ECU. Will disabling the CEL also set the applicable emissions monitors to a "ready" state? My best guess would be that the emissions monitors will remain in a "not ready" state (emissions test fail) even though no CEL will be generated (because they were disabled). Too many emissions monitors in the "not ready" state will cause an emissions test fail. I'm not a technician nor do I work for any auto makers (read not currently), but I do understand a little bit about how ECUs use drive cycles to test for any malfunctions the car may be experiencing. With the monitored catalytic removed, the applicable drive cycles may never be able to determine a "ready" state. It will probably just stay "not ready" unless it can be hacked to say otherwise. I don't have my FR-S on the road yet, (will be a few more weeks before I do) but when it is I will be installing my catless EL header and running the corresponding OFT tune with the catalytic efficiency CELs disabled. I will then use an OBDII reader to check the emissions monitors (same ones the ministry checks) for "ready" and "not ready" conditions. If anyone is able to do this experiment now please do so, I will click thanks on your post hahaha. Otherwise I will report back in a couple of months. Last edited by DM7; 05-02-2015 at 02:47 AM. |
#20 |
Some say.....
@DM7 I have no idea, but I look forward to your results. I'm going to send my tuner an email to see what he has to say about this. I think I have a good OBD2 reader somewhere. Good time to do some digging.
| The Following User Says Thank You to BatStig For This Useful Post: | DM7 (05-02-2015) |
#21 |
The ready state of the overall system and ready state of an individual sensor aren't quite the same thing. The cat efficiency system needs both O2 sensors be present and ready, and the cat working, to be marked as ready.
The ready state of sensors and CEL's go hand in hand. You can have sensors not ready without a CEL (my wife's bone stock Camry failed on that), but you can't have a CEL without the sensors being ready. The ready state of a given sensor is determined by if the ECU has enough data in recent drive cycles to trust the sensor. If the car is only driven on really short drives and never fully warms up, the O2 sensors and MAF sensor won't be marked ready. Under the new test system, you'll fail because of that. You won't get a CEL until the ECU is ready to believe the sensors, so they require all sensors be in a ready state so you can't clear a CEL in the parking lot and go pass. Now if you all sensors reporting as ready and have no CEL you'll pass. I'm not sure what exactly the tune does when disabling a CEL, but it also disables the affected system from reporting as not ready. For the cat efficiency, my best guess is that it changes the threshold to some impossibly high value so that the ECU always thinks the cat is working, even if it isn't present. Since, to the best of my knowledge, the test doesn't actually monitor calculated values (like cat efficiency) as long as the ECU isn't reporting any issues you'll pass, and disabling the CEL's tricks the ECU into thinking everything is peachy. It doesn't turn off the light, it stops the ECU from even thinking there was a problem. You still need to meet the drive cycle requirements for the ECU to trust the sensors. You can also use an app (I think torque can do it?) to force ready states, but that's a short term solution to be done in the parking lot. Also kind of interesting, you can pass with a CEL as long as it's not related to any emissions systems.
#22 |
Mr.Fujitsubo
Drives: 2018 STI
Not too sound like a chicken.....more like an organic chicken...but I might just do an exhaust and tune even though the gains are not as much cause the headers seem really loud -___-
That Hyundai is insanely loud.....
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#23 |
Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
The loudness depends entirely on the set-up you pick. I've got a Perrin catteeed and resonated front pipe, Perrin OP, and Perrin Cat-back with a top speed EL header and it is far quieter than a bunch of guys i know with just cat-backs. I picked that set-up specifically for volume because I work stupidly early and don't want pissed of neighbours messing up my car lol
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
| The Following User Says Thank You to RedFR-s For This Useful Post: | Mr.Impreza (05-03-2015) |
| Emissions with aftermarket headers in DMV area | ap5512 | Mid-Atlantic | 11 | 12-30-2014 06:19 PM |
| Got a custom tune on the FRS. What happens if i add aftermarket headers after? | AceNiNe | Software Tuning | 9 | 03-13-2014 11:37 AM |
| Got a custom tune on the FRS. What happens if i add aftermarket headers after? | AceNiNe | Software Tuning | 5 | 03-02-2014 10:50 PM |
| WTB aftermarket Headers | Nitro_FRS | Engine, Exhaust, Bolt-Ons | 5 | 01-09-2014 02:07 AM |
| Is aftermarket UEL headers with a cat a bad idea? | IAmNotTheDriftKing | Engine, Exhaust, Transmission | 27 | 12-27-2013 06:14 PM |
