Old 04-29-2015, 11:51 PM   #1
pdhami
Drives: 2014 Argento FR-S
Jack and Jackstand height
What Jack and Jackstand height should I be looking for, not a specific jack I'm looking for there's a lot of posts on that already. I'm wondering what height is good for working under the car such as if I'm installing an exhaust or headers.
pdhami is offline   Reply With Quote
Old 04-30-2015, 12:23 AM   #2
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
This varies. I've used a jack and jack stand set bought from AutoZone with no problems. The height of them was just about 14". Cleared enough room for me and i'm a skinny guy.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
The Following User Says Thank You to x1UP For This Useful Post:
pdhami (04-30-2015)
Old 04-30-2015, 12:29 AM   #3
gramicci101
Off Topic
I have a Harbor Freight 68050. It has a lifting height of 23.5", which is plenty for nearly anything you want to do. HF has jack stands that also reach 23.5", so that works out very nicely.
The Following User Says Thank You to gramicci101 For This Useful Post:
pdhami (04-30-2015)
Old 04-30-2015, 01:16 AM   #4
pdhami
So anything from probably 15 to 24 would be fine I'm assuming
Old 04-30-2015, 01:35 AM   #5
ryoma
ryoma's Avatar
if I'm just changing the oil, I set my jack stand to the 2nd hole from the top (~12"). if I'm working under the car for stuff like exhaust or installing things, I set my jack stand to the 3rd or 4th hole from the top (~14"-16"), depending on how much clearance I need. as for jack, I bought a low clearance truck jack from Costco a few years back, for like $100. I just jack up my car from the front cross member or the rear diff. slides under my car easily at stock height with extra room to spare.
The Following User Says Thank You to ryoma For This Useful Post:
pdhami (04-30-2015)
Old 04-30-2015, 11:50 AM   #6
gramicci101
Off Topic
You also have to consider how long the jack is front to back, and if you'll have any usable range on the handle once the jack is shoved all the way under the car.
Here's a post I did on mine. My jack is pretty long, and I still don't have full range of motion when using the rear jack point.
pdhami (04-30-2015)
Old 04-30-2015, 03:24 PM   #7
pdhami
ugh who knew finding a jack that is decently priced would be so difficult
Old 04-30-2015, 03:33 PM   #8
ryoma
ryoma's Avatar
Keep an eye on slickdeals or set up an alert. They usually have deals on jacks and stands
Sent from my VS980 4G using Tapatalk
pdhami (05-01-2015)
Old 04-30-2015, 04:14 PM   #9
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
http://www.harborfreight.com/rapid-p...8053-7814.html
Dad has one and Girlfriend's Dad has one. Used both with no problems.
Frishkorn is offline   Reply With Quote
The Following User Says Thank You to Frishkorn For This Useful Post:
pdhami (05-01-2015)
Old 05-01-2015, 03:17 AM   #10
pdhami
Looks I might be making a trip down to Washington to pick up a Jack, the ones up here in Canada are pricey
The Following User Says Thank You to pdhami For This Useful Post:
Frishkorn (05-01-2015)
Old 05-01-2015, 11:52 AM   #11
That depends upon your age.
16-24 - run it up on a couple of 4x4s
25-35 - standard ramps
36-50 - standard jack stands
51- 65 - a hoist
65+ - a hoist at a shop ..... while you watch from the waiting room
The Following 4 Users Say Thank You to humfrz For This Useful Post:
kayoh (07-02-2015), Purdue FR-S (05-16-2015), PWBRZ (05-04-2015), Ultramaroon (05-02-2015)
Old 05-01-2015, 11:58 AM   #12
gramicci101
Off Topic
I couldn't find any ramps that would fit under the nose of the car without dropping a few hundred dollars on RaceRamps. And there's no way they can convince me that a simple chunk of plastic or rubber or whatever is worth that much.
Old 05-01-2015, 01:09 PM   #13
Ashikabi
Ashikabi's Avatar
It totally is worth it. Stock height the harbor freight 3 ton jack fits fine and has acceptable handle clearance. If you are low low like me you need low ramps or a low jack to lift the car to put the tall jack under it. It's a pain but it's the way it's gotta be
Old 05-01-2015, 06:13 PM   #14
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
If you can fit under the car and the jack stands are within their usable range, then use that height.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
pdhami (05-01-2015)
Which jack should I get? slyphen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 03-06-2015 09:40 PM
Pro-Kit right height at each wheel B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-30-2014 09:13 PM
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
BRZ/FR-S Trunk Height? ngabdala Scion FR-S / Toyota 86 GT86 General Forum 1 05-24-2012 02:41 PM
