Old 04-19-2015, 08:29 PM   #29
stevo585
Drives: White 2014 BRZ
do you guys use any tuning? Not that you have to on a wet kit... just curious.
stevo585 is offline   Reply With Quote
Old 04-19-2015, 08:32 PM   #30
stevo585
Originally Posted by savaged View Post
I also use nitrous, the Nitrous Express plate kit to be exact. I jet for 75 or 100 depending on the trouble I plan on being in. It's been bithing but a pleasurable experience. When done correctly, desirable gains and sure to turn heads.
Do you have any thing else supporting the basic kit?
Old 04-19-2015, 08:34 PM   #31
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Im surprised no F&F jokes have been made yet.
Old 04-19-2015, 08:52 PM   #32
stevo585
Lol I know a serious nitrous thread...who would have thought?
The Following 2 Users Say Thank You to stevo585 For This Useful Post:
cdrazic93 (04-19-2015), Ultramaroon (04-19-2015)
Old 04-20-2015, 08:36 AM   #33
savaged
Drives: 2013 FRS/86
The only supporting features I've included are Nitrous Express' Purge and Remote Bottle Opener. Next will be their Window Switch and Bottle Heater. As far as a tune, you're correct, not much HAS to go in to that at this level. I have a P3Cars gauge I use to keep an eye on AFR as well as throttle since I use the TPS. As soon as I've got the safety features in place, I'll get numbers on it.
savaged is offline   Reply With Quote
The Following 2 Users Say Thank You to savaged For This Useful Post:
brznoob (04-24-2015), stevo585 (04-20-2015)
Old 04-20-2015, 08:49 AM   #34
savaged
Drives: 2013 FRS/86
A look at what I've been working on.
The Following User Says Thank You to savaged For This Useful Post:
Old 04-20-2015, 08:32 PM   #35
stevo585
Cool keep us updated. Very curious on dynos and quarter mile times.
So how long have you run the kit?
Old 04-21-2015, 08:39 AM   #36
savaged
Drives: 2013 FRS/86
Almost a year now. I've run 4-5 bottle. I'm fairly conservative on daily use, but when I'm spraying I give it hell. It's a major power adder.
Old 04-24-2015, 07:01 AM   #37
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
Gasoline uses N35 F20 for a 50 shot when E85 uses N35 F22 for a 50 shot. I contacted NX to find the right setting for the kit given the fuel pressure.
I'm currently running 50 shot on E85. Aren't you afraid of detonation/knocking with a 75-100 shot with gasoline without a tune? I'm running the OFT Stage 2 E85 tune but I'm afraid of running higher than 50 because I know they advanced the timing a lot to get gains. Car made on a dynojet 225whp 208wtq.
[ame="https://www.youtube.com/watch?v=seyXCWTnJh0"]2014 BRZ 6MT Dyno - YouTube[/ame]
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
brznoob is offline   Reply With Quote
Old 04-24-2015, 07:21 AM   #38
brznoob
brznoob's Avatar
@savaged I just noticed we have the same hood lol. I thought also on getting the dual bracket but didn't want to take so much space in my trunk.
Old 04-24-2015, 04:48 PM   #39
stevo585
Numbers seem low to me, no? I'd think you'd be at 190-200whp without the nitrous. Did you ever get a baseline run?
Old 04-28-2015, 02:53 PM   #40
brznoob
brznoob's Avatar
this dynojet reads as low as a mustang dyno. Stock BRZ/FRS makes 150ish. Stage 2 OFT BRZ/FRS on E85 makes 180ish, hence making 225 on a 50 shot sounds about right. Torque numbers look like 130ish, 160ish, hence 208 sounds about right. In other dynos might read 250whp 220 wtq aprox.
Old 04-29-2015, 11:21 AM   #41
stevo585
Still haven't hooked up the tach signal. It's been a pain. Well regarding the 50 shot is not really a 50 shot for me as I'm running E85 is more like a 35 shot. Though I'm not running lean I want to get the right jets to produce a 50 shot
Word that does explain it, thanks. Are you happy with the kit, any signs of knock? How long you been running it? Interested in the same setup as I have the OFT/e85 just have the usual fear of nitrous like everyone.
On a side note I think NX makes e85 specific universal jet kits.
Old 05-02-2015, 05:19 AM   #42
brznoob
brznoob's Avatar
Yes, NX makes E85 specific jets. I'm happy with the kit but the ultimate goal is to make it work with a supercharger. Then I'll run only a 35 shot on E85 probably using a progressive controller to avoid that sudden boost. I'm running E85 so no knocking whatsoever. I ran tests running the kit, no knocking, again I'm only running a 50 shot. I have been running it for 4 months, went through 5 bottles so far.
The Following User Says Thank You to brznoob For This Useful Post:
mrk1 (05-02-2015)
Any nitrous apps yet? 86pro Forced Induction 20 02-07-2014 12:00 PM
Nitrous System for FR-S/BRZ Titanmotorsports Engine, Exhaust, Bolt-Ons 18 04-26-2013 07:30 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 11:02 PM
nitrous eindio Forced Induction 17 09-22-2012 02:09 AM
Supercharged HKS car on nitrous? Lawnik Forced Induction 3 09-04-2012 12:47 AM
