#225 |
My window moldings were twisted too so they were replaced under warranty last week. The material that the new ones are made of is quite a bit more slick than the originals. What a difference in the wind noise at highway speeds! The time spent in the dealership waiting room was the best time I've invested in the car this month.
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (03-10-2015) |
#226 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I'm starting to notice this on the driver's side with my 2013.
Is it possible to get both sides replaced with the revised part when it only happens on one side? Here's a video of my issue: [ame]http://youtu.be/S8PE0Ij9cVc[/ame] Pictures: Last edited by dhuang; 03-09-2015 at 03:31 AM. Reason: Added pictures |
#228 |
Drives: BRZ CSB Limited
If the molding is starting to dry/squeak and you are out of basic warranty i found that Meguiars natural shine protectant and/or Armor All work really well to treat and condition the molding. I put it on/into the molding pretty generously it fixed the squeak for me. I want to say it got rid of some of the excess wind noise also.
Stuff is really great on the plastic part of the rear bumper/diffuser. |
#229 |
Drives: Subaru BRZ, Chevrolet Camaro
Drivers side window seal/door seal
guy, i need to replace my drivers door window seal, its torn at the top corner at the sharp pillar conner. Where can i get a replacement part - Dealers? RPM ? Im in cape town
#230 | |
Drives: '13 Ultramarine
If you are referring to the seal that is actually on the little 1/4 window at the front of the door, that is a separate issue which has its own thread(s). That seal can not be replaced on its own...it is part of the 1/4 window assembly. I have had mine replaced twice now under warranty. It is not removable from the glass.
#231 |
Drives: brz
Had the same exact issue as @dhuang , I brought it to a local dealership and they replaced the entire weatherstrip under warranty.
| The Following User Says Thank You to Richyjc For This Useful Post: | dhuang (03-16-2015) |
#232 |
IG: will__is__nguyen
Drives: 2013 Asphalt FRS
my drivers side door has this issue -_- taking it in on tuesday for them to look at and order parts
#233 |
they said if its not leaking they aren't fixing it -_-
#234 |
I don't lie.
Drives: AE86 Successor
Keep harassing them they fixed mine after trying 2 dealerships
I'll get a Mustang for way less if I wanted more power.
#235 |
Drives: 2013 Subaru BRZ
I applied autogylm trim gel on mines. No friction, no rubbing and squeaking anymore.
#236 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
In all seriousness, I've applied the 303 Aerospace Protectant and it works like a charm as well.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#237 |
Computer Scientist
Drives: 2014 BRZ Limited
My window seal is started having this problem on the passenger side around 8000 miles, which is strange because obviously my driver door is used more often.
I tried lubing the seal with EasyLube+Wax bike chain oil. That made the problem worse. I took off the lube with warm soapy water, and now I'm back to square one. The problem is obviously that the rubber on the seal has been worn and has too much grip. If you run your fingers along the seal, you will feel that it's nice and slick until you reach the problem area, which is very tacky feeling. My dealer is really cool so I'm confident they will replace the seal for me. Windows are not tinted.
Keep calm and drive safe
#238 | |
| The Following User Says Thank You to sstfnv For This Useful Post: | housecat (04-16-2015) |
| Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 128 | 02-27-2019 07:25 PM |
| Side by side cosmetic differences between BRZ and FRS/86 (same dimension lights) | Moto-P | BRZ Photos, Videos, Wallpapers, Gallery Forum | 109 | 08-19-2014 10:56 PM |
| Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 01:30 AM |
| Studying for Learner's Permit driver's knowledge test | PACMAN | Other Vehicles & General Automotive Discussions | 2 | 01-02-2012 11:17 PM |
| Little request: FR-S vs GT86 vs BRZ side by side photos! | EJ20 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 12-02-2011 12:53 AM |
