#295 |
Drives: '22 BRZ
Well, unfortunately changing the primary open loop table just meant the AFR error was even higher since the commanded AFR changed but the actual AFR was the same.
Any tips? I'm sure I'm doing something wrong, heh. edit: See this log from ~30 minutes ago: http://datazap.me/u/docwalt/04-09-15...mark=3530-3583 and this log from a few days ago: http://datazap.me/u/docwalt/04-06-15...mark=6761-6865 The commanded AFR changed, but the actual AFR was essentially the same shape and AFR error Last edited by DocWalt; 04-09-2015 at 09:15 PM. |
#296 | |
Drives: UK GT86
.: Stealth 86 :.
#297 | |
Drives: '22 BRZ
CL maf scaling is a piece of cake, and OL would be fine except for the weird rich dip I get when WOT. |
#298 |
Drives: UK GT86
Well the generic way is to get MAF Scale = Commanded AFR. If you don't want that you can just adjust the fuel map to get the AFRs you want, or even the MAF scale to the same end. I'm surprised you're even in CL that high MAFv range. TBH I'd rather the OL range was better scaled than CL in the cross over regions due to the potential issues on tip in as you come out of CL operation. I actually use a combination of OL and CL in one go to do my MAF as it seems to be more reliable.
Which ROM are you on? Is the open loop fueling additive defined? You could always use that to make it leaner.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | DocWalt (04-10-2015) |
#299 | |
Drives: '22 BRZ
I'm working from OFT Stage 2 UEL 91 Octane v2.063. I remember seeing the open loop fueling additive, I think. I'm not at home so I'll have to try that tonight. Thanks for the help so far! |
#300 | |
Drives: UK GT86
I do mine manually rather than the tool these days, find it more reliable and will take into account everything if you can sort the data.
.: Stealth 86 :.
#301 | |
Drives: '22 BRZ
FWIW I manually smoothed out that region of the MAF scale so there wasn't a massive dip and that resulted in the above behavior. Note the same AFR dip existed before scaling and after. edit: Oh, and is the OL fuel additive simply an AFR adder? I assume so, but wanted to double check. The description in romraider isn't defined, but the units are defined as "Lambda Additive" Last edited by DocWalt; 04-10-2015 at 07:03 PM. |
#302 |
Drives: '22 BRZ
This is how my MAF scaling ends up compared to the stock OFT Stage 2 scaling if I remove the 3v min/max limits. Kinda lumpy, to say the least. I did the math and it should fix my WOT issues, but I'll end up with tip-in knock again, I think.
#303 |
Drives: UK GT86
If you look at a graph of a WOT pull on Datazap what are the MAFv you have at 2-2.5k. That will be the cross over region, it's usually ~2.5v which is why I think the MAF scale changes it's spacing. If you want to use the tool I would:
1) Paste the original MAF scale into both open and closed loop screens and into excel (call this A) 2) Set no upper or lower voltage range 3) Run the tool for both open and closed loop and then paste both into excel (B and C) 4) Remove data from both new scales that is the same as the original, using the formula =if(A=B,"",B) may make that quick and easy (let's call these new rows D and E) 5) Average the 2 scales that only have the changed data using =average(D,E) When I get my laptop i'll show a bit better what I do. Yes, the fuel additive appears to be AFR points, -0.1 is richer, 0.1 is leaner. But remember it is a % of where you are. If your fueling is way off the MAF then 0.1 won't necessarily make it 0.1 AFR points leaner, it may be more or less. Again I have a spreadsheet I was trialling. I'll post it up.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | DocWalt (04-11-2015) |
#304 |
Drives: FT86
Their is a table for tip in enrichment, maybe adjust that for the tip in knock or take a bit of timing out of the base timing B table in that area or add a bit of fuel in the Open loop fuel table.
| The Following User Says Thank You to steve99 For This Useful Post: | DocWalt (04-11-2015) |
#305 |
Drives: '22 BRZ
Kodename, I get what you're saying. I can do that, which will smooth out the dip at 2.5v-3.0v. I only had a couple of samples of CL past 3v anyway (and not sure how I managed that anyway)
Steve, I think pulling a touch of timing and/or adding a touch of fuel is a good idea. I can get 93 octane, but it's a bit out of the way so I tend to run 91/92. Every time I've tried 94 locally my IAM drops so Sunoco's tanks of 94 must be pretty old. |
#306 |
Drives: '22 BRZ
So after going through that work suggested by Kodename and Steve I got a couple of nice WOT logs. Some minor knock correction, but no IAM drops and I'm still on mediocre 91 octane gas.
http://datazap.me/u/docwalt/04-11-15...zoom=1249-1338 http://datazap.me/u/docwalt/04-11-15...zoom=2370-2504 The MAF changes I came up with based on those logs gives me a curve like this: ![]() I guess I'll still have the little bit of a rich spot with the slightly lean spike. Unsure what's going on there, but based on my virtual dyno results from earlier it's not causing a loss of power. Thank you for the help guys! |
#307 |
Drives: UK GT86
If you have used the log stats screen on the tool before, you may be able to workout how to use this:
Open Loop Additive Tool For best results: Set the cell range to ~20% on the define axis screen and paste in your OL Additive table as the axes. Filter dV/dt to 0.3 or less, you'll need to add a column for dV/dt to your logs. The formula can be found here. Filter Fuel System Staus = 2 (Open Loop Only) Filter error <17.5% which will remove anywhere where you're off throttle and AFR is showing ~20:1 You'll need to creata a column called Error % into the log too, which is where you'll get the data. The formula is also in my spreadsheet
.: Stealth 86 :.
#308 | |
Drives: '22 BRZ
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 09:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 06:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
