Old 04-07-2015, 09:24 PM   #1
Zzzquil
Zzzquil's Avatar
What are the most reliable LCA's and Toe Arms
I'm looking to drop 1.5" to 2" on KW v3 Coilovers. Based on the research I have done on the past few days, if I really wanted to dial in my camber/toe angle I'm going to need aftermarket LCA's and toe arms. I mainly concern with the rear suspension adjustments as it seems like the front will be just fine with some bushings/bolt upgrades (correct me if I'm wrong).
I have noticed a lot of threads for LCA's and Toe arms are well over a year old, and would like to see if the LCA's/toe that were introduced to the market held up (no creeps, failures, etc).
Not looking to track the car, but it would be nice to have the option if I were to change my mind. I'm also a fairly spirited driver.
I mainly interested in the following LCA's:
-Voodoo
-SPL
-Whiteline
-GTSpec
-ISC
-RS-R (recently introduced)
As for toe arms options I'm thinking whiteline will do the just fine ( I'm open to other suggestions).
Any advice will be greatly appreciated!
Zzzquil is offline   Reply With Quote
Old 04-08-2015, 02:12 AM   #2
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
There is no issues with the factory units. Bushings may dry out and tear. I consider that a consumable. When you start to have trouble with that the rest of the car will have bigger issues. eg. rust
Its all just bling. There are some stiffer units that can increase feel. They tend to be heavier and overbuilt.
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 04-08-2015, 02:41 AM   #3
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Except that OP is looking for adjustability.
@Zzzquil I have SPL and they are dynamite. People are beating the hell out of them on the track and I have yet to hear of anyone having issues.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
tooslow4umayne (08-07-2016)
Old 04-08-2015, 03:13 AM   #4
PowderfaceTr.
Drives: stock
Just ream the holes oval. That gives you all the play you need.
Old 04-08-2015, 03:15 AM   #5
Vroomin86
Drives: 2015 Fire
Never thought of that but I wonder if that would affect OEM integrity as they weren't built with that engineering in mind...
Vroomin86 is offline   Reply With Quote
Old 04-08-2015, 04:26 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Right. No chance of slippage there.
Its all just bling.
What do you mean by this? Unless you call camber adjustment bling.
Old 04-08-2015, 04:48 AM   #7
Captain Snooze
Drives: Red Herring
-Voodoo
-SPL
-Whiteline
-GTSpec
-ISC
I think Whiteline may have discontinued their rear lca. RacerXFabrication also do rear lca as well.
Velox are going to a lot of trouble to stress test their not-as-yet released arms http://www.ft86club.com/forums/showthread.php?t=82474 . Their testing is just crazy thorough.
Voodoo arms are kinked so that the car is dropped 18mm by installing them.
CSGMike swears by SPL.
Of the brands listed I don't think there is sufficient sales or reporting to state whether a particular brand has reliability issues.
Old 04-08-2015, 04:48 PM   #8
Zzzquil
Zzzquil's Avatar
@BatStig I think I will be going with SPL for LCA's. I have only heard good things about them aswell. What aftermarket toe arms are you running (if any)?
@Captain Snooze - Are you running any LCA's?
Old 04-08-2015, 06:26 PM   #9
Captain Snooze
Drives: Red Herring
I have first release RacerXFabrication lca but they no longer make them in that style. They have changed from welded plate
to machined aluminium.
Another consideration is whether you want urethane bushes or spherical ends.
Old 04-08-2015, 09:11 PM   #10
BatStig
Some say.....
BatStig's Avatar
toe arms are you running (if any)??
No toe arms at this point. I'm still running the OE springs and struts.
Old 04-09-2015, 08:36 AM   #11
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Honestly we run the SPC arms on all our track cars and have installed close to 50 sets on customer cars here in the NY/NJ area. We are notorious for terrible pot holes and on track we run very sticky race tires. Not a single set has slipped or changed alignment specs between alignments.
These arms are also the ones speced for The Spec86 Cup race cars as well as the SCCA T-4 class of racing.
-mike
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
endless_pain (04-21-2015), tooslow4umayne (08-07-2016)
Old 04-09-2015, 08:53 AM   #12
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Ratsy parts are supposed to be super durable (plus it's JDM as f*ck and all that). http://www.rasty.tv/86brz/parts.html
At least they look the part.
Guillaume is offline   Reply With Quote
The Following User Says Thank You to Guillaume For This Useful Post:
ck-GT86 (04-09-2015)
Old 04-09-2015, 03:31 PM   #13
fika84
fika84's Avatar
I also run the SPC arms with no issues! +1 for inexpensive and fully functional! Stock toe arms currently with ~1.5" drop on ST Suspension coilovers.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 04-09-2015, 03:34 PM   #14
vroom4
We abouse the crap out of Spc, no problems or slippage
vroom4 is offline   Reply With Quote
Cusco LCA, Toe Arms, Trailing Arms xDBOYx Brakes, Suspension, Chassis 10 05-23-2015 07:11 PM
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 12:53 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 04:20 PM
Most reliable F/I kit? official_george Forced Induction 103 05-14-2013 01:00 PM
Reliable LED kit companies? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-27-2012 11:38 PM
