#687 |
You realize you can set the shift light to whatever RPM you want, right? It doesn't have anything to do with the engine's power output.
#688 |
Drives: Neptune GR86
There's no way the governor wasn't functioning either...
#689 |
Drives: Red
#690 |
Drives: Subaru BRZ Limited
Did the TRD intake need to do the maf-scaling?
Thanks. |
#692 | |
Is that good enough to correct those turbulence or I need customize tuning? Thanks again. |
#693 | |
Drives: Fast
Right here: http://www.ft86club.com/forums/showthread.php?t=64790 |
| The Following User Says Thank You to 2016 Camaro SS For This Useful Post: | cslntuee (04-06-2015) |
#695 |
The SquadWhisperer
I have seen it noted that it was really close to stock maf calibration and I have seen another say it was a ways off. Mine is in the "close enough" ballpark, but I'm going to rescale regardless. I'm running Stg 2 UEL with the OFH.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
| The Following User Says Thank You to Thorpedo For This Useful Post: | cslntuee (04-06-2015) |
#696 | |
I cannot find the post. Thanks. |
#697 |
The SquadWhisperer
Link in 2016 Camaro SS's post.
| The Following User Says Thank You to Thorpedo For This Useful Post: | cslntuee (04-07-2015) |
#698 |
Drives: '15 BRZ RA
I don't think you need any MAF rescaling. The ECU when it is in closed-loop mode, it takes additional measurements from the O2 sensor and adjusts the AFRs. These measurements are much more exact than the MAF measurements. This is because ECU expects to be able to deal with overly dirty fuel filters and reduced fuel flow issues. Then it also uses these corrections in the MAF readings in open-loop mode. In a sense, the ECU will somehow re-calibrate the MAF readings itself. It might not be perfect, but it will do the job. I would expect issues in the AFR, only if the MAF sensor needs a big re-calibration.
#699 | |
Drives: FT86
Have a look at your LTFT Long term fuel trims if they are over about 7% then maybe worth maf scaling. If you on OFT Stage 1 tune then Commanded AFR and AFR (measured by 02 sensor) should follow each other fairly closely under load, on overun injectors turn off . If both of those ok then maf scaling is ok . like this http://datazap.me/u/steve99/e85-maf-...zoom=5580-7148 have a read of maf scaling links below. http://www.ft86club.com/forums/showthread.php?t=64790 Last edited by steve99; 05-26-2015 at 05:45 AM. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Chimera (07-01-2015), mgarcia707 (04-04-2019) |
#700 |
Drives: 92 Prelude
Any before and after dynos with stage 1 OFT? The biggest thing I like about this intake is the angle of the filter pointing air towards the "Inlet tube" while stock points air straight into a wall. Also that there is no curve for air to go through, logically I would think this intake is better designed then most I see out there but I'm probably wrong lol
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
