Old 04-05-2015, 09:36 PM   #1
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Oil cooler consensus?
While lurking, I learned that most of you like your oil coolers.
I also learned that there are many types. Air to oil, water to oil...
The two that stand out most to me are Cusco, and Perrin.
Cusco warms the oil up quicker. Though, I don't see many results of it.
And the perrin has a thermostat. But the oil won't warm up any quicker than without a cusco.
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 04-05-2015, 09:56 PM   #2
steve99
Drives: FT86
For an NA car aggressive street and mild track driving in warm to hot climates the coolant/oil type are ok.
If your boosted or for even aggressive track driving long stints NA in warm to hot climates then the air\oil separate radiator type is needed the OEM coolant heat exchanger types dont have enough capacity.
See bolt on mods link below for more info
Old 04-05-2015, 10:03 PM   #3
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I have Maximalperfomance oil cooler and it works great for the track.
It's efectively the same as the perrin oil cooler kit but more affordable.
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
DocWalt (04-05-2015)
Old 04-05-2015, 10:39 PM   #4
vroom4
Thanks for the kind words, we are trying to help out our fellow enthusiasts with our affordable kit!
vroom4 is offline   Reply With Quote
Old 04-05-2015, 10:45 PM   #5
HUNTERANGEL121
Thanks for the awesome link.
Is it the stock radiator that's limited if one were to go with Cusco's oil cooler?
F20/F22C both have heat exchangers like Cusco. Oil temps aren't really a concern on them.
Old 04-05-2015, 10:52 PM   #6
steve99
Drives: FT86
the stock radiator is fine if NA, but with prolonged hard driving oil temps climb. even with the heat exchanger oil coolers the coolant does not rise but the oil temps still will with sustained hard driving.
The coolant/oil heat exchanger coolers will buy you about 10-15 minutes of sustained hard driving on a hot day.
The air/oil radiator types correctly sized should keep oil temps under control indefinitely.
monitor your oil temps if their getting over 230F to 240F then you should be looking at oil cooler especially if running the stock 0W20 oil, 10W30 give you a bit more security in hot climates or if boosted.
see the video in previoys link.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
HUNTERANGEL121 (04-06-2015), Koa (04-05-2015)
general consensus on best economical winter tire? jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-08-2014 07:05 PM
Consensus on Removing all Emblems Prior to XPEL Ultimate Chad86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 33 06-24-2014 08:26 AM
Any consensus on best manual transmission fluid choice? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-01-2014 06:14 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Consensus on TRD exhaust offering for FRS?... OICU812 Engine, Exhaust, Transmission 19 06-19-2013 07:53 AM
