#57 |
Drives: TBD
^ Yes, but if I go auto I will drive it like a clutchless manual. Problem solved, for the most part.
#58 | |
Stig 2nd Class
Drives: Ultramarine FR-S
#59 |
Drives: TBD
^ Tried trail braking with a downshift just before the apex in an auto on my test drive - I was near the cornering limit and it did not upset the rear end. This was likely because of the perfectly rev-matched downshift. It wasn't the VSC that kept the rear settled because I could jab the throttle and swing the rear out several inches in a tight corner even with all the nannies on.
If you don't trail brake to the fullest extent your car can do it, your times won't be optimal. Maximum trail braking sometimes puts you in a position where you can't downshift enough prior to corner entry, as you lose enough additional speed trail braking that you need to go down another gear while cornering for maximum post-apex acceleration (a common occurrence in decreasing-radius corners). Last edited by Sport-Tech; 05-21-2012 at 11:12 AM. |
#60 | |
Drives: Scion FR-S
First of all, nobody said anything was wrong with an Auto. So just because Audi wins Le Mans with them, it has nothing to do with what I previously said. You're just trying to be an ass here. Same with the next statement. When it comes to a DSG transmission, in my opinion its not a true manual. No clutch means its not really "manual control". It just means you get to pick which gear your in without having to worry about the drive line. Again, this has nothing to do with someone saying "using your left foot makes the car more sport like". You're grasping at straws for an argument. I'm not even going to start commenting on the "you people" argument.
#61 | |
Drives: 2013 Scion FRS Whiteout
I want to try and learn on pc before I try the real thing in my FRS. |
#62 | |
Drives: TBD
Whatever wheel you use should have a gated manual shifter and stiff pedals (including a clutch of course) for best realism. G27 is a good choice. |
#63 | |
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
#64 | ||
Drives: BRZ!
#65 | ||
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
The only time I wouldn't do it is if I was in a car with a loud exhaust, or if it burned oil on deceleration or similar. That would be obnoxious. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
| The Following 3 Users Say Thank You to Jeff Lange For This Useful Post: |
#66 |
Drives: TBD
Clearly the more shifting you do the more you are wearing the clutch and the synchros, especially if you don't rev match perfectly (which is very hard to do). And the nominal increase in brake wear you incur by shifting from 4 directly to neutral (because you are not utilizing the full value of engine braking) is inconsequential. Anyway, brake pads are a lot cheaper to replace than a clutch or other tranny components! Going 4-3-2-1 every time you stop - that may be fine if you live in rural Nevada with 20 miles between stop signs but in a city? A lot of effort for next to nothing. Nobody I know does it. The gas saving will be very minor and not worth the aggro unless you are hypermiling. And in a city the additional noise is not appreciated (at night especially) - some residential areas even have "no engine braking" signs up on downhill slopes.
#67 |
You don't shift into 1st when slowing down in most cars, the ratio is too short and it puts a lot of wear on the synchros, however "no engine braking" signs are for diesel trucks that have engine retarder brakes. They are not meant to, nor do they, apply to passenger vehicles.
Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged Last edited by Jeff Lange; 05-21-2012 at 11:01 PM. |
#68 | |
Klaatu barada nikto
Drives: Raven FR-S MT
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
#69 |
Just a quick follow up to the comments that had been happening before, and that is to say that there are no hard and fast rules on when to downshift and when to coast, what is right for one situation may not be right for all situations. There are times when I don't downshift to 2nd, just stopping at 3rd, and I'm not always going from 6-5-4-3-2 either, that's just a lot of wasted shifts. Skipping gears is common practice even when downshifting, and is typically taught by professional driving schools (this again isn't always the best, look at the S2000 thread linked to earlier).
If you are in 6th, downshifting from there to 3rd while braking/rev-matching and then slowing down to about 1500-2000rpm before clutching in is often probably appropriate, or similar. I'm just saying, being in gear is almost always more appropriate than not being in gear, and being in a gear that can give you a somewhat usable powerband to get out of dangerous situations instead of hitting the gas in neutral is preferable. Everyone's driving style is different, and you will develop what works best for you in time. Some people like to shift earlier, some people prefer higher rpms. There's not much more satisfying when driving a manual transmission than a perfect rev-matched heel-toe downshift. If you've practiced and know the car, you can pretty much do it almost perfectly every time. There is minimal wear on the clutch. I've pulled clutches out of my cars at 80-90,000 kms or more and it still looks almost new. If you're looking not to wear components out, and you are not comfortable rev-matching or heel-toeing, by all means don't do it, but that doesn't mean it is the correct way to do it, or that you are driving "better". I'm not recommending people be shifting all the time and to every gear every time they're accelerating/slowing down. For example if you are on the highway coming up to a turn-off and you are slowing down in say 5th and you slow down in gear and get to the corner and you feel you should be in 2nd, go to 2nd and continue on your way, but I would not suggest clutching in or going to neutral and then coasting/braking with the engine disengaged and then going into 2nd. That is wearing out more components than just staying in the gear and simply shifting to second. In that situation I would probably go 5-4-2 or 5-3-2, but honestly every corner is different, speeds are different, surroundings are different. Basically: Read/watch/learn as much as you can both about how the car works and why things are the way they are and you can get the most from your car for a long period. My main point is that, in most cases, is is almost always preferable to be in some gear while slowing down, and not in neutral or pushing in the clutch until you are at a low speed. Jeff
#70 |
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) — General Topics | 59 | 12-01-2013 12:28 AM |
| Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 | Snoopyalien24 | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 11-26-2011 07:56 AM |
| Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) — General Topics | 67 | 11-09-2011 05:58 PM |
| May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
