Old 04-04-2015, 03:16 PM   #281
himbo
Drives: Lightening Red BRZ Ltd.
Originally Posted by NotEric6 View Post
We had our suspicions that the OEM intake manifold doesn't distribute air evenly to each cylinder. Believing that the OEM ECU does not correct for this (which still seems like a viable assumption), we plan to pick up some power by balancing the cylinder distribution some while improving the overall efficiency through reduced flow losses. That was the goal at least.
I have no doubt that you can pick up significant power by optimizing cylinders. There is a great video on youtube detailing how NASCAR does this and they pick up multiple percentages of power. I just didn't think OEMs were to that point yet.
Has this info changed the development or schedule of this manifold?
himbo is offline
Old 04-04-2015, 03:20 PM   #282
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
No, nothing has changed.
VerusEric is offline
Old 04-04-2015, 09:13 PM   #283
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
So long, I've been looking too hard, I've been waiting too long
Sometimes I don't know what I will find, I only know it's a matter of, time
When you need an intake, when you need an intake
It feels so right, so much power, I need to know if you need it too
Maybe I'm wrong, won't you tell me if I'm accelerating too strong
This wallet of mine has been hurt before, this time I want to be sure
I've been waiting for a manifold like you to come into my life
I've been waiting for a intake like you, your engine will survive
I've been waiting for a new intake to make me feel alive
Yeah, waiting for a manifold like you to come into my life
You're so good, when we make power it's understood
It's more than a tune or KoolBRZ can say
Only Velox could make it this way
When you love your car, yeah, really love love your car
I know it's right, from the moment I floor it deep in the night
There's nowhere on earth that I'd rather be than thrashing you mercilessly
With apologies to Foreigner
[ame="https://www.youtube.com/watch?v=GOf915su9q8"]foreigner waiting for a girl like you - YouTube[/ame]
Captain Snooze is offline
The Following 7 Users Say Thank You to Captain Snooze For This Useful Post:
2much (04-05-2015), adprokid (09-17-2015), Blu-by-U (04-05-2015), gramicci101 (04-04-2015), HatchetBurial (04-05-2015), HUNTERANGEL121 (04-06-2015), Nigelr32 (04-05-2015)
Old 04-05-2015, 10:08 AM   #284
Tim Radley
Drives: None
The turn behind the throttle body alone is a nasty sharp edge. It's just built down to a price that's all.
If you've managed to get the air distribution much improved on this then you will get a load more timing into it when boosted.
The intake shown below took another 7 degrees compared to a ported stock one.
When do you expect to get this tested and ready for launch?
Tim Radley is offline
The Following User Says Thank You to Tim Radley For This Useful Post:
Calum (04-05-2015)
Old 04-05-2015, 12:35 PM   #285
Calum
That Guy
Drives: 2013 asphalt FRS MT
@DeliciousTuning @moto-mike @EcuTek
Anybody know if these cylinder offset correction factors are adjustable with ECUTEK?
Calum is offline
Old 04-05-2015, 01:28 PM   #286
Kodename47
Kodename47's Avatar
Drives: UK GT86
What offset do you mean? I know that fuel and timing trims are available. They just aren't available to end users (at the moment).
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 04-05-2015, 05:54 PM   #287
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I needed to hear that. thanks
2much is offline
Old 04-05-2015, 06:37 PM   #288
Calum
That Guy
Originally Posted by Tim Radley View Post
Stock manifold doesn't run equal air distribution and the stock ecu mapping is offset on each cylinder to compensate for this. So technically each cylinder will now need mapping individually to make this run right. Cool looking product
I'm not aware of any threads talking about it but most oem ecu's on a performance car i've ever measured in this way runs different cylinder maps or at least offset tables for each cylinder for both ignition and fuel. This is why aftermarket ecu's with a single table for fuel and also for ignition often run pretty badly at idle and transient compared to oem.
I'm running a Motec ecu on my GT86 with 4 lambda's (one per header) and its very clear just how bad the intake and exhaust paths are and the amount of difference required. Its not a constant offset either, amounts cross over. If you measure each intake runner and exhaust runner length they all have a different total overall tuned length so it's not surprising at all.
When will pricing and completion date be confirmed on this?
this
Calum is offline
Old 04-05-2015, 07:23 PM   #289
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
@Calum you can adjust fueling and timing trim on a per cylinder basis. But to really do anything with that you'll need a 4 channel EGT or AFR for fuel, and some knock equipment for the timing.
Xero-Limit is offline
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Calum (04-06-2015), gramicci101 (04-05-2015)
Old 04-05-2015, 07:51 PM   #290
Kodename47
Kodename47's Avatar
Drives: UK GT86
If only the access to the per cylinder knock thresholds were logable or accessible like they are on the FA20DIT or on the Motec, that would allow a little part of the picture become more apparent. A lambda sensor in every exhaust port would be ideal but as Tim said it's a big investment. You just have to be aware that this is the case.
So on the stock manifold the front 2 cylinders will run richer than the rear based on the TB to runner angle? If so, is this something that increases as RPM increase?
.: Stealth 86 :.
Kodename 47 DJ:
Calum (04-06-2015)
Old 04-05-2015, 08:03 PM   #291
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Oh Velox, I need air for my engine, so it can make more power.
The stock air runs are so kinky, the engine works hard to breathe.
Oh Velox, help me end this nightmare, so that I can track faster.
Please make more power for me and make my engine run stronger.
Go, the jig is up, the news is out, the parts look astounding.
When data is in, post the numbers up and don't bother rounding.
Need an intake that flows real smooth and let the engine breathe,
To go down the road.
Many, many apologies to Styx
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline
Old 04-05-2015, 11:31 PM   #292
Turdinator
Señor Member
Turdinator's Avatar
This thread just keeps getting better
1974 TA22 Celica
2013 86 GT
Turdinator is offline
Old 04-06-2015, 02:42 AM   #293
zooki
Drives: waiting on a 2021...
Now is not exactly the time,
To try and make a simple rhyme,
Let's all wait for the dyno numbers,
instead of becoming mere word fumblers
No speculations need be fanned,
stick to the facts that are at hand,
Velox is trying to raise the bar,
You ask why? Because racecar...
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline
The Following 8 Users Say Thank You to zooki For This Useful Post:
2much (04-06-2015), ATL BRZ (04-08-2015), Blu-by-U (04-06-2015), Captain Snooze (04-06-2015), flippy (04-27-2015), gramicci101 (04-06-2015), HatchetBurial (04-06-2015), Mad1723 (04-10-2015)
Old 04-06-2015, 03:00 AM   #294
Tim Radley
Drives: None
That is the beauty of having an ecu like the Motec. It allows all this stuff to be logged and experimented with. Knock for example, all 4 cylinders run differently. Even when fuelling is improved, the air path and firing order robbing other cylinders leads to some cylinders knocking before others.
In answer to your two questions. Its not the case they run richer, at some points they run leaner. The required fuel difference crosses over. In other words, at a certain rpm cylinder 3 requires more fuel than cylinder 1 and at another rpm it requires less. It's due to the tuned length and airflow issues.
My concern was that if the stock ecu has cylinder fuel offsets buried within it then not being able to adjust this with an aftermarket table will lead to a proper manifold then not working as good as it can do.
I'd be surprised if the stock ecu hasn't got individual mapping buried deep within as the stock ecu runs smoother than an aftermarket one without individual cylinder mapping. Be nice for an expert on the stock ecu to chime in that has actually dug around inside it and knows exactly what tables are in there. I could be wrong here.
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
