go_a_way1
Old 04-04-2015, 06:51 PM   #1989
dp1
driving smoother faster
Drives: Sold
Originally Posted by 0351USMC View Post
Question for the guys running a moto-east tune on the JRSC kit, what Rev limit is optimal? 7850,8050 or 8150? Keeping in mind my car will have a lighter flywheel and lightened pulleys.
Mine is at 7600 and my understanding is that with stock internals it's risky to go higher. Oil pressure drops enough with stock 7400 redline. I'm using 5w30 oil during warmer months. Experts will chime in.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
0351USMC (04-04-2015)
Old 04-04-2015, 07:03 PM   #1990
CSG David
CSG David's Avatar
If that is a legitimate question, then I have a few questions for you to consider before moving forward:
1. Did you ask Moto-East about this and inquire for his recommendation?
2. What are you trying to accomplish? What are your application goals? This is very important in defining the scope of your project and your willingness to fork money out to make things work reliably.
3. Is your engine built?
The Following User Says Thank You to CSG David For This Useful Post:
Old 04-04-2015, 07:04 PM   #1991
CSG David
CSG David's Avatar
It's not even about oil pressure at that point.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
0351USMC (04-04-2015), dp1 (04-04-2015)
Old 04-04-2015, 08:47 PM   #1992
dp1
Drives: Sold
What else, assuming stock internals?
Old 04-04-2015, 09:08 PM   #1993
sw20kosh
Drives: 2013 Black FR-S
7k rpm if you track.
Old 04-04-2015, 09:10 PM   #1994
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Nah, 7400 is still ok
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
Old 04-04-2015, 09:18 PM   #1995
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
The question is, how much power are you really gaining by revving higher and risking more? I wouldn't go higher than 7400-7600 rpm on stock internals, especially boosted.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Old 04-04-2015, 09:19 PM   #1996
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
1. Yes I was emailing back and forth with Mike earlier (sent extra parts with my FF kit) and I asked about the rev limit. Never got w response. Figured he's busy so I'd ask here. Ultimately I trust what he says.
2. The end result im looking for is a balance of power/performance and reliability, but skewed towards power/perf more. The car will be a weekend fun/spirited driving car and building towards track use as the build progresses.
3. Stock internals. Unless @*LongFella forgot to mention any other work he had done.
0351USMC is offline   Reply With Quote
Old 04-04-2015, 09:21 PM   #1997
0351USMC
0351USMC's Avatar
That's what I figured would be safe on a stock block. Figured I'd ask beforehand. I was on the road today and typed out a quick post from the rest stop, hadn't had a chance to sit down and do hard research on the subject.
Old 04-04-2015, 09:35 PM   #1998
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Stock internals
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
Old 04-04-2015, 09:37 PM   #1999
2016 Camaro SS
Drives: Fast
My tuner, (Nelsmar on these forums) showed no gains worthwhile raising my rev limiter past 7600 on stock internals even while N/A. He said you're penny pinching for horsepower at that point and it's just not worth the risk.
Not sure how the C30 responds to spinning the blower harder past 7400. Getting a tuner to respond on here like Mike could answer it in a heartbeat. I personally wouldn't do it because we're probably talking a small amount of horsepower, but the dyno would tell the story easy. I believe Mike will play it safe and keep you at 7400 possibly topping out at 7600. It's a pretty valid question to ask especially while running a supercharger.
Old 04-04-2015, 09:39 PM   #2000
*LongFella
*LongFella's Avatar
CSG David - You know he's buying my Jenny, right?!? ;-)
Old 04-04-2015, 09:47 PM   #2001
*LongFella
*LongFella's Avatar
Why risk a higher rev limit? Be safe. Unless, you plan to build the engine.
Old 04-04-2015, 09:53 PM   #2002
sw20kosh
Buy a spare engine.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
