Old 03-30-2015, 11:21 AM   #1
Fonzi
Drives: 2013 White FRS
Just ordered new Camshafts
I just ordered a set of camshafts from Piper Cams. These are a new set of cams not regrind.
Intake
Duration : 272
Valve Lift : .472
Exhaust
Duration: 266
Valve Lift: .445
Fonzi is offline   Reply With Quote
The Following 7 Users Say Thank You to Fonzi For This Useful Post:
cdrazic93 (03-30-2015), D K (03-30-2015), Darryljr11 (03-30-2015), Freeman (03-30-2015), Lonewolf (03-30-2015), sw20kosh (03-30-2015), swarb (03-30-2015)
Old 03-30-2015, 01:23 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Sounds like fairly mild cams. Probably the farthest you'd be able to run without getting interference.
Old 03-30-2015, 01:50 PM   #3
Fonzi
Yea that was the goal for me. Since 2 of my camshafts were bent instead of buy new stock ones, I went with these.. I dont want my idle all over the place but with some extra up top. They do have a more extreme cam but not what I am looking for
Old 03-30-2015, 02:03 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
@Fonzi
What are you using for tuning?
Old 03-30-2015, 02:03 PM   #5
sw20kosh
Drives: 2013 Black FR-S
are you forced induced?
Old 03-30-2015, 02:10 PM   #6
Fonzi
Ecutek.
Old 03-30-2015, 02:11 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
JESUS how did you bend a camshaft and not throw valves like bullets!?
Old 03-30-2015, 02:14 PM   #8
Fonzi
I am running full blown stage 1 with a gtx2867 ( selling turbo ) need bigger turbo.
Engine build:
-Pauter Rods
-JE Pistons 9.5 compression
-ARP Bolts
- Aftermarket Head Gasket
Heads
-Ferrea +1 MM Exhuast and Intake Valves
- Ferrea Dual Spinrgs
- FerreaTitanium Retainers
-Port and Polish
-Five Angle Valve Job
-Piper Cams
The Following User Says Thank You to Fonzi For This Useful Post:
WORKS (02-12-2018)
Old 03-30-2015, 02:17 PM   #9
Fonzi
not completely sure to be honest. but did go to the machine shop to verify it was .020 out on the dial indicator
Old 03-30-2015, 08:31 PM   #10
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
12mm on intake and 11.3 exhaust. Have you done any measurements for static overlap? I do wonder if 12mm is possible on exhaust. For your turbo size it seems pretty good. BTW are these measured at .010 valve opening?
Coheed is offline   Reply With Quote
Old 03-31-2015, 09:08 AM   #11
Fonzi
My turbo size will be going to a gtx3076 or gtx3582.. The measurments are done at 110 degree nominal and has a 49 degree overlap.
Coheed (04-05-2015)
Old 04-04-2015, 08:48 AM   #12
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Who are you using to build your engine? I'm probably going to go that way in a year or two.
industrial is offline   Reply With Quote
Old 04-04-2015, 10:12 AM   #13
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Go with gtx30. gtx35 may not hit peak boost till 5k rpm and unless you wanna make a drag monster with over 650whp its not worth it.
Darryljr11 is offline   Reply With Quote
The Following 2 Users Say Thank You to Darryljr11 For This Useful Post:
Fonzi (04-04-2015), Surok (01-19-2018)
Old 04-04-2015, 12:49 PM   #14
Fonzi
I am using Redline Motorsports in Brentwood NH
industrial (04-04-2015)
Where are all the high lift/duration camshafts! stevo585 Engine, Exhaust, Transmission 35 02-23-2015 06:39 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
CAMSHAFTS! have they made any? karma003 Engine, Exhaust, Transmission 21 11-04-2013 07:35 PM
Have you ordered your FRS? MrFRsLa Southern California 10 05-16-2012 01:13 PM
FR-S pre-ordered ! but ... QC-FRS CANADA 11 04-20-2012 01:53 PM
