Drives: 2015 WRB BRZ
Dual Climate Control LED Issue
So, this is kind of a weird issue but I hope someone has encountered and fixed it before I call the dealer. I don't know when this started happening, but recently when the "Dual" LED is lit up, the temp controls are independent, and when I hit the switch and the LED is off, the temp controls are combined. It seems that this is now backwards. Anybody ran into this?
#2 |
Drives: Subaru BRZ
Wut? When Dual LED is lit, its supposed to allow each side a unique temperature. When its not lit, each side will be forced to be identical.
If its doing the opposite, I dunno - try disconnecting the negative battery terminal for a bit to reset virtually everything. If its not back to normal call the dealer? |
#3 | |
I Love custom Turbo kits
Drives: Limited BRZ
#4 |
INTJ
Drives: 2017 86 860
Dunno if serious or April Fools...
#5 |
Drives: BRZ DGM Limited
mine works that way too.
I also noticed that when I push the gas pedal my car goes faster. |
| Automatic dual climate control harness | Sangthing | Electronics | Audio | NAV | Infotainment | 209 | 05-19-2023 01:16 AM |
| Climate Control Issue | amishdude01 | BRZ First-Gen (2012+) — General Topics | 32 | 12-17-2014 05:15 PM |
| BRZ limited dual climate control | Sangthing | Interior Parts (Incl. Lighting) | 6 | 09-12-2014 07:01 AM |
| Ac knobs for BRZ limited / FRS with dual climate | dnizzle | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-15-2014 11:43 PM |
| FS - BRZ Dual Climate Control Unit | dvsidboy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 01-12-2014 09:52 PM |
