Old 03-30-2015, 08:29 PM   #1
zeal86
zeal86's Avatar
Drives:
DIY: 86 Tightening Torque Values
Having as many torque vaules in one place as possible will hopefully save time for some of you do-it-your-selfers.
Please add or correct errors in the list I have compiled by posting the following and I will update the list :
• proper name for part/best description of part
• torque value (please convert to ft/lbs whenever possible)
• location of the part
• post image of and/or link to schematic, diagram, drawing, illustration, figure, etc...
86 Tightening Torque Values (**In ft/lbs unless otherwise noted**)
__________________________________________
Engine/Transmission __________________________________________
Air Intake Boot Clamp (Except for Air Cleaner Case) | 1.5
Air Cleaner Case | 4.4
Air Intake Boot Clamp (Air Cleaner Case) | 2.2
Automatic Transmission Drain Plug | 7.4
Automatic Transmission Fluid (ATF) Overflow Plug | 27.3
ATF Refill Plug | 27.3
Belt Covers (#1 & #2 ) | 4.7
Cam Plate | 12
Clutch Push Rod Lock Nut | 5.9
Crank Pulley | 94
Differential Gear Oil Drain & Filler Plugs | 36.1
Differential Carrier Assembly
- Rear Upper Mounts | 46
- Rear Lower Mounts | 70
Engine Grounded Cable | 5.5 ft/lbs / 66 in/lbs
Engine Mounting Bracket Nut (FR) | 33.2
Engine Mounting Bracket Bolt (FR) | 26
Engine Under Cover (#1) | 22.1
Engine Under Cover (#2) | 5.5 ft/lbs / 66 in/lbs
Exhaust - bolts securing bracket of exhaust pipe assembly (FR) | 36.9
Exhaust Manifold Sub-Assembly | 22.1
Exhaust Pipe Assembly (FR) | 31.3
Exhaust Pipe Assembly (CTR) | 13.3
Exhaust Pipe Sub-Assembly (FR) | 25.8
Fuel Injector (CM) | 4.7
Fuel Pump | 62.7
Fuel Tank Protector No. 3 | 80 inch/pounds
Ignition Coil | 6.3
Intake Manifold Protector (LH & RH) | 6.3
Oil Filter (80mm Wrench) | 10.3
Oil Filter Union | 33.2
Oil Pan Drain Plug | 28.9
Sound Creator | 4.4
Sound Creator clamp | 1.5
Spark Plug | 12.5
Steering Shaft Joint | 25.8
Transmission Drain & Filler Plugs | 27.3
Vacuum Booster Operating Rod Lock nut | 16.2
Chassis/Suspension/Wheels/Brakes
Body Mounting Cusion Sub-assembly (Rear LH & RH) | 44
Brake Bleeder Valve (R) | 5.9
Brake Line | 24
Cross Member Sub-assembly (FR) | 70
End Link (at Lower Control Arm) | 28
Gearbox | 44.3
Knuckle Ball Joint Castle Nut | 19.9
Lower Arm Suspension Assembly | 38
Lower Arm Support Plate Bolt | 81
Lower Arm Support Plate Nut | 81
Lower No. 2 Arm Bush (Front LH & RH) | 63
Lower Suspension Arm Bolt (FR) | 81
Parking Brake Cable Assembly No. 2 Clamp Bolt | 13
Parking Brake Cable Support Bracket | 13
Rear Body Mounting Cushion Sub-Assembly Bolts | 44
Stabilizer Bar Bushing No. 1 Front
Stabilizer (End) Link Assembly (FR LH & RH) | 34
Stabilizer Bracket (R) | 22
Stabilizer (End) Link (FR) | 34
Stabilizer (End) Link (R) | 28
Steering Knuckle | 114
Strut Top Nut (R) | 41
Strut Tower (FR) | 17
Strut Tower (R) | 22
Strut Tower Bars | 12
Suspension Arm Bolt (Rear) | 81
Suspension Arm Bushing Bolt No. 1 (R) | 81
Suspension Member Sub-assembly:
**Front Support | 52 (14mm) , 107 (19mm)
**Rear Support | 107 (19mm)
Stabilizer Bracket Bolts (FR) | 55
Stabilizer Bracket Nuts (FR) | 18
Sway Bar Bracket (R) | 44
Tie-Rod End Lock Nut | 62.7
Tie-Rod End Sub-assembly LH & RH | 20
Toe Adjust Cam | 74
Toe Control Link Sub-assembly (LH & RH) | 44
Upper Control Arm Assembly (Rear LH & RH) | 66
Wheel Lug Nuts | 89
projekt zeal86 build
zeal86 is offline   Reply With Quote
The Following 29 Users Say Thank You to zeal86 For This Useful Post:
8R6 (02-01-2016), airrick (04-08-2020), Andrew025 (04-03-2015), ap5512 (04-05-2015), Ayrton (02-13-2016), Calum (04-03-2015), CxG (06-12-2018), DandoX (02-10-2020), DarkestBuddha (03-30-2015), fstlane (04-04-2015), funwheeldrive (03-25-2018), GhostOp86 (04-03-2015), gtengr (10-22-2017), juliog (04-09-2017), Kaotic Lazagna (04-08-2015), Keenercarguy (06-09-2017), melon (04-04-2015), mgarcia707 (03-10-2020), microSDHC (12-12-2018), mit_peid (04-03-2015), mokinbird87 (01-10-2017), No1der (04-03-2015), Shankenstein (02-03-2016), smg1138 (05-11-2016), STV3 (02-01-2016), Sugi (04-05-2015), SuperDave (08-28-2017), TIE Pilot (04-03-2015), weederr33 (08-13-2024)
Old 03-30-2015, 08:31 PM   #2
zeal86
zeal86's Avatar
Drives:
I'm looking for the subframe bolt torque value...can anyone help me out with that?
thanks in advance.
Old 03-30-2015, 10:06 PM   #3
zeal86
zeal86's Avatar
Drives:
Also, I've come across some information that is conflicting... Is the torque value for the strut tower bar nuts (front) 17 ft/lbs or 11.8 ft/lbs?
Old 04-02-2015, 08:03 PM   #4
8R6
8R6's Avatar
Drives: FRS
im pretty sure it's 17 lb.-ft.
8R6 is offline   Reply With Quote
Old 04-03-2015, 09:28 AM   #5
babydriver
Hit the road and I'm gone
babydriver's Avatar
GrimmSpeed recommends 12 ft/lbs, but I torqued mine to about 20. No problem with the bolts, but I wouldn't go any higher than that. Otherwise, SNAP!!!
17 is probably good and tight and also nice and safe.
Slip, slidin' away.
Old 04-03-2015, 09:46 AM   #6
zeal86
zeal86's Avatar
Drives:
Anyone recognize these bolt identification markings. Trying to determine proper tightening torque. Thanks in advance.
M8x1.25
M10x1.25
Old 04-03-2015, 09:46 AM   #7
jvincent
jvincent's Avatar
Correct value is 12 ft/lbs according to the repair manual.
Old 04-03-2015, 09:59 AM   #8
jvincent
jvincent's Avatar
Those are the bolt grade markings.
Old 04-03-2015, 10:04 AM   #9
ISDriven
ISDriven's Avatar
Drives: chill
Sticky please.
ISDriven is offline   Reply With Quote
Old 04-03-2015, 10:08 AM   #10
jvincent
jvincent's Avatar
There are several sub-frame bolts. Which ones are you referring to?
Old 04-03-2015, 10:17 AM   #11
zeal86
zeal86's Avatar
Drives:
I understand that but most references I've come across have the classes as 4.6, 5.8, 8.8, 9.8, etc... I have not come across the ones I posted above.
Old 04-03-2015, 10:18 AM   #12
zeal86
zeal86's Avatar
Drives:
I'll take pictures of the locations later and post them.
Old 04-03-2015, 10:28 AM   #13
jvincent
jvincent's Avatar
OK. In case you haven't seen it, the full repair manual is here:
http://www.ft86club.com/forums/showthread.php?t=12135
If you download the portfolio version it is easier to navigate. It has all of the torque values with pictures.
The Following User Says Thank You to jvincent For This Useful Post:
zeal86 (04-03-2015)
Old 04-03-2015, 02:25 PM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
This should be stickied in the maintenance forum.
BRZ Steering Right Tightening + VSC Fault?? BRZ2Bars Issues | Warranty | Recalls / TSB 4 05-07-2015 04:58 PM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) — General Topics 20 10-16-2014 06:38 PM
Front Oxygen Sensor Scaling - How do we make it read richer values? D-VO Software Tuning 7 05-08-2014 05:48 AM
Safe values? mike_ekim1024 Software Tuning 12 11-05-2013 02:19 PM
Tightening the Rear scottynoshotty Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-16-2013 01:57 PM
