Old 03-25-2015, 02:01 PM   #211
Originally Posted by s2d4 View Post
Yeah, no.
Can you expand on that?
Ultramaroon is offline
Old 03-25-2015, 02:32 PM   #212
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
My thought as well.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline
Old 03-25-2015, 04:29 PM   #213
Calum
That Guy
Drives: 2013 asphalt FRS MT
The piping is plenty to flow the volume of air without undo restriction. Mike was saying he'd have to upgrade the size of the MAF housing not the while run. The MAF sensors range of what it can measure is determined by a maximum air flow velocity. The max air flow velocity is determined by the size of the tube.
Calum is offline
The Following 2 Users Say Thank You to Calum For This Useful Post:
s2d4 (03-26-2015), Xero-Limit (03-25-2015)
Old 03-25-2015, 08:48 PM   #214
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I'm thinking axles as well. Coilovers went on but we couldn't get anything less than -2.1 camber which spins the 245's in 3rd still. We have the SPC bushings and @Raceseng strut tops planned for tomorrow which will give us what we need up front too.
I know some of the other guys we shipped these kits too should be unpacking theirs. Anxious to see how we do with the varied setups those are going on.
Xero-Limit is offline
Old 03-25-2015, 09:11 PM   #215
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
im thinking thats what my problem is somewhat with traction. 2.3 on the left and 3.2 on the right side.. LCA's are hear to take care of that now
Drive the car here to Vegas
86SPEED is offline
The Following User Says Thank You to 86SPEED For This Useful Post:
Old 03-25-2015, 09:42 PM   #216
sam69
Drives: GT 86
You can, but the restriction at the box won't help.
I'm aware of that, that's why I have a modified (for oil cooler lines) CF Simota air intake system sitting in the workshop ready to go on but is there any point if the Maf pipe and TB are a restriction
Also can the factory ecu be tuned with/for a larger TB and Maf pipe ??
sam69 is offline
Old 03-26-2015, 04:01 AM   #217
s2d4
s2d4's Avatar
Knowledge for the win!
That was the yes part of what you had quoted.
As for the intake, whatever you are happy with it.
s2d4 is offline
Old 03-27-2015, 12:39 AM   #218
Ron
Drives: Mr2
Incorrect Sir with all do respect.. in addition, there is power to be made with a proper filter/tube/TB combo, as they work in sync. For example, 80mm TB and 90mm filter/tube. Kenne Bell does it all day long. Sir, please remember that a SC works ALOT easier with an unrestricted, extremely free flowing inlet.
In fact, 65mm on the inlet tells me the 210 is loosing power in the upper revs as well. I really don't think some of you realize what kind of beast you have by way of MASSIVE inlet and meth injection. Just to note, your success with a properly setup Sprintex design benefits me as well having skin in the game, yet I have yet to see one setup correctly for maximum Volumetric Efficiency and I'm back and forth with my CNC guy to get me my finished components.
Ron
Ron is offline
The Following 2 Users Say Thank You to Ron For This Useful Post:
sam69 (03-27-2015), Ultramaroon (03-27-2015)
Old 03-27-2015, 01:08 AM   #219
s2d4
s2d4's Avatar
Ron
What is the restriction of 65mm? CFM?
s2d4 is offline
Old 03-27-2015, 01:36 PM   #220
Subzero
Old...
Subzero's Avatar
Drives: Subaru
Would a "torque box" do any good, giving it a plenum to breath from in front of the throttlebody?
Subzero is offline
Old 03-27-2015, 04:19 PM   #221
blown
Drives: ft86
Ron
I'm curious as well , what about the inlet elbow? I was considering one of your kits on my aw11 awhile back.
blown is offline
Old 03-28-2015, 03:54 PM   #222
Ron
Drives: Mr2
Bigger is better. Not sure what size the inlet is, but if it's 65mm on the opening to match the TB then it is undersized for max VE while overspinning. Since most overspin, most can benefit from an increase in inlet size. HP is gained by allowing the compressor to spin more freely via increased inlet. And meth injection has the distinct ability to raise the adiabatic efficiency of the compressor, effectively lowering compressor oil and outlet temperatures respectively. With that said, you guys should be in love with the base kit and what it provides for you with bigger power around the corner. Much however is involved to increase compressor VE. I believe your TB is fly by wire and not sure if ECUTEK can convert MAF signal to allow for a bigger MAF to be ran. So SC inlet manifold, TB, and MAF/filter tubing all need to be increased to allow maximum compressor VE. Guys, just take a quick peek at Kenne Bells page and ask yourself, why on earth do they keep going bigger and bigger on the inlet. It's simple as mentioned earlier; it frees up HP by way of allowing the compressor to spin more freely.
Ron
Ron is offline
Old 03-28-2015, 05:58 PM   #223
350matt
Drives: toyota mr2/ Toyota GT86
there's some good points raised here, and I believe its worth trying
but only once you're up over 300Bhp
and yes ECUtek allows you offset / rescale the MAF so you can fit a larger MAF tube with the stock plug in part
and you can get a larger TB from Cusco and MAP performance - but I've yet to seee any gains published for these
350matt is offline
Old 03-28-2015, 06:16 PM   #224
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Lightbulb
I am looking at exhaust options for the 335. Should I be running a 3" exhaust setup like one would for a turbo setup for better performance?
Chad86 is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 12:27 PM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 04:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 03:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 08:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 08:39 PM
