| Software Tuning Discuss all software tuning topics. |
Drives: Toyota 86 GTS
OFT - Example alternate maps for AT, 98RON, E85, MAF Scales
Note:
I now have files hosted for all MY12-16 cals here. - On my roms you can dial in AFR perfectly on stock intake IN ONE REVISION with alternate maf scales. - All are cal hacked from A01G/A01I/B01C/B01D, thus logging and LC work for every rom on OFT. - No issues with unmapped DTC's or E85 cranking. - Includes FLEX FUEL for both 6AT and 6MT. - I've done a few MY17's now, but I've no idea about the logging capabilities for those cars on OFT yet. ADDRESS: http://www.wayneroms.com/ While the following examples may still be interesting to some, my current files make the majority unnecessary and obsolete. Below examples represent easily between 200 flashes to my ECU. Some of the screens are current, some seem fairly rudimentary now, but they still make decent examples. Please see the guide below for choosing a maf scale and load limits. http://www.ft86club.com/forums/showthread.php?t=94822 WHAT TO LOG TO DIAL IN YOUR TUNE: Engine Speed (rpm) Throttle (percent) MAF Voltage (volts) MAF g/s Engine Load (g/rev) Ignition Advance / Total Timing (degrees) AFR Commanded AFR / Target AFR STFT (percent) LTFT (percent) Fuel Sys Status (2 = CL, 4 = OL) IAT / Intake Air Temp (F) Advance Multiplier FLKC / Fine Learning Knock Correction (degrees) IT'S IMPORTANT TO DRIVE 100km/60mi AT PART THROTTLE UP TO 6000rpm THEN LOG THE ABOVE PARAMETERS AT WOT 2500-7200 rpm. ONLY THEN WILL YOU BE ABLE TO CHOOSE THE CORRECT AND/OR WORK ON A MAF SCALE. SEE END OF POST FOR DEFINITIONS AND EXAMPLE ROMS COMMON CHANGES O2 SENSOR SCALE (NOTE: RESCALED AXIS) OTS (top) v86 (bottom) Radiator fan activation when car is at operating temperature and under 70kph. OTS/Stock (top) v86 (bottom) AT THROTTLE All my maps now have a brand new AT throttle map. The MT throttle map is more linear but doesn't work as well between shifts on the AT with longer ratios. v100 (left) OTS/Stock (right) LOAD LIMITS (NOTE: RESCALED AXIS) (out of date) STAGE 1 Stg1 98 v86 vs OTS BASE TIMING DIFF Stg1 AND Stg2 98 TOTAL PORT INJECTOR RATIO (COLD/HOT/WARM) NOTE: RESCALED AXIS This is useful for maf scaling. I recommend restoring port injection at 5000 rpm to be safe. STAGE 2 Stg2 98 AND E85 QUIET COLD START OTS (top) v86 (bottom) STAGE 2 PETROL Stg2 98 MAF SCALE (out of date) OTS vs v86 DIFF (top) v86 (bottom) Stg2 98 LEAN VS RICH MAF SCALE (out of date) v86 LEAN based on Stg1 (top) v86 RICH based on Stg2 (bottom) Stg2 98 v100 vs OTS BASE TIMING DIFF Stg2 vs Stg1 BASE TIMING DIFF (out of date) Stg2 IMRE 98 vs Stg2 98 BASE TIMING DIFF Stg2 98 v86 vs OTS TOTAL TIMING CHANGES (3D) (Add +6 deg adv for total timing) (out of date) E85 E85 FUEL DASH DISPLAY OTS/Stock (top) v86 (bottom) E85 CRANKING IPW E85 CLOSED LOOP FUELING MAP OTS (top) v86 (bottom) E86 OPEN LOOP FUELING MAP OTS (top) v86 (bottom) E85 v86 vs OTS BASE TIMING DIFF v99 E85 vs 98 v100 TOTAL TIMING DIFF E85 v86 vs OTS TOTAL TIMING CHANGES (3D) (Add +6 deg adv for total timing)
#2 |
Drives: Toyota GT86 Manual
Thanks Wayno.
How hard is it to apply these same changes to the manual ZA1J___G ROMS (EU 6MT) roms? Have you made any changes for your PSR Headers (or are they similar enough to the OpenFlash headers that they just work)? |
#3 |
Yep, any G rom.
Most UEL are the same. The ethanol in our E85 is mixed with worse fuel than US though, so there's some timing taken out for knock a few people have logged at 6800rpm, even though our E% is higher. |
#5 |
Drives: MR Spyder/GT86
I dont get it so this is only for the the automatics? or can it be used for manuals?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
#6 | |
Drives: FT86
Throttle tables are different between auto/manual. Their is an E85 G rom attached to the first post |
#7 |
Drives: Toyota 86
Nice work Wayno.
#8 |
More work done to E85 tunes. OP updated.
#9 |
Drives: Toyota GT86 6M/T
#10 |
Timing, fuel, cranking, do a compare with the old one if you downloaded it.
#11 |
Drives: GT86
Good work.
I do wonder if there is any further discussion on long term effects of running lean even on low load but for extended times? What to look for when logging, what could go wrong? Target AFR 14.7? Is this both DI and indirect injection? Also what happens during the warm up phase? Sorry lots of questions
#12 | |
Drives: FT86
If you have a look at the stock rom fueling tables you will see it runs leaner than these tunes for higher rpm and loads. The OL AFR fueling tables are the target afr, their are tables for the di\pi ratios but the overall target afr is determined by the ol fuel table and a couple of closed loop offset tables when running in closed loop. Ethanol generally results in lower exhaust temps than petrol. As always these tunes are provided free with no guarantee, run at your own risk. @Wayno and myself have been running them for a few months and mine is running leaner tables than the ones posted here, however everyones fuel blends are different.. always check your tune is running reasnoble fuel trims less than 10%, your wot afr follows open loop fuel table and little or no knock and iam at 1. by warmup phase assume you mean high rev cold start, as far as we know this is just to heat cats for emmisions purposes, you still need to give you car about 10 minutes to get coolant and oil to operating temps, regardless of what alterations you make to starup phase |
#13 |
Drives: GT86
Warm-up I usually drive very light throttle just under 3000rpm, I wondered how this could be affected by a leaner blend.
#14 |
Drives: FT86
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 09:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 10:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 12:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 05:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 04:26 PM |
