Old 03-22-2015, 02:33 PM   #1
mortybryant
mortybryant's Avatar
Drives: Scion FR-S RS 1.0
CEL and Cruise Issue???
Started my RS1 this morning and the CEL was on. I'm just over 5k miles. No noticeable issues. Went ahead and took off. Approximately 10-15 miles later I notice my cruise control won't engage. The light is also orange (typically green). I stop, turn the car off and back on. CEL is off. Continue to drive and cruise control is now working.
Any ideas???
mortybryant is offline   Reply With Quote
Old 03-22-2015, 02:41 PM   #2
Koa
no concrete analysis can be made unless you're able to pull the CEL
Old 03-22-2015, 02:45 PM   #3
leoh007
leoh007's Avatar
Drives: 2014 Monogram
Not sure what the problem is but your car goes into limp mode when the CEL is on, hence not being able to use cruise control you may possibly get a traction control light on as well. I had the same issue. Bought a catless header which resulted in this issue, not sure if you have aftermarket parts but if you do a tune is needed. hope this helps
leoh007 is offline   Reply With Quote
Old 03-22-2015, 02:46 PM   #4
mortybryant
No aftermarket parts, but thank you for the info. Much appreciated.
Old 03-23-2015, 01:03 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Idea: CEL prevents cruise from being used.
Solution: find out what caused the CEL and prevent it from coming on.
-alex
strat61caster (03-23-2015)
Old 03-23-2015, 01:13 PM   #6
Could be as simple as a wet or dirty sensor or something as bad as an possible total failure and 1,000 things in between.
If it repeats take it in.
Old 03-23-2015, 01:34 PM   #7
Tromatic
A CEL does not always mean limp mode, which is more than obvious when that is happening.
If you have any plans at all (or not) for mods, an OBD dongle and something like Carista is a must have for reading and clearing codes.
The Following User Says Thank You to Tromatic For This Useful Post:
Tcoat (03-23-2015)
Old 03-23-2015, 02:49 PM   #8
zooki
Drives: waiting on a 2021...
Have you gotten sideways, or done any donuts? Mine does the same thing sometimes when I slide it around, or do donuts. Turn the car off, start it back up, good to go. I think it has something to do with the stability control freaking out.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Tcoat (03-23-2015)
Jan 11th OTOC Cruise to the 'Cruise In Country Diner' OTOC Northwest 12 01-11-2015 01:03 AM
Cruise to 'Cruise In Country Diner' 1-26-14 OTOC Northwest 29 03-29-2014 01:39 PM
Cruise to Cruise In Country Diner Sept 8th OTOC Northwest 6 09-06-2013 04:41 PM
OTOC cruise to Cruise in Country Diner OTOC Northwest 36 01-15-2013 09:18 PM
cruise control and speedo issue.. tibsy92 Issues | Warranty | Recalls / TSB 1 10-10-2012 01:21 PM
