Old 03-21-2015, 11:44 PM   #197
Ron
Drives: Mr2
Originally Posted by alexisfire02 View Post
I'd like to see your torque drop offs.
We did dyno pulls with 68, 70, 72, and 80mm pulleys.
The torgue drop was worse every time we went down a pulley size.
In fact, the 72mm pulley offered the best looking dyno.
Hello sir, I am curious to know if you where running the stock inlet and TB while over spinning the compressor. I ask because I notice that you mentioned you had a hard time with controlling the heat of the 335. With stock 70mm inlet and TB, 68mm sc pulley on this compressor is really over working it. I have designed a 75mm billet inlet for a different application and I'm very concerned now that I may need to go 90mm, and that's on a 1.6L. For example, I used an undersized inlet and TB on my first twinscrew build. After increasing the size, I gained close 100rwhp. Got to love those Twinscrews!
On another note, why are there all these pics of guys running there filter in the engine bay? That can't ever happen with the Twinscrew compressor.
Ron
Ron is offline
Old 03-22-2015, 09:58 AM   #198
Ron
Drives: Mr2
Originally Posted by moto-mike View Post
Another issue though is the intake, we're hitting 5v on our big intake, which means you'd need a 3.5" MAF or bigger to flow what this would flow on a smaller pulley.
Excellent news. The 335 seems to have room to grow, though bigger TB will be a bigger challenge while increasing inlet size.
Ron
Ron is offline
Old 03-22-2015, 02:44 PM   #199
xwd
Ron
I was kind of curious about the throttle body size as well. I have one of the TRD S/Cs (not twinscrew, but TVS 1320), and the kit Magnuson/TRD developed uses a 15mm larger than stock TB (stock is 65mm, the kit uses an 80mm TB). It's a roots blower but similarly sized to the Sprintex 335.
I've always looked at the IC as being the restriction with the Sprintex kits, but maybe that's not accurate.
People put filters in the engine bay because it's easy, although the Sprintex kits re-use the stock airbox so it shouldn't really be necessary.
xwd is offline
Old 03-23-2015, 12:54 AM   #200
s2d4
s2d4's Avatar
Stock intake setup becomes a restriction over 300hp, apparently according to cosworth engineers.
s2d4 is offline
Old 03-23-2015, 04:27 AM   #201
sam69
Drives: GT 86
So how could this be overcome as from what I understand the ecu calculates everything from the air flow through the MAF pipe and if you increase the size of the air flow straightener at the air box it causes AFR issues and similar with TB.
Why can't one just increase the size of the above (MAF pipe & TB ) and then tune accordingly
Give me a Weber carbie and I'll tune it but these thing confuse me LoL .
sam69 is offline
Old 03-23-2015, 06:20 AM   #202
s2d4
s2d4's Avatar
You can, but the restriction at the box won't help.
s2d4 is offline
Old 03-23-2015, 09:06 AM   #203
Ron
Drives: Mr2
So 325rwhp was made by way of 65mm inlet? That is outstanding! Common forced induction fundamentals will tell you the outlet (intercooler) is always the bottle neck. However with a SC especially TS compressor, it is the inlet design that holds all the magic.
So it's a 70mm MAF sensor and 65 mm TB? Inlet increases sometimes can only be made by way of standalone, as the efi negotiation with stock Ecu can not always be accomplished.
Ron
Ron is offline
Old 03-23-2015, 09:51 AM   #204
s2d4
s2d4's Avatar
Ron
Why are you so adamant that 65mm would be a restriction at 325rwhp?
s2d4 is offline
Old 03-23-2015, 11:11 AM   #205
Ron
Drives: Mr2
I think Mike mentioned he is maxed out on the inlet and needs to go at least 3.5 inch. That must be all the way through to blower to maximize compressor efficiency. When overspinning the 335, a 65mm TB is far too small for that size compressor. It's one of the biggest mistakes when trying to make big power out of a Supercharger. Choking the inlet will force the compressor to work harder especially on the top end, and especially while increasing compressor speeds. Effectively heating the outlet temps and lowering boost. 210 and 335 guys that are overspinning your compressor should take a boost reading behind the air filter. You'll find that you have a restrictive inlet at higher compressor speeds.
Ron
Ron is offline
Old 03-23-2015, 12:34 PM   #206
s2d4
s2d4's Avatar
Yeah, no.
s2d4 is offline
The Following User Says Thank You to s2d4 For This Useful Post:
Calum (03-23-2015)
Old 03-23-2015, 02:21 PM   #207
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Summer rubbers are on...finishing up the alignment and we should do some beating on the car again!
Thinking of doing a poll: What will break first?
Axles?
Trans?
Pop the motor?
Hopefully none of the above! Though we will put the 80mm pulley back on I think.
BTW we have an open house May 9th. Anyone wants to go for a quick spin in the car will be able to (passenger).
Xero-Limit is offline
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Boofneenee (03-23-2015), Calum (03-23-2015)
Old 03-23-2015, 04:54 PM   #208
Yoda
Drives: Crystal Black BRZ(Sophia)
Axles?
Trans?
Pop the motor?
Axles first then trans.
Yoda is offline
The Following User Says Thank You to Yoda For This Useful Post:
Dream20b (03-24-2015)
Old 03-25-2015, 11:40 AM   #209
smudge
Drives: Supercharged GT86
I reckon the driveshafts (axles) will go first
smudge is offline
Old 03-25-2015, 12:53 PM   #210
Axles?
Trans?
Pop the motor?
4th gear
Wish I was in PA. I'd love to do a ride-along.
Ultramaroon is offline
ATL BRZ (03-25-2015), Dream20b (03-26-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
