Old 03-21-2015, 09:02 PM   #1793
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
There's some goodfellas on this thread.
I'll still be around 😉
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-21-2015, 10:23 PM   #1794
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
It has been a good read! What are you moving onto @LongFella?
Jmonty is offline   Reply With Quote
Old 03-21-2015, 10:38 PM   #1795
*LongFella
*LongFella's Avatar
Jackson Racing Supercharger Owners Thread
The next toy (aka "Daddy Car") is one of the pre-order launch edition 2015 VW Golf R. I got lucky and was able to get one of the first 500 launched in the US. It's a beast! It has a LOT of potential for some serious power.
I have the same forum name on VWVortex and started a build thread there too.
Maybe Jackson Racing can get into the VW market? hint hint wink wink 😉
Old 03-22-2015, 01:08 AM   #1796
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Well you already have a good relationship with them, so maybe you can test mule for them. And itll be baby approved. Thats almost as good as CARB approval
0351USMC is offline   Reply With Quote
Old 03-22-2015, 01:32 AM   #1797
*LongFella
*LongFella's Avatar
So... Oscar Sr and Oscar Jr...
I've got a test car for you 😁
...can't forget about Church! Want a go at it?
Old 03-23-2015, 06:45 AM   #1798
CSG Mike
CSG Mike's Avatar
Originally Posted by 0351USMC View Post
Well since Im buying @*LongFella 's JRSC'd FRS I went thru and read the full 82 pages of this thread. Definitely learned a a lot and prevented a fair amount of Noob questions I would have ended up having. Looking forward to getting this ride and bringing it up North. Hwy 1 will be a fun drive from SoCal up here to the Bay Area.
Congrats!
@*LongFella see? Easy!
Old 03-23-2015, 08:08 AM   #1799
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
I thought I might ask if anyone is Crawford Billet Power Blocks with their JRSC kit?
I am. But I am also planning to take them off over the weekend. My problem is that they lift the intake to a point where it lightly touches the hood padding and I just do not like it.
From what I have read they add no value once you go FI.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 03-23-2015, 08:10 AM   #1800
RevoG
RevoG's Avatar
Does anyone have a definite answer on where to install two oil sensors? I have both the oil temp and oil pressure coming but want to know the best place to install them. Was thinking of putting the temp sensor on a sandwich and the pressure sensor on the block, but would like some guidance in this regard.
Old 03-24-2015, 06:34 PM   #1801
CSG Mike
CSG Mike's Avatar
Pressure is usually installed in-line on an oil cooler line, since most people monitoring pressure also have oil coolers.
Temp is already available on the car.
Old 03-24-2015, 08:10 PM   #1802
sw20kosh
Drives: 2013 Black FR-S
SHARTA uses the oil galley port or whatever it is called on the block.
Old 03-24-2015, 08:40 PM   #1803
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You could use a oil sensor sandwich plate like this:
http://www.ft86speedfactory.com/trd-...late-1740.html
If you are using the Mocal thermostatic sandwich plate with spacer, this will replace the spacer and you can order a new shorter adapter screw to mount the oil take off plate to.
I found oil temperature readings taken from the sandwich plate were higher than what the ECU reads, as ECU reads post-cooler.
JDKane527 is offline   Reply With Quote
Old 03-25-2015, 04:31 AM   #1804
RevoG
RevoG's Avatar
Thanks Mike, can I use the galley plug for the pressure sensor? I do not want to cut or make changes to the current oil cooler set up.
Also, I'm running the Greddy Informeter and it does not show the oil temps. I know the car has this function through techstream but I could not get it to work on the Greddy. This is why I want to install on a sandwich just below the oil filter.
Old 03-25-2015, 11:00 AM   #1805
Xuningshen
Drives: Subaru BRZ
You feel comfortable having 2 "extender" things on there? one screwed onto another? i dont like the feeling of it for some reason.
I'm running oil pressure from the gallery plug next to the AC compressor and it works just fine. i got the prosport oil pressure sender relocator "kit" that has the m18 x 1.5 to 1/8" plug and SS braided line.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 03-25-2015, 11:10 AM   #1806
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Random, should I spend $5k on the Jackson racer kit or $5k on improvements to my house that I just purchased 4 weeks ago? Hmmmmmmm. In terms of return on your investment it's a no brainer. House. In terms of pleasure the $5k would bring.. No brainer Jackson. While my goal was to buy a discounted used kit my wife did say that she wants free air miles and so a credit card is ideal for purchase. But then she will want a vacation out of it which means more $$. So that brings up another point. Live in the now or plan more for retitment. I could save all my life then due premature with all this money. These are the questions that haunt me each day. Fuck.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
