go_a_way1
Old 03-19-2015, 07:06 PM   #1779
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Originally Posted by Infamous Performance View Post
Had an uber odd issue with a JRSC kit equipped FRS yesterday...
Twice the car has come in with complaints of "rich" codes being triggered (CARB tune). I had already trapped the event happening at the onset of boost (transition from closed to open loop). I have seen this before and it can be as simple as rotating the MAF sensor housing.
Visit one: The car had the old silicone intake hose (instead of the new pipe). So first thing we did was clean the MAF and swap the tube for the pipe. Next we rotated the MAF (trying different positions). This helped some, and also made it worse depending on rotation. In the end the we were not pleased with the -20% fuel Long Term Learned fuel trim, but it was not throwing a code.
Visit 3: The reflash appeared successful. Until we revved it up. Then the fuel trims went haywire again and the car was uber rich (-35%).
Hey, it all sounds like my case! (minus the ECU communication issues and reflash)
So, after speaking with Oscar Sr and Jr we decided to remove all 4 aftermarket HID ballasts from the car. It worked. It would appear the RF interference from the DDM Tuning HID kits (4 of them) was causing corruption in the communication. The issue went away as soon as the HID's were disconnected.
This is really weird!
I do have HID lights, but they are stock, so probably shouldn't cause the same issue, or is there still a chance for that?
alpax is offline   Reply With Quote
Old 03-19-2015, 07:11 PM   #1780
alpax
alpax's Avatar
This is an interesting new detail for me. Can the MAF rotation make a big difference? Maybe I should try that? How do you do it? The sensor housing/connector is held with two screws, so there is no play there. Do you rotate the sensor itself?
Old 03-19-2015, 07:54 PM   #1781
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
OEM HID's won't cause the issue. MAF housing orientation can have a large affect though. The orientation of the MAF housing should be perfectly parallel to the ground. Meaning facing precisely straight up.
Sincerely,
Zach
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
alpax (03-19-2015), CSG Mike (03-19-2015), Jackson Racing (06-11-2015)
Old 03-19-2015, 10:40 PM   #1782
CSG Mike
CSG Mike's Avatar
Visit 2: At the car would no longer communicate. 4 different lap tops and cables, 3 different scanners and my Solus. Nothing would talk. We requested JR send over the CARB tune in a zipped file so we could verify no corruption in the map and re-flash with the newest version of EcuTeK software.
Visit 3: The reflash appeared successful. Until we revved it up. Then the fuel trims went haywire again and the car was uber rich (-35%). So, after speaking with Oscar Sr and Jr we decided to remove all 4 aftermarket HID ballasts from the car. It worked. It would appear the RF interference from the DDM Tuning HID kits (4 of them) was causing corruption in the communication. The issue went away as soon as the HID's were disconnected.
I am now waiting for some feedback from the customer. He was planning on swapping out the HID's for LED's. He will continue to monitor the fuel trims and report back.
For now, any owners who might be experiencing odd issues like this might want to check the install of their aftermarket HID's (if so equipped).
I've observed this on more than a few cars with low quality ballasts.
Infamous Performance (03-19-2015)
Old 03-19-2015, 10:41 PM   #1783
CSG Mike
CSG Mike's Avatar
The MAF should be pointed "straight up".
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
alpax (03-19-2015), Infamous Performance (03-19-2015)
Old 03-19-2015, 10:43 PM   #1784
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
You rotate the entire section of tube the MAF sensor is located on.
ScionOfHorus is offline   Reply With Quote
The Following 2 Users Say Thank You to ScionOfHorus For This Useful Post:
Old 03-19-2015, 10:50 PM   #1785
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
OEM units are "insulated/shielded" and do not emit RF interference like the aftermarket kits do. The OEM units are tested for this exact issue.
Infamous Performance is offline   Reply With Quote
The Following User Says Thank You to Infamous Performance For This Useful Post:
Old 03-19-2015, 10:52 PM   #1786
You rotate the entire length of tube that the MAF housing resides on. The MAF sensor should be flat/parallel to the ground for optimum accuracy.
The Following 2 Users Say Thank You to Infamous Performance For This Useful Post:
Old 03-19-2015, 10:57 PM   #1787
Almost 15 years of working on Subies. 5 of those years running this shop. First time I have seen aftermarket HID's cause this issue. I even have a set of DDM running my wifes fogs on her 08 LGT. No issues in 6+ years (although her HID head lamps are Denso/Phillips and not OEM).
Many, many of our customer use DDM Tuning HID kits. They are scary cheap and DDM is 2 exits down the road. Not saying the kits are anything special or even "good", but I had not seen this happen before.
You learn something new every day and thought sharing might help others.
We will have to meet up sometime sir. We are separated by far more traffic than miles. A meeting of the "Mikes".
Old 03-21-2015, 05:08 PM   #1788
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I thought I might ask if anyone is Crawford Billet Power Blocks with their JRSC kit?
Jmonty is offline   Reply With Quote
Old 03-21-2015, 05:09 PM   #1789
ScionOfHorus
From what I've read, they're not anywhere near as effective when you have FI.
The Following User Says Thank You to ScionOfHorus For This Useful Post:
Jmonty (03-21-2015)
Old 03-21-2015, 05:19 PM   #1790
Jmonty
Same as what I have been reading just didn't see any testing to prove it?
Old 03-21-2015, 05:20 PM   #1791
ScionOfHorus
Has to do with runner length not being really relevant with the amount of air being forced through.
Jmonty (03-21-2015)
Old 03-21-2015, 07:43 PM   #1792
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Well since Im buying @*LongFella 's JRSC'd FRS I went thru and read the full 82 pages of this thread. Definitely learned a a lot and prevented a fair amount of Noob questions I would have ended up having. Looking forward to getting this ride and bringing it up North. Hwy 1 will be a fun drive from SoCal up here to the Bay Area.
0351USMC is offline   Reply With Quote
The Following 3 Users Say Thank You to 0351USMC For This Useful Post:
*LongFella (03-21-2015), CSG Mike (03-23-2015), ScionOfHorus (03-21-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
