| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 | |
Drives: 2019 Mazda Miata RF
#44 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
I am going to end up getting a Steelie. Hopefully this solution will work. Then when I want to use my sunshade, etc. I can easily remove my radar detector from the window.
#45 |
Drives: Series 10 FRS
I have used clear packing tape over the black sunscreen dots to make the area smoother...
#46 |
Thanks again for this DIY just "hardwired" in my escort passport and it works like a dream. Only took 30 minutes mostly because the stupid airbag cover had a hard time going back into place. Also rather than tucking in the cable through the gap near the glove box its way easier to pop open that side kick panel and just close the cable over it.
Sent from my A0001 using Tapatalk
#47 |
Drives: 2013 Scion FRS Asphalt
So after days of being away from my car I decided that I would try this DIY. I own a valentine V1 and went to target to pick up a phone cord that was long enough to run from the glove box to my desired location. Long story short my V1 won't turn on any more. Both the center consol and the glove box electrical ports fail to start the radar. Tried my original cable to see if that was the issue and still no success. Any ideas y'all?
Hook Em'
#48 | |
Drives: Toyota GT86
#49 |
What could have caused the blown fuse? Was it the new phone cord or just by random chance. Id hate to swap out the fuse and plus the V1 back in to the new phone cord and have it blow again. And thanks for the help!
Hook Em'
#50 |
Drives: Toyota GT86
My fuse just popped randomly from powering on I believe. Maybe a power surge can cause this, I'm not sure. I thought my Valentine 1 was shot initially, but then I checked the fuse and it was blown. Pull out the fuse and check to see if it is blown. The wire will be broken inside the fuse if this is the case. The fuse is located in the power plug adapter. My V1 has been running strong for approx. 10 years.
#51 |
Drives: FR-S 10 #103 AT
You need to be careful with phone cables. They're reversed end to end by the standards, but they work for most phones even when they aren't. Sometimes they're wrong in the package, which could account for your problem.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#52 |
I didn't even know there was a lighter plug in the glove box WUT! Thanks for this.
Sent from my SM-G920P using Tapatalk |
| The Following User Says Thank You to p1l0t For This Useful Post: | soulreapersteve (03-27-2017) |
#53 | |
Contract? /人◕ ‿‿ ◕人\
Also ![]() lol |
| The Following User Says Thank You to soulreapersteve For This Useful Post: | p1l0t (03-27-2017) |
| Radar | L3P47 | Electronics | Audio | NAV | Infotainment | 31 | 05-15-2013 12:53 PM |
| radar detectors | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 02-24-2013 02:27 PM |
| Radar Detectors | swag | BRZ First-Gen (2012+) — General Topics | 28 | 01-31-2013 04:58 PM |
| Next mod: Radar dector | jwbrocloud | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 01-27-2013 01:04 PM |
| Has anyone done a good concealed Valentine One install? | sikest | Electronics | Audio | NAV | Infotainment | 3 | 01-22-2013 06:37 PM |
