Old 05-18-2012, 12:51 PM   #85
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
Rpm - Mph
Yesterday I had the opportunity to play with cruising speeds a bit. The following photos were taken at the 55, 60 and 70 MPH. The process used was:
Relatively flat road as seen through a GPS elevation (it changed only a few feet over the distance).
Car was at this speed with a stable RPM and MPG reading for at least 30 seconds before the picture was taken.
Cruise control used to hold speed.
The readings were easily reproducible on my 6AT.
Yeah I am closer to 3k range @ 70mph w/ 6spd manual if I remember correctly. Go Auto for Taller gear = better mpg!
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
The Following User Says Thank You to MarkRacerX For This Useful Post:
Dadhawk (05-18-2012)
Old 05-18-2012, 01:09 PM   #86
serialk11r
Drives: '06 AM V8V Coupe
That's interesting, the 70mph fuel economy is really shitty...in fact, I have a hard time wrapping my head around such a huge drop from 55 to 60. Pekingduck said he was getting 39mpg at 70 in the manual transmission!
48-49 sounds about right for 55 considering the gearing, but 60 and 70 are just completely off. Given the expected load increase and considering the increased efficiency due to increased load, 60 shouldn't be that low. Just punching in 48/(12/11)^3 (aka, zero rolling resistance and constant engine efficiency) gives 37.
Makes me wonder if there's something wrong with your car!
The Following User Says Thank You to serialk11r For This Useful Post:
Old 05-18-2012, 01:14 PM   #87
Originally Posted by Spd229 View Post
huh.....maybe i'll have to get over my whole "can't drive 55" problem. lol.
I'm second guessing the 55 shot, honestly. I'm wondering if I was in a slight incline or something. One thing I did notice is the MPG can vary widely at the same RPM even tough speed isn't changing if you are going up/down a small incline. I'll try that one again if I get a chance. It did hold there for at least 30 seconds though, and the road was relatively flat.
Old 05-18-2012, 01:42 PM   #88
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
On my Lexus IS 250 which has essentially the same auto, 6th gear usually comes in at 55 mph so I'm not surprised by that mileage.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
Old 05-18-2012, 02:02 PM   #89
Could just be the method I used to measure it too. Not exactly scientific and kind of hard to focus on all this to make sure its exactly right.
Old 05-18-2012, 04:05 PM   #90
serialk11r
Yea, could've been a slight slope or something like that, but those numbers are still really weird. The only one that seems about right is the 55mph reading, on a completely flat road. I feel like 60-65mph shouldn't be causing that big of a drop overall, maybe like low 40s mpg. If Pekingduck's reports are correct, I'd predict ~42 mpg trip average going about 70, locked in 6th gear of course.
Old 05-18-2012, 04:34 PM   #91
Allch Chcar
Drives: N/A
That's actually not too unrealistic, Cereal, but I'd like to hope that something was off at 60 and 70mph. Possibly timing retard under load?
Dadhawk, what's the earliest it shifts into OD? I have a feeling it'll hit 50+MPG if you could get it into 6th at 35mph or even 45mph.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 05-18-2012, 04:48 PM   #92
serialk11r
Yea I think either he hit a slight incline without noticing or there is something wrong, maybe timing retard (which would be scary, because the load levels are still pretty low). Why did you ask about when it shifts into OD Allch Chcar? rofl, just put it into manual mode, slip it into 6th gear. At 35mph the engine would be turning a little over 1000rpm which is not going to stall, if the transmission doesn't let you do that, the person who did the programming needs to be shot. Although on that note, 1000rpm on the manual transmission's 6th gear is like, 23mph???
Anyhow, it seems a bit unlikely that they would intentionally design the engine to start retarding spark timing this early and then intentionally giving it these tall gears which would cause a significant drop in efficiency...if that's the case though, then maybe this is a good reason to start looking into E85 conversion? The Cobb dyno run showed it running rather rich, maybe the high compression ratio combined with suboptimal fuel is limiting the power...perhaps E85 can allow aggressive spark timing and closer to stoichiometric AFR.
And Dadhawk, thanks again for providing the community with some info
Old 05-18-2012, 04:48 PM   #93
I'm going to try and duplicate this again this weekend on a different road just for verification.
Old 05-18-2012, 05:07 PM   #94
MTeator
First 86
don't forget wind... a 5mph headwind at 55mph means you've got the 60mph wind resistance.
I do wish 5th and 6th were taller in the MT. At 70mph I'm doing 3,000 rpm. Still, even if the computer is off a bit I'm averaging 27mpg since pickup yesterday.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-18-2012, 05:33 PM   #95
Allch Chcar
Drives: N/A
I didn't ask that because I'm not driving it and I can't just ask him to drive 35mph and put it into 6th and set the cruise control. I don't know how it will act and I do not want to make Dadhawk uncomfortable. Plus it would make me responsible.
I wouldn't assume it's retarding timing without actually looking at the ECU readouts, it's just a thought since the MPG doesn't seem to correlate with the increased load. It could be entering enchrichment too, though I doubt it. Then again, I don't program ECUs. I do know that ATs operate at higher loads than MTs.
And yes, Cereal. I am still thinking about E85 conversions but I'm trying to keep it low key while I'm just doing research. There is another E85 guy here that I am kind of competing with. I don't want to lose.
-Allch Chcar
Old 05-18-2012, 05:54 PM   #96
Its possible although they were all on the same stretch of road within a few minutes of each other, heading due West the entire time.
Old 05-18-2012, 05:59 PM   #97
Honestly, I don't know. When you're in "D" and standard shift mode, the shifting is so smooth in the higher gears I don't even notice it. Obviously, I could do it manually or just need to pay closer attention. I'll do that if I rerun the test this weekend. I'd also be interested in what others are seeing so we can get a baseline. I suspect each car will be slightly different.
Old 05-18-2012, 10:25 PM   #98
Allch Chcar
Drives: N/A
Heh, I understand. Thanks for sharing with us!
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
Dadhawk (05-19-2012)
dadhawk, first86
