Old 03-14-2015, 06:18 PM   #1
tazz786
Drives: 2015 scion FR-S
Question Camber after alignment
Just got new tires and wheels installed as well as added Eibach pro kit to my firestorm FRS..nothing else had been done as far as camber/crash bolts ...After i got the alignment i noticed that the left rear camber says -2.0 and the right rear says -2.3 on this set up. Shouldnt the rear camber be the exact same? Is this something i should be worried about?
Tires i installed were 245 35 18 all around..wheels are XXR 527'S with 35 offset all around..also 10mm spacers in the rear both sides.
tazz786 is offline   Reply With Quote
Old 03-14-2015, 06:23 PM   #2
Porcupint
Drives: 13 GBS BRZ
Camber is not the same in the rear from the factory. If I recall, mine was about .3 degrees off as well from driver to passenger side.
If you want to even it out, you're going to need rear lower control arms.
Porcupint is offline   Reply With Quote
The Following User Says Thank You to Porcupint For This Useful Post:
tazz786 (03-14-2015)
Old 03-14-2015, 06:33 PM   #3
tazz786
Hmm I suppose if it came like that from factory there shouldn't be too much to worry about then.. Thanks much!
Old 03-14-2015, 06:45 PM   #4
Koa
false... factory alignments have historically been sporadic and a proper alignment will have that camber dialed in.
What needs to happen is a competent mechanic must play with the subframe to get rid of the cross slop. This requires patience and care... not all technicians care at all where your numbers end up if you don't hammer home your alignment specs at least to the counter guy, and even better still if you can meet the person doing the alignment. Make it personal to them. If they know you're expecting a certain performance and setup, they'll be less inclined to just throw it on the rack, dial out the toe, and call it a day.
The Following 4 Users Say Thank You to Koa For This Useful Post:
8R6 (04-02-2015), Caspeed (04-15-2015), Porcupint (03-14-2015), tazz786 (03-14-2015)
Old 03-14-2015, 07:34 PM   #5
Porcupint
Drives: 13 GBS BRZ
And this is why I've found one guy who takes pride in his alignment jobs and I continue to go to him. He doesn't do "good enough" he does perfect.
This was the last alignment job we got done. Front was what really mattered but wanted 0 camber in the rear and a little toe in.
Old 03-15-2015, 03:55 AM   #6
ka-t_240
How did you get to 0 camber in the rear, and why?
ka-t_240 is offline   Reply With Quote
Old 03-15-2015, 12:51 PM   #7
Porcupint
Drives: 13 GBS BRZ
Control arms and because drift car. That's on a crazy "240" though. Not a twin.
Old 03-29-2015, 04:11 AM   #8
Alexandr_Rychok
Alexandr_Rychok's Avatar
Drives: Subaru BRZ, Chevrolet Camaro
I think, that is not present.
Alexandr_Rychok is offline   Reply With Quote
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 10:37 AM
Alignment and Camber questions for Dummys(me) KonTheory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 09-19-2014 09:41 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-26-2013 12:39 AM
