| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2015 scion FR-S
Just got new tires and wheels installed as well as added Eibach pro kit to my firestorm FRS..nothing else had been done as far as camber/crash bolts ...After i got the alignment i noticed that the left rear camber says -2.0 and the right rear says -2.3 on this set up. Shouldnt the rear camber be the exact same? Is this something i should be worried about?
Tires i installed were 245 35 18 all around..wheels are XXR 527'S with 35 offset all around..also 10mm spacers in the rear both sides. |
#2 | |
Drives: 13 GBS BRZ
If you want to even it out, you're going to need rear lower control arms. |
| The Following User Says Thank You to Porcupint For This Useful Post: | tazz786 (03-14-2015) |
#3 | |
Hmm I suppose if it came like that from factory there shouldn't be too much to worry about then.. Thanks much! |
#4 | |
What needs to happen is a competent mechanic must play with the subframe to get rid of the cross slop. This requires patience and care... not all technicians care at all where your numbers end up if you don't hammer home your alignment specs at least to the counter guy, and even better still if you can meet the person doing the alignment. Make it personal to them. If they know you're expecting a certain performance and setup, they'll be less inclined to just throw it on the rack, dial out the toe, and call it a day. |
#5 | |
Drives: 13 GBS BRZ
This was the last alignment job we got done. Front was what really mattered but wanted 0 camber in the rear and a little toe in.
#6 |
How did you get to 0 camber in the rear, and why?
#7 |
Drives: 13 GBS BRZ
#8 |
Drives: Subaru BRZ, Chevrolet Camaro
Camber after alignment
I think, that is not present.
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| Does toe affect camber in the rear? More camber on one side after alignment | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-30-2014 09:37 AM |
| Alignment and Camber questions for Dummys(me) | KonTheory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 09-19-2014 08:41 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Rear Camber/Alignment Question | anewprelusion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-25-2013 11:39 PM |
