Old 03-12-2015, 06:23 PM   #1877
wheelhaus
wheelhaus's Avatar
I find the PvP difference is based on a few factors that are employed by good players.
First, the ability to adapt as MokSpeed mentioned. This translates to very high situational awareness and quick changes to tactics. Each enemy in PvP is unique, they move differently and have different strengths and weaknesses. Find ways to adapt and exploit them. You need to be able to assess each enemy in any area of the map, where your teammates currently are and what the goal is at the moment. Being on an actual team with voice chat is huge, we've had the entire team instantly switch goals because one person saw something away from the group.
Secondly, mobility. Its hard to hit a moving object. If you can maintain momentum and change direction quickly, you will simply be harder to hit with any weapon. I have changed all my builds to high agility with secondary emphasis on recovery, because it works in PvP and PvE. Get accustomed to snapping your aim to targets very quickly while moving.
Thirdly, map knowledge. The maps are mostly small and easy to memorize. Map knowkedge will help you learn common routes between key points, sniper spots, etc. You'll know where to aim as you round a corner without having to think about it. It will also help your defense immensely, if you know where things are you can duck behind cover without having to look for it first. Radar usage is a huge part of this, keep one eye on the reticle and one eye on the radar, and get to know the maps.
Fourth, good builds. This goes for both PvE and PvP, but using complimentary gear is a pretty big bonus. One of the most effective I can think of right now is Bad Juju and Obsidian Mind for a voidwalker Warlock for more supers. Another is No Backup Plans and Monte Carlo (sorry XB1) for defender Titan for more force barrier. Using a gun you're handy with is a good idea, but learn to use all weapon classes effectively. This is not only more fun, but helps your aim to develop to get those tasty crits.
The Following User Says Thank You to wheelhaus For This Useful Post:
53Driver (03-13-2015)
Old 03-12-2015, 06:46 PM   #1878
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Map knowledge is where most people struggle, myself included.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
Old 03-13-2015, 10:03 AM   #1879
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
I agree, I don't play PvP enough to know the maps well. Back when I grinded IB for a week, it was the first and only time where I saw my skill improved in PvP and most of that was I learned the maps. Now, I just run around like a chicken with my head cut off. I'm not even sure if I've played on all the maps since they added new ones with TDB.
wheelhaus makes good points about building your character to fit the tactics. I'm also horrible about this when it comes to PvP, usually I just jump in and play without making too many adjustments.
On another note, did anyone pick up Red Death from Xur this morning? I'm not a big pulse rifle guy, but people seem to really like this one so I picked it up.
53Driver is offline   Reply With Quote
Old 03-13-2015, 10:19 AM   #1880
f0rge
I grabbed it since I didnt have it and pulse rifles are supposed to be the new thing. The regaining health perk is also incredibly useful for Crota HM.
Too bad I have 4 primaries I need to level before this one.
Old 03-13-2015, 10:35 AM   #1881
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Ended up with full legendary/exotic armor for a Titan, so decided to delete my 2nd warlock. Let's see if I can get him to 30 before the reset and a 4th chance at shards I don't need from the nightfall...
Old 03-13-2015, 10:36 AM   #1882
53Driver
53Driver's Avatar
Yeah, I've picked up 3 new primaries in the last 2 weeks now so I need to start getting back on every day and running some bounties I guess. I also had heard about that perk being very valuable for CE HM so guess it was good I picked it up. What time were you wanting to Raid this weekend?
Old 03-13-2015, 11:08 AM   #1883
n2oinferno
Praise Helix!
n2oinferno's Avatar
Red Death is a 2hko in Crucible. That's why everyone wants it. I'm getting one, plan on maxing it out and using it, maybe in IB next week if I can grind it out quickly. And if I want to switch to a secondary or heavy exotic I'll go with 3LW.
Old 03-13-2015, 11:22 AM   #1884
f0rge
Right now I have 6 primaries I need to level but that's just never going to happen. Focusing on Fang of Ir Yut first then I'm not sure, either Vex or Red Death I guess. I also need to start getting back on every day to run at least a few bounties, not that I even need to level these guns...
This weekend is bad for me, probably working most of it. Thatswutsup said Sunday which is probably the only day that'll work for me.
Old 03-13-2015, 11:41 AM   #1885
53Driver
53Driver's Avatar
Man that sucks. No big deal about Sunday, I'll try to get on later that day at some point. If you want to run a few bounties tonight, I'll run them with you. Need to run my alternate Titan through that first part of Crota to get shards and see if I can pick up the gauntlets.
Old 03-13-2015, 12:25 PM   #1886
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
So what weapon types are currently the ones to "use" in Crucible?
Based on the average player in Crucible, the best gun types as of now are pulse rifles, shotguns, and snipers.
Snipers have yet to be patched and I see no reason why they should be at all. Skilled guns for skilled kills.
With the adjustment of Auto Rifles it is apparent now that pulse rifles reign supreme. Scout rifles remain highly competitive, however, they simply cannot compete with the rate of fire on the pulse rifle's bursts.
Shotguns did not receive much of a buff, but the reason they are so deadly now is because of the adjustments they have made to fusion rifles. Fusion rifle shots have been adjusted to contain a much more drastic bloom effect lowering their effective range to nearly the equivalent of a shotgun. Because of this, shotguns absolutely dominate now since they require no charge time.
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
Old 03-13-2015, 12:35 PM   #1887
f0rge
Exotic pistols are still worth using too, TLW, Thorn and Hawkmoon are still wrecking the joint.
Old 03-13-2015, 12:39 PM   #1888
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Primarily Thorn!
I'm just glad I don't have to deal with Hawkmoon on XB1.
Was it patched before or after iron banner? Cuz I was wrecking everyone with it in IB.
Patch was after IB. The shotgun from IB has disgusting range.
Old 03-13-2015, 01:00 PM   #1889
53Driver
53Driver's Avatar
Primarily Thorn!
What are your thoughts on running Universal Remote with another shotgun as a secondary? Pointless or an evil combination?
Old 03-13-2015, 01:42 PM   #1890
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
It depends on your play style and the map. If you're the run n' gun, up close and personal type then I say go for it. It just saves you from having to reload your gun and you can simply switch to another shotgun.
Personally I'd never run anything other than a hand cannon or a rifle for my primary (Vex was basically an auto rifle prior to patch), but that's just my play style.
NorCal86 Facebook Groups finch1750 Northern California 41 01-08-2024 02:58 PM
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
El Monte Car meet raid by polices- 115 citiations given Speed2th Southern California 5 07-18-2014 03:22 AM
Gundam Universe - General All Discussion Thread poormans_LFA Off-Topic Lounge [WARNING: NO POLITICS] 273 03-24-2014 12:45 AM
Any groups in the Stockton Area? MidLife&luvIt Northern California 73 06-09-2013 07:14 PM
