Old 03-12-2015, 11:04 PM   #29
Tmann405
Drives: 15 BRZ
Originally Posted by Kiske View Post
Do you still have the secondary cat? Mine ticked while I had mine.
I have a cat on the front pipe.
Tmann405 is offline   Reply With Quote
Old 03-12-2015, 11:26 PM   #30
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I have catless UEL headers and no turbo and I do smell odor. Odor is most profound if I don't let the car warp up and when I really get on it. I would compare "getting on it" to running boost because both are demanding more . jmust make sure your not mistaking the odor to that of running a catless header. I feel like you should be able to identify an exhaust leak with a review of your fuel trims. Have you all looked at them?
No clue what this ticking sound could be.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-13-2015, 03:10 AM   #31
kensta
kensta's Avatar
As for me, I am running no cat. I have a 2.5" ISIS over pipe, 2.75" J2 front pipe, and 3" Perrin non-resonated catback exhaust.
I mainly hear the ticking noise when I apply medium to hard pressure on the gas while driving. I do not hear it when I gently or slightly tap on it or cruising. It's hard to observe the ticking when the car is parked while revving the motor up, you'd to be driving make it more noticeable. I may have to look underneath around the area again for black carbon build up since I did not see anything last time.
Sorry, I don't wanna thread jack anybody. Hoping if anyone else have this same issue.
kensta is offline   Reply With Quote
Old 03-13-2015, 09:07 AM   #32
Tmann405
Drives: 15 BRZ
That's exactly what I have. Under hard acceleration is when I hear it.
Old 03-14-2015, 03:34 AM   #33
kensta
kensta's Avatar
Hey buddy,
Good news! I fixed my ticking noise. It was the flex joints on the exhaust manifold. Today, I decided to change my oil and observe the exhaust manifold area and thought I should try wrapping up those two flex joints. I wrapped them up with some DEI exhaust/header wrap between the two welded area of the flex joints and wire tied them. I'm so happy to fix this!! Been two months and brought to shops that would charge ridiculous to remove and try to fix the problem. Most of them think it's the turbo or mechanical related smh.
This is surely a defect. I have the turbo kit installed for two months. Ever since I started the car up from day one of the install, the ticking was present.
I'm not sure if any SBD owners has the same issue or have posted in the SBD forums.
The Following 3 Users Say Thank You to kensta For This Useful Post:
Boofneenee (03-14-2015), jarednoel (03-18-2015), wooly35 (03-16-2015)
Old 03-14-2015, 02:14 PM   #34
kensta
kensta's Avatar
Here are pics of the before and after wrapping the flex joints. The first two pics, I only took a shot of one of the joints because I wasn't really focusing on getting both, but more at the runner part. I thought the two runners on the right were rubbing each other to make that ticking noise but not the case.
Note that there's some yellowish part on the flex. I used black exhaust wrapping. If I used the white wrap that came with the kit, but I already wrapped over the down pipe, I can probably see black carbon on the leaked area more easily.
Since I am not sure which of the two flex joints are leaking, I probably have to remove one of the wraps of the two to determine which one is the culprit. Hoping that both aren't bad.
Old 03-14-2015, 02:37 PM   #35
Tmann405
Drives: 15 BRZ
Sweet man, I'm glad you got it fixed. I just got some exhaust wrap and I will be wrapping mine as well.
Do you think that they are leaking? Or do you think that they are vibrating or something?
Old 03-14-2015, 03:27 PM   #36
kensta
kensta's Avatar
Not 100% positive on leaking. I wrapped it but it doesn't guarantee the leak is gone if there is one, just temporarily aid in quieting down the vibration of the metals. Fumes would still go through I would assume. I have to test the car out more for a day or two had to rush to work today..
Let me know if that works for you.
The Following User Says Thank You to kensta For This Useful Post:
Tmann405 (03-15-2015)
Old 03-15-2015, 07:45 PM   #37
Tmann405
Drives: 15 BRZ
Hey man, so I got under there and wrapped the joints and like you said I'll have to give it a few days, but it definitely muffled the tick at the least. I did see some weird spots on the joints that looked like burn marks.
Overall I'm satisfied with the wrapping, thanks for sharing!!!!!!
Old 03-15-2015, 07:52 PM   #38
raven1231
Other than ticking how's the kit ?
Old 03-15-2015, 08:42 PM   #39
Tmann405
Drives: 15 BRZ
I like it a lot, especially with my tomei exhaust it sounds amazing, its a full 3 inch from the over pipe back. I also have the AVO clutch which I love!!!
The Following User Says Thank You to Tmann405 For This Useful Post:
raven1231 (03-15-2015)
Old 03-16-2015, 07:50 AM   #40
wooly35
Drives: 2014 Scion FR-S LS3
sweet deal. I just installed the kit this weekend and have had similar problems with the fitment and exhaust leak. I will try the exhaust wrap on the flex joint and see if that takes the ticking away.
wooly35 is offline   Reply With Quote
Old 03-16-2015, 02:33 PM   #41
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Problem is wrapping the headers especially the flex joints will contributed prematurely to them cracking. They are too brand new for them to be doing what they are doing. Where is @spdbydesign ? No comment?
FRS
The Following 2 Users Say Thank You to Boofneenee For This Useful Post:
raven1231 (03-16-2015), Tmann405 (03-16-2015)
Old 03-16-2015, 03:05 PM   #42
raven1231
This is what bothers me....There has been zero input on their part.
BorgWarner EFR / JDL turbo install!!! Infamous Performance Forced Induction 89 01-22-2015 12:38 AM
I'm thinking about going Motec for my turbo install... diss7 Forced Induction 29 07-16-2014 04:21 AM
Fumes coming out from the vent? Moss Scion FR-S / Toyota 86 GT86 General Forum 22 10-11-2013 01:31 PM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 01:56 AM
Shop in TN or MS to install and tune turbo brocktwalker Southeast 2 03-16-2013 10:58 AM
