Old 03-09-2015, 05:14 PM   #1429
conedodging
conedodging's Avatar
Drives: '14 BRZ
Originally Posted by piknockout View Post
Going to start putting the parts on the car either this weekend or next weekend. Going to be running the KW V3's and was curious where everyone is setting their ride height. Specifically, I want to get a good initial height on the car. Can anyone get measurements of the distance from the bottom of the threads to the collar for the front and rear? Would prefer to make small tweaks than massive changes when I first drop it to the ground.
Also if anyone has a center of hub to bottom of fender measurement, that would be great too.
I can get you my hub-fender measurements after work. They should be roughly what last year's national championship car was running, given I didn't touch the coilovers before putting them on.
conedodging is offline   Reply With Quote
The Following User Says Thank You to conedodging For This Useful Post:
piknockout (03-09-2015)
Old 03-09-2015, 06:43 PM   #1430
Kostamojen
Originally Posted by MTCRX View Post
The backdate/update issue doesn't cross from special edition cars to stock cars.
The base cars have them now as mentioned.
Old 03-09-2015, 07:13 PM   #1431
conedodging
Drives: '14 BRZ
Originally Posted by Kostamojen View Post
Those qualify under the "backdate/update" rule. If an identicle model from a later year has something, you can use it on the previous year.
To be clear there is no update/backdate rule in ST. What you're referring to only applies to bodywork in 14.2.F.
Addition of spoilers, splitters, rear wings, bumper covers, valances, side skirts and non-functional scoops/vents is allowed provided either:
1. It is a production part which is standard or optional equipment of a US model of the vehicle ("Model" is defined in Section 12.3)
Which covers far far less than the actual update/backdate rule that appears in SP. Honestly I'm not even sure it covers under-body panels.
The Following 2 Users Say Thank You to conedodging For This Useful Post:
Scooby South (03-10-2015), Thorpedo (03-09-2015)
Old 03-09-2015, 09:41 PM   #1432
conedodging
Drives: '14 BRZ
Quick Measurement: (hub-fender)
12.25" Front
13.0" Rear
I think maybe my rear could go down a bit. Quarter inch or so. Keep in mind this is un-corner balanced right now.
Old 03-09-2015, 10:50 PM   #1433
Kostamojen
Under the provisions of Section 1.1 of these rules, SCCA® Regions are free to allow any other version of the Street Touring® concept which meets the local needs. In particular, some leeway in the area of bodywork allowances
(e.g., wings/spoilers beyond those allowed in Section 14.2.F) is encouraged at SCCA® Regional Solo® events.
Old 03-10-2015, 01:36 AM   #1434
conedodging
Drives: '14 BRZ
And? Then it becomes a question of what the region allows, not what the rules say. That will be different for each region.
Old 03-10-2015, 03:16 AM   #1435
Kostamojen
Its the "don't be a ****" rule.
Would anyone in their right mind boot someone out of class because they added a trunk liner to a trunk-liner-less C-stock FRS, or switched to the sharkfin antenna from a 2015 on a FSP BRZ, or added the underbody panels to a STX class twin?
NO, unless you were doing it to be an ass. Its not a firm rule for a reason.
Old 03-10-2015, 09:48 AM   #1436
piknockout
Drives: 2014 BRZ
12.25" Front
13.0" Rear
Thanks! Very helpful. I guess I'll intall them where they came out of the box and then adjust accordingly.
piknockout is offline   Reply With Quote
The Following User Says Thank You to piknockout For This Useful Post:
conedodging (03-10-2015)
Old 03-10-2015, 12:13 PM   #1437
RTR
Drives: monogram raven
Ok, so we have a CAT in the stock header. Since you have to have a CAT, does that one count? In other words can I use a catless front pipe as long as the header is stock? That's where I get confused.
RTR is offline   Reply With Quote
Old 03-10-2015, 12:27 PM   #1438
conedodging
Drives: '14 BRZ
Yeah, you only need to retain one cat. Even that doesn't have to be stock, it can be a high-flow replacement (specs are in the rulebook). So you could go with a catless front pipe and a non-stock, but catted, header if you wanted to.
Old 03-10-2015, 12:28 PM   #1439
RTR
Thanks
Old 03-13-2015, 12:26 PM   #1440
justint5387
Drives: 4 wheels
Is an aftermarket cam seal plate legal?
justint5387 is offline   Reply With Quote
The Following User Says Thank You to justint5387 For This Useful Post:
tigermack (03-13-2015)
Old 03-13-2015, 03:22 PM   #1441
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
In my personal opinion, you could try to "sell it" or legally have it as an engine dress up item as it does not offer any performance benefit.
2superblus is offline   Reply With Quote
Old 03-13-2015, 04:10 PM   #1442
cjd
cjd's Avatar
Drives: 2017 BRZ
It's the kind of thing that might get a protest at nationals if it's that kind of week for someone, but would probably not even warrant a second look locally. I have no idea if a protest would be upheld. Rumor is a rotary was once town down because of an aftermarket cam sticker in a stock class...
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
