Drives: 2013 Hyundai Genesis Coupe
Which Speakers for Upgrade
Now I have used search and dabbled in some of the other threads but car audio seems to be a black art to me.
I want to upgrade the car speakers both in the dash and in the doors. I have a premium infinity audio system In my genesis. There are 10 speakers and a deck mounted 8" sub and the sound quality is very good. Maybe even excellent but I haven't heard many other systems so I am sure there are better out there. Mainly I listen to jazz music and classical music with a lot of instrumentation. I want maximum clarify of sound above bass or being able to feel the car shake. The thing is most people seem to want a "powerful" audio system but what I am looking for is crisp sound over power. I know the stock speakers can only do 2 ohms. i know that 4 is better but not sure why. I know its best to replace the stock amplifier asap to improve sound quality but don't really understand why that makes a difference either. But my main question is how much do I have to spend to get and equivalent or better audio system than what is in my genesis currently. I definitely want to do door and dash speakers but do I have to do rears? and how much should a "good" amp run me for what I am looking to do? I am looking for ball park price quotes as well as a general idea of the different components I will need to purchase to make it possible. And what I could possibly omit like maybe rear speakers. for now lets just assume i will use stock head unit. Though I hope to get a pioneer next deck sometime soon. |
#2 |
Drives: FRS
Do you want an easy solution? If yes check out oem+. You're going to spend about 1k but you can easily spend the same and more going other routes. Sounds like a good fit for your description.
| The Following User Says Thank You to Chimera For This Useful Post: | shiro (03-30-2015) |
#3 |
What would some good aftermarket companies be?
#4 | |
Drives: 15' MT FRS
Via Note 4 using Tapatalk. |
#5 | |
Drives: FRS
OEM+ is an aftermarket company even if there name would suggest otherwise.
they are a vendor here, I'm sure one of them can speak better to it than I can. If you want to go custom I recommend starting on the how to use the OEM amp harness thread, lots of good info there. theres a sticky directory of threads with good info at the top of the Electronics | Audio | NAV | Infotainment section
#6 | |
Your advice is kinda backwards. OEM+ charges a premium for it to be plug and play. For the money, the biggest value would be to upgrade the door speakers, tweeters up on the dash, and amp in the rear. Couple this with a good subwoofer, and you have a setup that blows the doors off of the OEM+ rig for half the price. Ask me how I know. I just was over at @Integrity Concepts donating my 86 for them to make a 12" box offering The only thing OEM+ truly has a competitive advantage in is their DSP- signal processor that is mapped to the car's sonic platform. That is truly something worth buying- here's the caveat, though... it's only sold with their premium package. So you buy everything else just for the dsp. |
| The Following User Says Thank You to Koa For This Useful Post: | Integrity Concepts (04-21-2015) |
#7 | |
Drives: FRS
As far as price, you can build cheaper systems, but one a sub, box (corner loaded specifically, other standard boxes are cheaper), amp, and amp kit your looking at about 450+ without doing anything about any of the other speakers. that's all I was saying. Koa's right though, if your willing to learn more, you can very likely do more on a smaller/similar budget.
#8 |
Drives: FRS
I guess for perspective though, I am running this currently:
Infinity Reference series 6.5coax, 3.5coax, and tweeter (I'm to lazy to lookup model numbers, but you can find them easily) on audio pipe 3way crossovers (crx-303 I think) and infinity ref 4coax in the rear, all off an alpine ktp-445u wired for 4ch rear and front. Additionally, I have a wxv2 powered at 175w in a standard box. I'd like to upgrade to some corner load boxes, but money...
#9 | |
(double negatives booosh)I'm running similar to you, Infinity Kappas 62.11s and some tweeters I had lying around through a ktp-445u wired up back... a 12W6v2 sub and 500/1 monoblock for boom.. ![]() I got the sub & box for 180, kappas for 80 new, the ktp for 90, the 500/1 monoblock for 300 after in-store credit for some boxes I traded.. I dare an OEM+ system to sound x2 better as at current they're 2x the price of my setup for far less sonic performance |
#10 |
Drives: 2019 BMW ///M4
I would start with sound insulation on the doors... change the settings to feel with Max Bass and ASL to Low.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| The Following 3 Users Say Thank You to N1rve For This Useful Post: |
#11 |
I just about finished my stereo install... so far I love it.
Doors and Dash: Precision Power PPI P65C3, these are 3 way components with a passive crossover and sounds amazing. The reason why I chose the 3 way is so that I can retain and use all the available speaker locations, but have 6 speakers only using 2 channels. I did bypass all the stock wiring and ran my own. Rears: JBL GTO429, these are 4" speakers and require some modification to get them to fit the rears. These are ran off my remaining 2 channels on my amp. Speaker Amp: Rockford Fosgate P400X4 Sub: Kicker Comp VX10 Sub Amp: Rockford Fosgate 600.1db Capacitor: Rockford Fosgate 1 farad I am currently running these off a cheap car headunit I was using for my garage stereo, but my Pioneer 4100NEX is currently on it's way to my house. The install was a pain in the ass but worth it. I used great stuff foam (2 cans) in each rear wheel well and then poly fill the remaining dead space (Don't tell my wife, we are missing 2 pillows). The sound deadening difference is phenomenally more quiet. I know people will boo hoo the great stuff, but it worked. |
| The Following User Says Thank You to bigdawg86 For This Useful Post: | Simplicity (03-14-2015) |
#12 | |
Drives: WRB BRZ
#13 |
The tweeter was the only thing that I mounted in a spot that was same location as stock, but flush mounted. |
#14 | |
| I'm looking to upgrade speakers | 86geek | Electronics | Audio | NAV | Infotainment | 32 | 03-13-2015 06:22 PM |
| Door speakers upgrade / replacement | mike_ekim1024 | DIY (Do-It-Yourself) Guides | 13 | 02-17-2015 07:29 PM |
| Door speakers don't work after HU upgrade | BigJyoungblood | Electronics | Audio | NAV | Infotainment | 18 | 05-30-2013 11:46 PM |
| Dash Top Speakers / Rear seat speakers | Laurie | Electronics | Audio | NAV | Infotainment | 9 | 03-01-2013 06:31 PM |
| Thoughts on the BRZ radio/gps/speakers - Should we upgrade? | dorkymork | Electronics | Audio | NAV | Infotainment | 21 | 01-30-2013 11:04 AM |
