Old 03-06-2015, 09:09 PM   #3109
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
@SPCorBUST it sucks for us, but it appears as though KW will not be delivering on their promise of a CARB approved tune. They've been silent on the topic for a very long time...
mit_peid is offline   Reply With Quote
Old 03-06-2015, 09:19 PM   #3110
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Even though CARB doesn't effect me I do believe you guys are right.
Freeman is offline   Reply With Quote
Old 03-06-2015, 09:51 PM   #3111
SPCorBUST
SPCorBUST's Avatar
They still might get it, and that would definitely be awesome for other owners.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 03-06-2015, 10:01 PM   #3112
scarfo
Drives: gts 86
Can you run a c38 with lower boost to achieve the same results as the c30? Any issues with doing this? I'd go with the larger injectors , thinking of doing it this way so I've for scope to increase later when I want to spend more on internals.
Thoughts?
scarfo is offline   Reply With Quote
Old 03-06-2015, 10:05 PM   #3113
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
@scarfo that is exactly my plan. I'll be running the stock injectors, catless uel header with the c38.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 03-07-2015, 07:29 AM   #3114
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Thoughts?
I didn't think injectors and pump are needed for the c38. Unless running e85
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-07-2015, 11:02 AM   #3115
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
@Andreas83 @fteightysix
is it just the top fitting that would have clearance issues? cant really tell from the pics if the bottom fitting will have issues fitting too?? maybe @KraftWerks cant shed some light on this??
DAN_BRZ is offline   Reply With Quote
Old 03-07-2015, 04:57 PM   #3116
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Plenty of room for the lower fitting.
I am not sure what type of threads the ports have yet.
I am offshore at the moment, so I will look in to it when i get back home.
Andreas83 is offline   Reply With Quote
Old 03-10-2015, 01:19 AM   #3117
mit_peid
Boosted Noob
mit_peid's Avatar
Kraftwerks Supercharger Owners Thread
Anybody else have problems attaching the two 10mm bolts underneath the bumper? I just removed the bumper to install the updated (adjustable) brackets that KW provided awhile back. The new brackets move the IC further back maybe 1/4" or 3/8" but I still can't seem to get the holes to line up underneath the car. There's literally nothing holding on the bumper underneath the car right now. Name:  ImageUploadedByTapatalk1425964806.355610.jpg
Old 03-10-2015, 03:53 PM   #3118
shortcut
Drives: Frs 2013
Does anyone know if Kraftwerk tune that come with the kit is OPEN or LOCK?
shortcut is offline   Reply With Quote
Old 03-10-2015, 04:12 PM   #3119
CSG Mike
CSG Mike's Avatar
You don't really expect anyone to give away their work for free do you?
Old 03-10-2015, 04:35 PM   #3120
shortcut
Drives: Frs 2013
Not really, maybe just hoping a little bit.
Old 03-11-2015, 01:41 PM   #3121
Derka
Drives: 2015 frs
Their tune for Hondas is unlocked for adjustment.
Unfortunately for us it's locked and they refuse to unlock it for anyone. My car was running dangerously lean with their tune. They wouldn't unlock it so we could just adjust the fuel. I had to pay for another tune from someone else
Derka is offline   Reply With Quote
Old 03-12-2015, 11:46 PM   #3122
empyreal89
Drives: 14' BRZ
Hey all!
The SC is in and tuned and everything is sweet. 298 whp and 232 tq. Ptuning did a great job! The only issue now is that my car has trouble starting. It takes 2-3 times to finally get her started. The first time will just turn over and die after a few seconds. 2nd time it will kind of start and die or it will fire up. Usually it is finally started by the third time.
I changed the battery to an Optimum Yellow Top and I am still having issues. Any ideas? Any help would be greatly appreciated.
I will say she is definitely what I wanted in terms of power. I also have the black intercoller and cut out the grill for a nice clean look. Maybe a build thread in the future.
empyreal89 is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
