#15 |
Switched to the dark side
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
"COURTESY LAMP AY CLR" - 94256CA000
Part number for Subaru door step light housing. I bought them almost exactly a year ago. Time to put them in!!!! http://www.ft86club.com/forums/showt...ght=door+light @boredom.is.me Glad you didnt give up like you said you did in the thread above.
![]() WTB: FA20 longblock in Socal or shipped. |
#16 |
Custom User Title
Drives: Asphalt FR-S MT
Haha, ya I'm glad too. It's the little things that bring the smile. I was supposed to take pics of between the door jamb but forgot. If someone can remind tomorrow, that would be great.
#17 |
Nice job. I was just looking into doing this myself. Thanks for the info!
#18 |
Custom User Title
Thanks and no problem. The DIY is a bit lame so if you need anything, just ask.
Sent from my mind using telepathy.
#19 |
Drives: Scion
Thank you two posters above! You are a great help!
#20 |
Drives: 2016 Scion FR-S
#21 |
Custom User Title
Possibly, but the dome was incredibly easy as well.
#22 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
How do you take the cover of the door light off?
Instagram: Gabe.it.the.ole.college.try |
#23 |
Custom User Title
You have to take the door panel off.
two screws inside the handle plastic clip to the front pull straight out starting from one side > bottom > other side, then lift the panel
#24 |
Drives: 2018 Toyota 86
You dont need to go through the door and tap into the dome light.
just tap into the wires in the door [ame="https://www.youtube.com/watch?v=SjTjz-eEiiA"]https://www.youtube.com/watch?v=SjTjz-eEiiA[/ame] |
| The Following User Says Thank You to hexxen For This Useful Post: | EndlessAzure (11-13-2022) |
#25 |
Drives: 2014 FR-S
found a new source for the OEM connector to the Toyota (Camry) or BRZ Limited door courtesy lamps. They are $5.40 a pair in quantity of two (one pair):
https://www.aliexpress.com/item/32967395244.html |
#26 |
Drives: 2014 FR-S
Red Door Courtesy Lamps
Found the Toyota part number and JDM source for the Red Lens Door Courtesy Lamp (not the reflector): SU003-03290
lamp as well as the connector (without pigtail) or connector (including 4-inch pigtail) Last edited by tarzan_nojane; 01-15-2020 at 04:56 PM. Reason: added images |
| The Following User Says Thank You to tarzan_nojane For This Useful Post: | EndlessAzure (11-13-2022) |
#27 |
Drives: 2014 FR-S
Courtesy door lights.
#28 |
Custom User Title
This is a 10 year old post from when the car came out.
| BRZ Driver's Door Courtesy Light Won't Work | delusional | Issues | Warranty | Recalls / TSB | 31 | 05-29-2022 08:15 AM |
| Changing out the door/courtesy lights - problem | mikalem | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 02-10-2014 09:39 AM |
| Passenger Door Courtesy Light Wont Turn Off | zex | Issues | Warranty | Recalls / TSB | 12 | 10-04-2013 02:31 PM |
