Drives: GT86
Oil cooler for HKS V2 supercharger
Do I have to run the HKS oil cooler that tucks behind the light if I have the V2 supercharger kit.
I have a RHD car and the Intercooler seems to sit to the left where a lot of aftermarket intercoolers are positioned. What are you guys running with the HKS Supercharger? i wanted to buy Sard but not sure it will fit.
www.facebook.com/badluckteam
my HKS Supercharged, Varis kitted ZN6 build http://www.ft86club.com/forums/showthread.php?t=26368 |
#2 |
Drives: Scion FRS
not sure about SARD, i ended up running the HKS oil cooler.
#3 |
Touge worship
Drives: Forester STi SG9
I have the HKS V2 S/C on my BRZ so i know that setup pretty well
Yes, you HAVE to install an oil cooler, the easiest solution is the HKS oil cooler for S/C setup it works perfectly with the supercharger layout. this is what you are looking for: http://www.hks-power.co.jp/en/produc...oling/db/15613 I wouldn't go any other route, I understand it is probably not the cheapest one, but the HKS v2 kit + tunning isn't cheap either, so it is totally worth the money all together
#4 | |
Drives: 2014 Toyota GT86
How many quarts of oil did you add after you install the oil cooler? How many hp did you gain after you tuned? Thank you |
#5 | |
Touge worship
As for the power, my result can't be compared to a normal V2 setup as I have the stroker kit, Vcams , and injectors but you still can check on my build thread
#6 | |
Drives: GT86
#7 |
Touge worship
The cooler is actually exposed through the wheelwell, it requires to trim the plastic wheelwell, and put a grid for protection, no need to touch the fogs
![]() Great buy ! peace of mind with a oil cooler makes a difference
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| oil cooler for innovate supercharger | Benn0r | Forced Induction | 15 | 11-11-2015 10:09 AM |
| Perrin Crank Pulley, Pulleys, Vortech Supercharger, Chase Bays Oil Cooler, | Chase Bays | Engine, Exhaust, Bolt-Ons | 26 | 01-05-2015 05:20 PM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 02:00 AM |
| What oil cooler kits do you have installed alongside your JR supercharger? | Venator | Forced Induction | 11 | 07-14-2014 05:29 PM |
