Old 12-23-2014, 04:17 PM   #169
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I was just thinking that. To help me double check the open source tables I would make changes in ecufash, save and then open the rom in ecutek to make sure it was the same table. How long does it take for ecutek tables to make it out of beta? I feel like they leave us non professional tuning end users as a low priority. I didn't get stock B01C for months. My professional tuning friend emailed it to me. Sorry for being off topic.
Toyota John is offline   Reply With Quote
The Following User Says Thank You to Toyota John For This Useful Post:
Hadalet (06-21-2017)
Old 03-05-2015, 11:59 PM   #170
adelphi
adelphi's Avatar
Drives: Subaru BRZ
I started to use OFT few weeks ago ( running OFT Stage 2 UEL map).
My current mods : Perrin drop-in filter, Perrin inlet hose, Tomei UEL header, scorpion exhaust (OP, FP , catback exhaust) and Crawford BPB.
Fuel : Shell V-Power + octane booster.
I followed Shiv tutorial for BPB mapping changes.
I Log my car with BPB mapping changes :
http://datazap.me/u/adelphi/brz-oft-...=0&data=1-2-13
Log without BPB mapping changes :
http://datazap.me/u/adelphi/brz-oft-...&zoom=266-2018
Unfortunately I forgot to activate knock correction logging in the first log.
I am not sure which map is best for my car since I have limited knowledge on data logging.
I hope the experts in this forum can give me some feedback. Thanks.
adelphi is offline   Reply With Quote
Old 03-06-2015, 12:17 AM   #171
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
If you make the knock correction table changes, you'll be adding further timing and the ECU is already pulling -4 deg.
For aussie fuel I ended up taking the UEL 91 map and PULLING quite a bit of timing. This is after a lot of testing and trying many different things.
I understand your fuel is even worse than ours, and ours is worse than U.S. fuels.
You can get my map here.
http://www.ft86club.com/forums/showthread.php?t=83945
Old 03-06-2015, 02:50 AM   #172
adelphi
adelphi's Avatar
Drives: Subaru BRZ
Thanks Wayno for you help.
I will try your base timing map.
base on my data log, do you think I better skip BPB mapping changes ?
Old 03-08-2015, 03:50 AM   #173
Wayno
Wayno's Avatar
The changes in the first post add timing, you should be pulling timing. My map pulled timing.
Old 04-21-2015, 12:04 AM   #174
ka-t_240
Are there any Stage2 maps available for the Grimmspeed Intake? I know there are some stage1 items. Getting ready to install my OFT.
Car currently has: EL Tomei Header, Grimspeed intake, Invidia Catback, Berk Catted frontpipe. Car will be running both e85 and 91.
ka-t_240 is offline   Reply With Quote
Old 04-21-2015, 06:15 PM   #175
steve99
Drives: FT86
the grimspeed intake maf scaling is very close to stock.
OFT tunes stage2 tunes for petrol and E85 have "adjusted" maf scaling unless you want to do a bit of tuning it will be best just to leave the tunes stock and just run your grimspeed intake.
Old 04-23-2015, 12:31 AM   #176
ka-t_240
That was my thoughts, wanting to make sure to get it as best as I can from the start.
Old 08-13-2015, 03:59 PM   #177
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Is this still the procedure with the new maps, and with a D00C ECU?
tato.valverde is offline   Reply With Quote
Old 08-13-2015, 06:39 PM   #178
steve99
Drives: FT86
yes, make sure you use oft tunes and definitions.
the changes shiv proposes will only work with good fuels like usa 93 on inferior fuels you likely to get knock using those changes.
tato.valverde (08-13-2015)
Old 01-06-2016, 08:28 PM   #179
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Dude seriously, with all the help you've given us amateur romraider users, you deserve some sort of donations or some thing
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
tato.valverde (01-08-2016)
Old 01-08-2016, 09:11 AM   #180
tato.valverde
Completely agree. I don't know if it's allowed here, but back in my Android XDA days, I used to "buy beers" for people like you
Old 01-12-2016, 12:07 AM   #181
FRSBRZGT86FAN
So because the crawford bpb tunes aren't on the site anymore, when I get these in the summer I just do these modifications on romraider and check my datalogs?
Seems suprisingly simple
Old 09-18-2016, 06:59 PM   #182
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
First time editing a tune, did all the steps and uploaded to my OFT, however when I went to go select the file no popup saying the checksums have been fixed, is this of any worry?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 08:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 02:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 05:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 12:18 PM
