Sam Strano
Old 03-03-2015, 01:26 PM   #2297
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Well, it's still too cold for autocross here in Illinois. Some of us still managed to get our racing fix though!
Getting a little oppo in the middle of a frozen lake with @G_Ride!
(Photo Credit: Roberto Perez http://rpphotography11.blogspot.com/)
More pics from the event here: http://oppositelock.jalopnik.com/ral...ump-1689055517
Also picked up these for the upcoming season. Thanks again, @TRev!
Space is starting to become an issue though. :P
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 5 Users Say Thank You to Shark_Bait88 For This Useful Post:
7thgear (03-03-2015), DocWalt (03-03-2015), G_Ride (03-03-2015), qoncept (03-03-2015), TRev (03-04-2015)
Old 03-03-2015, 06:39 PM   #2298
Jawnathin
Drives: Toyobaru FRZ
Originally Posted by SeanRTR View Post
FYI:
Kevin_Kuchta@toyota.com
Hello Sean. You’ll need to sign up for the 2015 Contingency program, the details and forms are attached here, looks like you last signed up in 2013. Will need W9 information if you are eligible for (and win) any awards. In SCCA Solo, Toyota and Scion racers are awarded for Class Championships at the SOLO Nationals."
What do you guys use for 'Employer Identification Number' when filling out the W9?
Jawnathin is offline   Reply With Quote
Old 03-03-2015, 06:49 PM   #2299
JB86'd
JB86'd's Avatar
Drives: JAWS
If you don't have an EIN usually I believe your Social Security number is what you'd put.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Jawnathin (03-05-2015)
Old 03-03-2015, 06:49 PM   #2300
justint5387
Drives: 4 wheels
Your SSN
justint5387 is offline   Reply With Quote
The Following User Says Thank You to justint5387 For This Useful Post:
Old 03-03-2015, 07:41 PM   #2301
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Fun times
It was also good to meet @TRev in person.
G_Ride is offline   Reply With Quote
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
Shark_Bait88 (03-04-2015), TRev (03-04-2015)
Old 03-03-2015, 09:24 PM   #2302
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Originally Posted by qoncept View Post
I ran on Primacy's at a local event in about 40 degrees and VERY VERY wet and took 2nd raw (and pax actually) at one event. Easily the best I've ever done.
Likewise I ran the Primacy's at my second event with the car in 35 degree temps and took second in class to a two driver (helped to heat tires up) M3 on RS3s. My only other mod was camber bolts. Pretty much the entire class of 11 cars was on "better" tires. In my opinion the Primacy's are better tires than most people give them credit for.
Briankbot is offline   Reply With Quote
Old 03-03-2015, 10:44 PM   #2303
renfield90
The Stig's German cousin
My big gripe with the Primacy was the upper end of its heat range was far too low for my climate. By 2nd run they would be greasy. By 3rd run the car was so loose I thought I broke something and abandoned the run - to date the only time I've been scared in this car. Begged for a water sprayer before my 4th run and it got better but still required a lot of wheel work to keep pointed the right way.
You do learn a lot about the car on that tire, and it's probably a good tire for conditions where you won't exceed its heat range. In 40 degree weather, I'd still prefer a "real" tire plus some tire covers between runs, and then I'd use my first couple of runs strategically to work on tire temps.
Old 03-05-2015, 04:29 PM   #2304
Jawnathin
Originally Posted by justint5387 View Post
Your SSN
Thanks! If only winning was as easy as filling out the forms I would be all set!
Old 03-05-2015, 04:49 PM   #2305
Shark_Bait88
I know this has been discussed a lot, but I'm still back and forth on it.
235/45 vs. 245/40 ZII*, is the extra 1/2" of tread width worth it?
I know 245/40 is a lot of tire for a 7" wheel, but these are going to be used almost exclusively for autocross events and to drive to/from the events. They MIGHT see some other road use for club cruises this year, but I'm not 100% on that yet.
This is my first time buying a good set of performance tires for any sort of racing, so all input is appreciated. I'm trying to be fairly competitive this season, locally, and run at least one national event.
Old 03-05-2015, 04:59 PM   #2306
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
235/40 vs. 245/40 ZII*, is the extra 1/2" of tread width worth the extra weight?
it's not really the weight issue you should be worried about, but the response.
against all conventional logic the 245 seem to deliver the most absolute grip at the expense of response, this means to truly utilize their potential you're gonna have to be very trusting of the car and your inputs, because you're not gonna get quite the same feedback and generally feel like the car is being unresponsive
Old 03-05-2015, 05:01 PM   #2307
Shark_Bait88
Gotchya.
I actually made some edits to my post. I'm looking at 235/45 vs 245/40 and realized that the weight is the same, at least according to tirerack.
Old 03-05-2015, 05:10 PM   #2308
simpleisbest
Senior Citizen
Drives: Scion FR-S
Gotchya.
45 profile on Dunlop was reported to be "floppy" in the past Z2s. Hopefully the SS are stiffer. I have run the 245/40 and they work fine. 235/40 would feel the best, imo...but just can understand why they cost so much!!!
simpleisbest is offline   Reply With Quote
Old 03-05-2015, 05:19 PM   #2309
Shark_Bait88
Yeah, I was thinking about those but that $100 price jump is pretty ridiculous. Granted, I've never driven on really nice tires so anything is going to feel a lot better to me coming from Primacy HPs. haha
Old 03-05-2015, 05:25 PM   #2310
Jawnathin
For me, the biggest consideration of 245/40 and 235/40 is the change in gearing. 235 is shorter and will accelerate better but will have lower top speed than the 245/40. On a tighter course where you don't hit the rev limiter the 235 will be better. On faster courses a 245 may save you from a shift or riding the rev limiter as long.
Between the two, I would lean 235/40. Both the 235 and 245 will be pinched, so effective contact patch probably isn't all that different. With the 235s you get the benefit of shorter gears accelerating out of every corner while the 245s taller gearing only becomes a factor at the very top end. As noted earlier, the better response of a 235/40 is a nice plus too.
And this is coming from someone who just got 245/40 RS3s.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
