Drives: 2013 White-Out FRS
Feels rough shifting + 6th gear ringing.
I got this car used and it's my first manual car, so I'm not sure if it's all ManTran cars or just this car, or me.
When I shift, usually to third or fifth gear, if feels like something is in the way of the shifter itself, not lower, but where the rod of the shift stick is right under the boot. It makes sort of a crunching noise sometimes. This happens like 75% of the time I shift into third and about 30% of the time I shift into 5th. No other gears really have this sound, though it does feel rough shifting into first or second sometimes, but I read that's normal. I asked a couple of friends and they said it doesn't sound anything like grinding. Also, in 6th gear around 3.1 - 3.3 RPM, there's an extremely high pitched sound that comes from the engine bay. It goes away as I speed up but comes back/gets louder as I near that RPM range and it's ONLY in 6th gear. It gets a bit annoying since around 70MPH, it's pretty prevalent. Any idea? |
#2 |
Drives: 2015 BRZ Series Blue WRB
How many miles on the car? I bought my brz with 18 miels and I feel like my shifter got better/smoother with time.
As far as the noises when shifting gears.. Make sure you are pressing the clutch all the way |
#3 |
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Are you sure it's 6th gear doing the ringing? The noise may be coming from the differential. After I installed diff bushing inserts, I get it at 35 and 70 mph. I "solved" it by cruising a few mph higher or lower than 70. It is kinda annoying though.
#4 | |
did your noise come on at any gear?
#5 | |
It's 30k miles. I tried anywhere from pressing all the way in to pressing in softly to almost all the way to the wall, etc. It still happens randomly. |
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 09:57 PM |
| Shifting from 1st-2nd gear... | FRSpappa | Engine, Exhaust, Transmission | 13 | 05-24-2014 10:06 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 12:13 PM |
| 3rd gear inconsistent shifting | mike the snake | Issues | Warranty | Recalls / TSB | 30 | 11-22-2013 03:54 PM |
| Clicking shifting 2nd gear and R | radroach | Issues | Warranty | Recalls / TSB | 0 | 03-16-2013 11:36 AM |
