Drives: 2015 BRZ, Aozora Edition
Reverse Camera on stock 2015 head unit
Hey all,
I have a 2015 BRZ with the OEM Subaru/Fujitsu head unit. I have a few questions: 1) I was wondering if anyone has installed a reverse cam? 2) How well does it work with the head unit? 3) What camera did you buy? 4) What How To/DIY guide did you follow (if any)? Thanks in advance!
iLaw
2020 Subaru Crosstrek Sport 2015 Subaru BRZ Aozora Edition (Sold) |
#2 | |
Drives: 2015 BRZ, 2005 STI
#3 | |
Did the harness help a lot? Was it easy to install? Did you have to purchase the "Reverse Trigger Wire" that was mentioned in the AutoHarnessHouse link? Thank you.
iLaw
#4 | |
I was originally going to purchase the harness from http://ae64.com/Products.htm but I found that the link I posted earlier was cheaper and had everything I needed. I did not have to purchase the Reverse Trigger Wire and everything functions properly. |
#5 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I was planning to go with the harness + camera from Beatsonic:
http://www.ft86club.com/forums/showthread.php?t=41673 Seems the most straight forward and I know it'll work since so many have tried it. |
#6 |
The Fail Boat
Drives: CWP S.B.
really wanna do this.....but I need a beer & buddy to do it
#7 |
#8 |
Drives: '13 BRZ - SWP
My notes from when I put a backup cam in my 2013. Maybe the info can help.
| The Following 2 Users Say Thank You to Monoman For This Useful Post: | FRSBRZGT86FAN (02-13-2016), tracerit (03-07-2015) |
#9 | |
Drives: '13 SSM BRZ Limited 6MT
ae64.com has three different cables listed and being an audio noob I wasn't sure which one to get, but was advised on that one. |
#10 |
Drives: 2015 Subaru BRZ Limited DGM
That large black box on the harness (relay?), did you secure it somewhere?
#11 |
I just let it hang around in the bundle of wires lol. it's pretty tight in there so I doubt it will be moving a lot.
#12 | |
Drives: 2015 BRZ Ltd 6MT
#13 |
Drives: 2014 BRZ
The parking brake signal already goes to the head unit, you unplug that connector and plug it into this one if I'm remembering my install correctly. I recommend the harness as well since it was super simple to connect. The only thing you do with the harness is plug in your video cable from the camera and connect the 12V power to the camera. Make sure you get a camera that can tolerate the 12V.
#14 | |
Two 10-pins, so whatever you take out, you connect it back into the harness. But there's only one 16-pin connector. Speaking of the 10-pin, I'm having a nightmare with this, it's not keyed correctly to the back of the head unit. Why is this so difficult? Should've been easy, plug, and play. ![]()
| The Following User Says Thank You to BaBaFlyingSheep For This Useful Post: | SVXdc (08-26-2017) |
| Backup camera for AXCP-Q14U T10015 pioneer touchscreen head unit | infamous_s | Electronics | Audio | NAV | Infotainment | 8 | 02-21-2017 12:44 PM |
| 2015 scion head unit | speedracer45 | Audio/Visual, Electronics, Infotainment, NAV | 13 | 03-31-2015 09:27 AM |
| FS: OEM frs 2015 head unit | mynameis940 | Audio/Visual, Electronics, Infotainment, NAV | 17 | 12-04-2014 01:39 PM |
| 2015 BRZ Head Unit | Makattack | BRZ First-Gen (2012+) General Topics | 18 | 09-21-2014 03:53 AM |
| anyone interested in a bespoke unit w reverse camera? | xpicer | NY / NJ / CT / PA | 3 | 11-03-2012 07:57 AM |
