Old 02-28-2015, 06:42 PM   #15
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I have my first oil change scheduled for April. I asked if I had to bring it in even if it hasn't reached 7500 miles. They told me which ever comes first because my tires need to be rotated at first service. I trust my dealership because they did some warranty work on my other Scion car. They went out of their way to make sure the issue was taken care of. In fact I got my car back in a few hours. So far they haven't done anything shady to me just yet. I go to one of their service centers in my area.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-28-2015, 06:45 PM   #16
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by tekFRS234 View Post
I'm about to cross 1k break-in and I'm planning to do my own oil changes. At what mileage did you do your very first oil change?
I had my first oil change done at 3500. It probably wasn't necessary, but whenever I break in a new engine, I like to get that high concentration of engine material out of there fairly soon. I had my second change done at 7500, and then I've been following the maintenance schedule since then.
What oil and filter do you prefer? I've always used basic Fram filters and Casterol synth blend.
No no no no no no. Fram filters are garbage. In some applications the filter media has been known to collapse and starve an engine of oil. The only way I would put that shit on a vehicle is if I hated it and wanted it to die.
Use the Subaru oil and filters.
I'm also planning to save my first few used oil filters. A buddy said if you had engine problems you or a shop/dealership could inspect the oil filter for evidence of problems. Any thoughts?
You can cut open an oil filter and see what it has caught, but a better test is to send an oil sample off for analysis by a lab like Blackstone. It costs $25, and they'll send you the collection kit for free. The report they send back gives you all sorts of information about what metals, fuel, coolant and other contaminants are in your oil, which can tell you a lot about how your engine is wearing.
Originally Posted by tennisfreak View Post
Best way to fix a bad service center is to give them bad feedback (I know this first hand). They live and die on those surveys we fill out. If you give them a terrible survey they will move heaven and earth to make you happy.
This is definitely the truth with Subaru. I had a mediocre (not bad) experience with my dealer, and I said so. Suddenly they were calling and leaving messages offering me free services to make it right. Ended up getting the throttle body cleaned for free.
Originally Posted by dentalprodigy View Post
OP i think the first service is 7500 miles.
OP might want to check that. For the BRZ, it was 7500 for 2013 and 2014, but I believe they changed it to 6000 for 2015. I'm not sure why. I had a TBN done on the Subaru 0W20 with my regular oil analysis, and Blackstone estimated it was good for at least 11,000 miles. I think Subaru just wants to sell more oil and filters.
what surveys is everyone talking about? the one you get from the dealership to your email?
I don't know how Scion does it, but with Subaru, I usually get an automated follow-up email from the service manager, followed by a survey request from Subaru. In my case I didn't even have to give them a bad survey, because I responded to the service manager's email first, and they jumped to. The service rep actually told me their compensation is affected by those surveys.
The Following User Says Thank You to extrashaky For This Useful Post:
dentalprodigy (02-28-2015)
Old 02-28-2015, 08:06 PM   #17
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
You are correct they changed it to 6000 for 2015. I also changed mine at 3750 and then again at 7500 - thinking I'd get the break-in stuff out early. Since the recommendation changed I decided I'm doing mine every 5000, so I did it at 11000+ and will be doing it again at 15000. Then I'll stick with 5000 intervals from then on.
I'm thinking Subaru learned something with the first 2 years production of FA20s and had a technical (e.g. warranty) reason for shortening the interval. I'd rather change it early just to be sure...
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
Old 02-28-2015, 09:11 PM   #18
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by pushrod View Post
Use factory Subaru filters, and a good synthetic 0w20 oil. Follow the intervals in the manual. Mine says: @8000km, @16000, @32000, and +16 from then on out.
Make sure you get the quantity right. The dipstick doesn't lie. If you overfill it, you're gonna have to drain it.
Also, there is a non-reusable crush washer on the drain plug. Buy a bunch from the dealer.
Don't use other grades.
billwot is offline   Reply With Quote
Old 02-28-2015, 10:39 PM   #19
Racer-X
Drives: 2016 FR-S
Also, there is a non-reusable crush washer on the drain plug. Buy a bunch from the dealer..
Buy a Fumoto valve instead and make your life easier.
Racer-X is offline   Reply With Quote
Old 02-28-2015, 10:39 PM   #20
extrashaky
I seriously doubt that's necessary. As I said above, I had a TBN run on my oil when I sent it off to Blackstone for analysis. A TBN (total base number) test measures the amount of base additive remaining in the oil at the time of the test, and it's used to determine how well the oil is holding up. I had a TBN on a sample that had been run for 7500 miles, and Blackstone estimated that it could go 11,000.
Meanwhile, on 7500 mile intervals, my engine is not seeing any abnormal wear at 32K miles. My 30K oil analysis didn't give any indication that the filter is failing. If actual testing shows that the oil is holding up and the filter is holding up, I can't think of any reason for Subaru to change the service interval other than to make more money for the dealer service departments.
Yeah, they learned that they could make more money off their customers by having them come in for more oil changes. Think about it: If there were a legitimate technical reason to change the interval on the 2015 BRZ, why wouldn't they recommend it for the 2013 and 2014 as well? It's the same car.
If I had a 2015, I would do it every 6000 miles to maintain the warranty. But if Subaru says to change the oil every 6000 miles, doing it every 5000 miles is a waste of money unless you're really beating the shit out of your car.
Old 02-28-2015, 10:41 PM   #21
Racer-X
Drives: 2016 FR-S
You'd think they would change it on the FR-S as well, but it's still 7,500 miles for the 2015.
Old 02-28-2015, 10:51 PM   #22
Teseo
Drives: frs
Cheap Toyota is the answer
Old 02-28-2015, 11:21 PM   #23
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Wouldn't pay for itself until after 25 oil changes. Not worth it.
pushrod is offline   Reply With Quote
Old 02-28-2015, 11:26 PM   #24
Racer-X
Drives: 2016 FR-S
You have a low value of convenience.
Old 02-28-2015, 11:27 PM   #25
pushrod
Benched 86lb
pushrod's Avatar
Pretty much.
Old 02-28-2015, 11:43 PM   #26
M12Power
M12Power's Avatar
Drives: 2015 Firestorm Scion FR-S 6MT
I'm past the break-in period now (over 1,200 miles). I believe Scion Service Boost doesn’t cover oil change right after break-in (first scheduled maintenance is still at 7,500 miles), so I plan to do it on my own soon (with Castrol EDGE full synthetic 0W-20 and Royal Purple 10-2808 filter).
M12Power is offline   Reply With Quote
Old 03-01-2015, 12:09 AM   #27
M12Power
M12Power's Avatar
Then then cannot try the (automatic) response when something breaks and needs warranty repair "Well we cant verify the routine service was done correctly". The shady dealers will try this every time a customer has been doing their own maintenance and needs warranty work.
I believe that’s actually against the law in the US (the Magnuson-Moss Warranty Act). Toyota cannot refuse warranty work just because you take your car elsewhere for service. I believe it is also mentioned in the owners manual.
More info:
http://www.consumer.ftc.gov/articles...ne-maintenance
Old 03-01-2015, 01:19 AM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1 on OEM filter and crush washer, ~$8 or at most $9.
+1 on first oil change at 7,500 miles (6.5k if the manual was changed). The factory fill has some anti-wear ingredients, theory is that those can 'treat' the surfaces of interest in the engine for longer life. I'm also a proponent of following factory instructions on break in (under 4k rpm first 1k miles, no constant speed). There are literally thousands of people who will vehemently oppose this paragraph, do whatever gives you warm fuzzies.
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Tcoat (03-01-2015), TheVoiceOfReason (03-01-2015)
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Oil change stiboy808 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 05-27-2014 12:26 PM
When should i do an oil change? Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 112 03-15-2013 02:25 PM
When will you be doing your first oil change? pr086 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 12-10-2012 05:48 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 10:32 PM
