#197 |
Drives: Asphalt Scion FR-S
BOOM! uploaded!
#198 |
Drives: 14 Ultramarine FR-S
*Drive slowly below 3500 rpm no WOT or hard acceleration until you see STFT rise rapidly followed by LTFT and stay high, this indicates that the petrol is now out of lines and the E85 has made it through the lines and pumps, this generally takes 2 or 3 km
@steve99 or anyone who has the answer, didn't see it anywhere in the thread Per the OP when switching to E85...What kind of numbers are you going to see to confirm that the petrol is out of the lines and is safe to flash over? I'm guessing by LTFT staying high, greater than 10%? Anyone have some ballpark numbers here, getting ready to switch to E85 soon.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#199 | |
Drives: FT86
Yes normally ltft should be below 10% . so when you see it jump from its normal values probably 7% or less then you know the e85 is through and it time to flash e85 tune. same thing when you switch back to petrol from e85_ fuel trim will jump then its time to flash the petrol tune. after the flash the fuel trims should be below 10% this confirms you have the fuel and tune matched. once you have driven a few miles with ltft below 10% your good to go. also check you iam is 1 and you dont have heaps of knock. high fuel trims indicate a fuel and tune mismatch |
#200 | |
Did a pull after about 15miles of the ECU learning. Only one knock correction occurrence, AFR looks normal. LTFT as well. Still approx, ~2gal of 91 in the tank (Calculates to ~E75). http://datazap.me/u/phantobe/e85-fir...data=1-7-13-14
#201 | |
Drives: FT86
IAM =1 LT fuel trims below 5% virtually no knock, you will always get the odd -0.6 correction occasionally, just worry if it over 0.6 and is regular and not just a one off spike. commanded afr and afr following each other under load fuel trimsmight move a bit on next tank when its not diluted with a bit of petrol
#202 |
Drives: '13 SSM BRZ Limited 6MT
would you suggest a second reflash of the e85 tune on the second tank (or third) tank of e85 assuming most if not all of the regular gas has been used up?
EDIT: also, how are some people able to log knock correction, oil temp and flkc parameters? i'm using OFT HW 1.00, FW 1.32. Last edited by tracerit; 02-02-2015 at 03:36 AM. |
#203 | |
Drives: FT86
have a read of the flashing-reset-learning link below |
| The Following User Says Thank You to steve99 For This Useful Post: | tracerit (02-02-2015) |
#204 |
Drives: MR Spyder/GT86
is there a way to get my car to have less problems with cold starting on e85 first fill up it always started instantly, second fill up it almost always needs 2 cranks, now 3rd fill up it even has to crank 3times sometimes.. temperatures here have been pretty much the same.. car drives great though only the tip in knock om some occasions but really perfect 90% of the time.
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
#205 |
It's been in the 40s in the morning by me lately. I just feather the gas pedal on start up.
I also adjusted my idle parameters too so I warm up a drop faster as well.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
#206 |
Drives: Toyota GT86
The easy way is to add some regular fuel with the E85, the other way is to tweak some settings in RomRaider, somewhere is a topic about this.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#207 |
temperature here atm is around 0-7Celcius or 32-46F
it's only on real cold starts but just sounds so unhealthy sometimes
GT86
#208 |
@elBarto yep. That's what I did. But that was like almost 2 months ago and I apparently wiped my history
now idr where it is
#209 | |
(Jerrycans)
GT86
#210 |
is there any damage from having a bad start?
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
