Old 02-26-2015, 03:15 PM   #757
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by PandaSPUR View Post
Is there any way for me to check if my harness has this issue before I bother trying to install it? (I was going to install on sunday).
Can I just look at which color wires are going into which pins?
If you want to remove the tape, you can check- each wire should go directly from one pin to the other, i.e., pin 4 to pin4, pin 5 to pin 5, etc.
Also, for anyone else reading too:
If the problem is that the DRL is not coming on at all, please make sure the DRL is supposed to be coming on to begin with! You must have the vehicle started and running. Autos must be in D, manual must have ebrake down. You might need a friend to look and see. Please be safe when testing.
John C.
Diode Dynamics
The Following 7 Users Say Thank You to Diode Dynamics For This Useful Post:
4honor (02-26-2015), Elkton86er (02-26-2015), FLYFISHR (02-26-2015), Husker BRZ (02-26-2015), Jmonty (02-26-2015), PandaSPUR (02-26-2015), Porcupint (02-26-2015)
Old 02-26-2015, 04:45 PM   #758
Porcupint
Drives: 13 GBS BRZ
Was going to ask about this myself. I'll double check mine when I get home tonight before I install it.
@PandaSPUR I'm not repining this one..
Porcupint is offline   Reply With Quote
Old 02-26-2015, 05:30 PM   #759
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
So I received the module yesterday, installed it following the instruction on DD's youtube video.... one of the module's plug's under clip broke off (only slight pressure), was still able to plug everything in though... but car battery dead ...couldn't start the car, it's been sitting for only a week...
well, long story short, was able to jump start it...with car started and running and hand brake down, the boomerang and DRL don't light up. They only light up when I put my car in gear...
DD, is mine faulty also?
jflBRZ is offline   Reply With Quote
Old 02-26-2015, 05:53 PM   #760
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
This part of it bolded is normal because you need to be in any other gear BUT the "P" gear for it to come on. Not sure about the boomerang though. But since the DRL isn't lighting up I assume it's connected to the boomerang with the new module.
Try setting it to "Auto" mode on your headlight stalk and see if that turns them both on with parking brake down and in Neutral, with the car running.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
Diode Dynamics (02-26-2015)
Old 02-26-2015, 06:00 PM   #761
Diode Dynamics
No, this module is fused and powered through other ignition-controlled components. It does not draw directly from battery. It did not make any impact on your battery in any way. Sounds like it's time for a new battery!
Your vehicle needs to be in gear for the DRL to come on, so everything is working properly.
Correct, this module does not change when and how the DRL comes on.
You do need to have the car started, with the car in drive or neutral if it's an automatic, or handbrake down on a manual. Make sure you're on a flat surface when checking, or a have a friend look. Thanks!
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Annahra (02-26-2015)
Old 02-26-2015, 06:03 PM   #762
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
Teeheehee...
Annahra is offline   Reply With Quote
Old 02-26-2015, 06:07 PM   #763
jflBRZ
jflBRZ's Avatar
Drives: WRB BRZ 6AT
yeah, it didn't light up in Neutral either...
Old 02-26-2015, 06:09 PM   #764
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I have no idea how the BRZs with auto transmission work, but BEFORE the mod, did the DRLs light up while you were in neutral?
Sounds like theyre working fine if they light up when you're in gear.
Lmao, its all good. Hopefully there's no problem anyways.
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
Diode Dynamics (02-26-2015), Porcupint (02-26-2015)
Old 02-26-2015, 06:16 PM   #765
qoncept
qoncept's Avatar
@jflBRZ
My gar is in the garage for the winter but I'm PRETTY sure the DRLs don't come on with a manual transmission unless it's actually in gear. I vaguely remember trying to take a look once and I couldn't.
qoncept is offline   Reply With Quote
Old 02-26-2015, 06:21 PM   #766
DaJo
FT86Club Vancouver
DaJo's Avatar
Weird...
2000 MR-S 5MT
2010-2012
jflBRZ (02-26-2015)
Old 02-26-2015, 06:26 PM   #767
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
Just got tracking info minutes ago for my 2/15 order. Things are moving!
nocturne1 is offline   Reply With Quote
Old 02-26-2015, 06:26 PM   #768
Porcupint
Drives: 13 GBS BRZ
Originally Posted by qoncept View Post
@jflBRZ
DRL comes on as soon as you drop the parking brake on the manual transmission.
The Following User Says Thank You to Porcupint For This Useful Post:
qoncept (02-26-2015)
Old 02-26-2015, 06:42 PM   #769
Diode Dynamics
We have a manual. Car must be running and ebrake dropped fully for DRL to come on.
I believe for automatic, car must be running and in Drive.
Again, this mod does not change when the DRL works, just what lights come on as the DRL. Thanks!
John C.
Diode Dynamics
Old 02-26-2015, 06:42 PM   #770
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
@KelvinBRZ @PandaSPUR
Here is a pic of my 6k headlights: (I know it isn't the best picture but it gives you an idea, I'll add a night time one tonight.
Name:  pictures from phone 011.png
Name:  pictures from phone 002.png
Size:  387.3 KBName:  pictures from phone 005.png
I will say the light isn't as effective as 4300k, that being said I think I will be trying the 5k lights in the near future to try and get more actual use out of the light. I don't dislike the 6k, but I think the 5k gives you basically the same aesthetic look with more functional use.
While I was out there I checked my module and tried my lights on auto, in neutral, and the car running and.... voila
Name:  pictures from phone 019.png
Husker BRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to Husker BRZ For This Useful Post:
Choco (02-27-2015), DaJo (02-26-2015), Diode Dynamics (02-26-2015), KelvinBRZ (02-26-2015)
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 04:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 03:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
