Old 02-14-2015, 08:14 PM   #2353
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Thanks @steve99 - much appreciated.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-22-2015, 08:42 PM   #2354
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
If you getting that cel code or car just shutting down, your car has a hardware problem, nothing to do with tune.
flash back your stock rom with oft ( just to be sure you will have no issues at dealer), drive till cel code or problem re appears (reflash resets ecu and cel codes) then take to dealer, possible fuel pump issue , unless your running out of fuel .
car will go into limp home mode with that cel reduced power and 4500 rpm limit.
I know this is off topic with the OFT discussion. So I drove my car to the dealership and they "fixed" my P0193 code. They said my oil level was low that's why my cam positioning wasn't reading my car properly. Anyways, 2 weeks after that "fix" my car is getting my P0193 problem. Its on stock tune and my rpm keeps jumping up and down between 1k-2k rpm constantly. I'm here waiting outside for a tow truck. Been 1.5 hours now and Dealerships are closed on Sundays. Gotta call in late tomorrow just to bring it to the dealership. Any advice?
ShibaYuki is offline   Reply With Quote
Old 02-22-2015, 10:26 PM   #2355
steve99
Drives: FT86
Something not right here
1.P0193 is fuel rail pressure problem nothing to do with oil or cam position actuators or sensors
http://www.datsc.com/tabid/122/OBD-E...u/Default.aspx
Either you or dealer have got code wrong.
2. If you oil level was that low to be causing the cam position problem then you have other serious issues like why was oil that low that oil pressure was dropping. You either burning or leaking oil. If oil pressure and level was that low for any apreciable period its likely caused other damage.
Hopefully the dealer is full of BS and the actual problem is a fuel pressure issue.
Old 02-22-2015, 11:30 PM   #2356
JB86'd
JB86'd's Avatar
Drives: JAWS
yes look like still a problem possible exhaust leak, if the nuts came rearly loose its likely you will have to replace gaskets again as they only crush to shape once.
Does this also apply to gaskets that are composed of only multiple layers of thin metal?
JB86'd is offline   Reply With Quote
Old 02-23-2015, 01:24 AM   #2357
steve99
Drives: FT86
most gaskets , crush washers are single use, you might get away with it but seldom worth the risk for such cheap components.
Old 02-23-2015, 07:52 AM   #2358
ShibaYuki
I know for sure the first time my oil level wasn't low enough for my car to stop working.
I told them how I asked around and googled what could cause the P0193 and they didn't even look at the fuel pump. They were so set that it was my oil level. Lol.
The Following User Says Thank You to ShibaYuki For This Useful Post:
steve99 (02-23-2015)
Old 02-27-2015, 01:47 AM   #2359
Kostamojen
Quick question, do the included Stage 2 tunes have the reduced idle rpm fix?
Old 02-27-2015, 03:24 AM   #2360
steve99
Drives: FT86
all OFT tune's idle is 750rpm stock idle is 650rpm from memory
Old 02-27-2015, 03:31 AM   #2361
Kostamojen
I mean the ignition idle, when you first turn on the car and it idles high to warm the cats.
Old 02-27-2015, 03:34 AM   #2362
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You'll have to do that yourself.
It's pretty simple though.
Old 02-27-2015, 04:09 AM   #2363
steve99
Drives: FT86
They did reduce cold start idle to 1400 rpm from 1700 rpm,
but you can also adjust the post start ignition timing from -15 to -4 but on usa rom you will also need to disable P050B cold start ignition performance.
see Tune Tweaks link below.
Old 02-27-2015, 04:11 AM   #2364
Kostamojen
Good info, thanks for the quick reply
Old 02-27-2015, 04:29 PM   #2365
winsometang
Drives: Scion F-RS 2013 Asphalt MT
Noob here. I just flashed stage 2 uel 91 on my frs. Running Ofh, nameless fo/op and zeta catback with injen intake. I was wondering what kind of range I should be seeing for short term and long term trims if it is running properly? Sorry if this has been answered, but I'm kinda lost and would greatly appreciate knowing how to read the diagnostics
winsometang is offline   Reply With Quote
Old 02-27-2015, 05:10 PM   #2366
phrosty
Fuel trims should generally be less than 10%.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
winsometang (03-03-2015)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
