#141 | |
Looking at events closer to you, I might do Buttonwillow on March 7 with Speedventures but I realize that might be too late for you. |
| The Following User Says Thank You to kster1 For This Useful Post: | mokinbird87 (01-13-2015) |
#142 | |
| The Following User Says Thank You to CSG David For This Useful Post: | mokinbird87 (01-13-2015) |
#143 | |
BOXER FR
Drives: WRB BRZ Limited
March 7th would work.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#144 |
Drives: gt86...among others
Hey guys,
Shocks are off now and looking to have them serviced. No re-valving just a winter tune-up. We got quotes here, but I'm curious what this service costs in the states. I'll be visiting in a few weeks and considering bringing them back if there's a big price difference. Thanks in advance
racing gods live deep in corners
#145 |
Just curious, has anyone tried using 7" springs? (instead of the OEM 8") For example, these Swift 7" springs in something like a 7kg/9kg (F/R) spring rate:
http://www.swiftsprings.net/products...prings-65.html The rears will need to be revalved but I'm just wondering about ride height and suspension travel with these stiffer 7" springs. With 8" springs, the car can't be lowered much as the spring rate gets up to 7.5kg and up. |
#146 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | kster1 (02-20-2015) |
#147 |
Drives: 2004 Toyota RAV-4 5M
Did you guys use helper springs to help lower the car? I'm running 7 inch Hyperco springs all around right now and have the rear ride height as low as it can go. Not sure if it is low enough to get the camber I want in the rear so I'm considering going to the helper springs depending on the results of the alignment.
#148 |
Drives: 2005 Toyota Camry
For me, I'm going to get the camber I want in the rear via RLCA.
As far as I'm concerned, there's 3 ways to get camber in the rear with Ohlins: 1) shorter springs 2) adjustable lower control arm (Whiteline or similar) or camber arm (SPC or similar) 3) adjustable lower control arm that also lowers the rear (Stance, etc) With the rear at max lowering, I have around 1.5 degrees static negative camber. -alex |
#149 | |
#150 |
I'm running 650lbs/in in the front and 750 in the rear. The front's can be lowered quite a ways, but the rear can only be dropped about 15mm. I think the way I have it set up now it is pretty close to the default height of the Ohlins, but I'm not quite sure, waiting on seeing alignment results as my judgement of the right ride height in the rear will be based on how much camber I get.
| The Following User Says Thank You to ja1217 For This Useful Post: | kster1 (02-21-2015) |
#151 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | kster1 (02-21-2015) |
#152 | |
Also, what was the ride height adjustability range (roughly) when on these springs? |
#153 |
Drives: 2008 Mazda Miata GT
Btw, I thought I should note ( as a lurker ) - I have a 2008 Miata that has had Ohlin DFV's since 6k on the odometer.
Currently at 113k. Never been rebuilt, but the spherical bearings rattle like mad now. They still work fantastic and the car is driven hard. For those who are interested, when I spoke to Ohlin's in the spring for just an OEM rebuild, it was $700, + shipping. |
#154 |
Drives: Exige S 240
I've had the Öhlins on for less than 10k km and I am starting to have some serious rattling coming from the rear left. I thought something wasn't tightened back properly when the shocks were mounted...
But @stormhammer, you got me googling around and it seems it is not an uncommon issue. http://legacygt.com/forums/showthrea...rs-91738.html? http://forum.miata.net/vb/showthread.php?t=301280 http://www.audiworld.com/forums/s4-r...-long-1589479/ Anyone experiencing that on their twin and found a way to fix it?
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 06:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 01:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 05:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 04:27 PM |
