Old 01-12-2015, 09:56 PM   #141
kster1
kster1's Avatar
Originally Posted by mokinbird87 View Post
i think the Ohlins set up is more comfortable than stock, so I can`t imagine the stiffer setting all of a sudden becoming so uncomfortable. maybe if i make it up to Laguna Seca I can hitch a ride in your car @kster1 ?
I'm not registered for any upcoming events at Laguna. Which day were you referring to?
Looking at events closer to you, I might do Buttonwillow on March 7 with Speedventures but I realize that might be too late for you.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
mokinbird87 (01-13-2015)
Old 01-12-2015, 09:58 PM   #142
CSG David
CSG David's Avatar
I`m looking to purchase a set and just have them revalve with the higher spring rate in the rear even before i install them on my car.
one question. does it feel just as comfortable as they were with the 343lb springs, or is it now at that uncomfortable/track smooth surface only setting? i would assume with proper valving, it would still be very comfortable.
Laguna Seca would not be a good place to test suspension comfort...lol. You can go 30kg/mm springs and still feel the suspension is smooth.
The Following User Says Thank You to CSG David For This Useful Post:
Old 01-13-2015, 05:31 AM   #143
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
it`ll be a while for me March 7th would work.
mokinbird87 is offline   Reply With Quote
Old 01-19-2015, 10:06 AM   #144
Doozer
Doozer's Avatar
Drives: gt86...among others
Hey guys,
Shocks are off now and looking to have them serviced. No re-valving just a winter tune-up.
We got quotes here, but I'm curious what this service costs in the states. I'll be visiting in a few weeks and considering bringing them back if there's a big price difference.
Thanks in advance
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 02-20-2015, 05:26 PM   #145
kster1
kster1's Avatar
Just curious, has anyone tried using 7" springs? (instead of the OEM 8") For example, these Swift 7" springs in something like a 7kg/9kg (F/R) spring rate:
http://www.swiftsprings.net/products...prings-65.html
The rears will need to be revalved but I'm just wondering about ride height and suspension travel with these stiffer 7" springs. With 8" springs, the car can't be lowered much as the spring rate gets up to 7.5kg and up.
Old 02-20-2015, 05:49 PM   #146
Racecomp Engineering
We ran 450 lbs/in 7 inch Hyperco springs all around without issue. Loved the Ohlins with that set-up.
- Andy
kster1 (02-20-2015)
Old 02-20-2015, 06:11 PM   #147
ja1217
Drives: 2004 Toyota RAV-4 5M
- Andy
Did you guys use helper springs to help lower the car? I'm running 7 inch Hyperco springs all around right now and have the rear ride height as low as it can go. Not sure if it is low enough to get the camber I want in the rear so I'm considering going to the helper springs depending on the results of the alignment.
ja1217 is offline   Reply With Quote
Old 02-20-2015, 06:22 PM   #148
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
For me, I'm going to get the camber I want in the rear via RLCA.
As far as I'm concerned, there's 3 ways to get camber in the rear with Ohlins:
1) shorter springs
2) adjustable lower control arm (Whiteline or similar) or camber arm (SPC or similar)
3) adjustable lower control arm that also lowers the rear (Stance, etc)
With the rear at max lowering, I have around 1.5 degrees static negative camber.
-alex
Old 02-20-2015, 06:34 PM   #149
kster1
kster1's Avatar
With the 7" springs and Ohlins, what spring rate are you running front and rear? What's the ride height like? Can you get to one inch lower than stock height? My main concern is not lowering the car too much.
Old 02-21-2015, 02:56 AM   #150
ja1217
I'm running 650lbs/in in the front and 750 in the rear. The front's can be lowered quite a ways, but the rear can only be dropped about 15mm. I think the way I have it set up now it is pretty close to the default height of the Ohlins, but I'm not quite sure, waiting on seeing alignment results as my judgement of the right ride height in the rear will be based on how much camber I get.
The Following User Says Thank You to ja1217 For This Useful Post:
kster1 (02-21-2015)
Old 02-21-2015, 02:20 PM   #151
Nope. Check our Facebook...the later pictures of our BRZ are on Ohlins. Its not super low but we get an inch or so.
- Andy
kster1 (02-21-2015)
Old 02-21-2015, 06:43 PM   #152
kster1
kster1's Avatar
- Andy
Do you mind linking the picture? I went through your FB page but I wasn't sure which was the picture with 450 lbs/in 7" springs.
Also, what was the ride height adjustability range (roughly) when on these springs?
Old 06-18-2015, 03:19 AM   #153
stormhammer
Drives: 2008 Mazda Miata GT
Btw, I thought I should note ( as a lurker ) - I have a 2008 Miata that has had Ohlin DFV's since 6k on the odometer.
Currently at 113k. Never been rebuilt, but the spherical bearings rattle like mad now. They still work fantastic and the car is driven hard.
For those who are interested, when I spoke to Ohlin's in the spring for just an OEM rebuild, it was $700, + shipping.
stormhammer is offline   Reply With Quote
Old 06-19-2015, 03:24 AM   #154
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I've had the Öhlins on for less than 10k km and I am starting to have some serious rattling coming from the rear left. I thought something wasn't tightened back properly when the shocks were mounted...
But @stormhammer, you got me googling around and it seems it is not an uncommon issue.
http://legacygt.com/forums/showthrea...rs-91738.html?
http://forum.miata.net/vb/showthread.php?t=301280
http://www.audiworld.com/forums/s4-r...-long-1589479/
Anyone experiencing that on their twin and found a way to fix it?
Guillaume is offline   Reply With Quote
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 06:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 01:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 05:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 04:27 PM
