#169 | |
Drives: Soon to be BRZ
#170 |
Bannéd
Drives: 2013 DGM BRZ
Thanks man! I'm rocking BBS CH-R 18x8 + 38. with PSS 225's all around. Didn't break out the tape as I am max low in the front and about 12mm higher in the back. Now that it's broken in a bit though I'm going to raise it by around 10mm because I'm getting a tiny bit of rubbing on the front tires if I hit a bump while cornering... I also think I'll put 10-20mm adapters in the rear because I love the small amount of front poke I have but the huge rear tuck drives my eyes crazy. haha
The fascinating thing about my signature is that by the time you realize that it is of no importance, it will also be too late to stop reading it. Good luck getting those five seconds of your life back. |
#171 | |
#172 |
Bannéd
I want to say 50mm or 2in. Somewhere right around that mark haha, feel free to correct me if I'm wrong... I was a little distracted by the Superbowl when I installed them.
#173 | |
#174 |
For me, Im doing this when I get my ride:
18x9.5 Rota Grid (5x100/e38/73) ST Suspension Coils SPC Performance Adjustable LCA And wheels: 255.35.18 All around Thats all I would need, I thought I would need camber bolts in the front, but they are adjustable just like the KW's so Im getting the LCA for the rears. What do you think? Pretty sick huh |
#175 |
Bannéd
Thanks man, My roommate and I just worked through the commercials and halftime. Granted it took all day to do it that way, but we got it done... Driving it to the alignment shop the next day it was clunking something fierce in the rear, and I was sure I had messed something up. Turns out I just needed and extra turn or two on the top mount. So all in all no problems.
#176 |
What do you think about what I'm going to put on my ride? Its in the post above yours lol
#177 | |
Drives: 2013 Firestorm FRS
Here was my setup on ST Coils, dropped 1.25" on 18x9 +40 with 245/40/18. Not quite the same as yours-but close, and it should look damn sick. Also, I do NOT have adjustable rear arms (yet) and just from the drop I'm at -2.5 on the rear for camber...I've been like that for 15k, and have had very very little camber wear-its been pretty darn even. Im at 0 toe, btw.
#178 | |
Bannéd
And for the rear depending on what you are going for, you might not even need the LCA. The natural camber from drop is pretty tame and a competent alignment shop can get you back in spec. That said, it wouldn't hurt and might make future modifications less of a hassle.
#179 | |
SPC Performance Cam bolts Would that work for the front? Thats all I would need right? Edit: From what I heard, I can run that without needed any camber bolts in the front |
#180 | |
Bannéd
#181 | |
Bannéd
#182 |
With just using the adjustment slot on the ST coil for the fronts, I was able to get about -1.5...
but as @Special_K said, this car is great since you can add-on as you go. |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
| RS*R Sports-i Coilover system installed (pics) | R0ME0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 139 | 02-05-2015 03:38 PM |
| Pics of you!? Pics of your life?! | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 66 | 12-25-2012 04:49 AM |
| More stock pics. My Raven FR-S with graffitti background. Sick Pics | Hardrock4445 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-11-2012 11:29 PM |
