Old 02-19-2015, 05:05 PM   #953
M16MB02
Hi,
I recently purchased a C38 kit with the high boost kit. Who could I talk to about getting set up with a flex fuel kit and forced induction e-tune for my specific setup on e85?
Thank you!
M16MB02 is offline   Reply With Quote
The Following User Says Thank You to M16MB02 For This Useful Post:
Old 02-19-2015, 08:40 PM   #954
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by M16MB02 View Post
Hi,
Thank you!
Feel free to send me a PM
Sincerely,
Old 02-20-2015, 04:31 AM   #955
tf1573
Drives: 2013 86
hi.
I'm planning more power up by supercharger.
So,I want to change the Direct Injector for Countermeasure to Knocking.
Do ECUTEK have Parameter of direct Injector??
tf1573 is offline   Reply With Quote
Old 02-20-2015, 06:51 AM   #956
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by tf1573 View Post
hi.
Yes, ecutek tuners have full control over the direct injectors.
Old 02-20-2015, 07:26 AM   #957
Calum
That Guy
Originally Posted by sales@delicioustuning.com View Post
Stage 2, with E85/Flex Fuel if you have it available! I wouldn't do a muffler delete unless you desire the sound. Overpipe and front pipe gains are negligible gains compared to header, and you do still want a little bit of backpressure in the system for low end torque retention. If street car, keep stock front pipe for low end. If race car, straight pipe and you'll lose low end but gain a small bit on top.
Sincerely,
Zach
IIRC I've seen you post about back pressure before. Maybe its just me, but someone in your business shouldn't post info that's not accurate.
http://www.gomog.com/allmorgan/exhaustbackpressure.html
Old 02-20-2015, 12:57 PM   #958
DeliciousTuning
Calum,
We hold the opinion that if you're staying NA, you want to keep a small amount of *restriction* in the system so as not to lose low end. Perhaps back pressure was not the proper term to use, however the end result stays the same with suggesting the consumer keep some sort of muffler. We've actually seen power losses on the low end from deleting the muffler, and that is where the suggestion comes from.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Calum (02-20-2015)
Old 02-22-2015, 02:49 PM   #959
raytrix
Drives: Series 10 FR-S
@sales@delicioustuning.com change of plans. I'm doing a Greddy T518z kit with 725cc injectors and the New Greddy Profec Boost controller. I can't wait for the GTX series of turbo kits to come out from Greddy. How much PSI do you guys recommend I can go while staying safe even if it overboosts seeing that I'm upgrading the injectors to 725cc? 10psi/12psi/14psi? What possibly whp/tq numbers I'll be theoretically seeing for those psi? I'll be running 93Oct pump gas. The turbo kit will be installed by Touge Factory. Supporting mods include Motive over pipe, Motive front pipe, Greddy Comfort Sport V2 GTS exhaust.
raytrix is offline   Reply With Quote
The Following User Says Thank You to raytrix For This Useful Post:
texasbound972 (02-22-2015)
Old 02-22-2015, 05:58 PM   #960
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I would highly suggest building your motor before considering going FI. Just my .02
texasbound972 is offline   Reply With Quote
Old 02-22-2015, 06:12 PM   #961
raytrix
Then by that logic, every bolt on kit out there should have a disclaimer saying do not install the kit unless you have a built motor.
Old 02-22-2015, 06:36 PM   #962
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
I don't think it's texasbound972 logic here talking rather than his actual experience. I would consider his advice.
kasikuusi is offline   Reply With Quote
The Following User Says Thank You to kasikuusi For This Useful Post:
Old 02-22-2015, 11:24 PM   #963
texasbound972
USMC
Even NA motors blow up. If that was the disclaimer nobody would sell any kind of FI kits. The truth would scare everyone away.
Old 02-22-2015, 11:26 PM   #964
texasbound972
USMC
Somebody please, what the fuck is this and do I need to get on the dyno asap? Overboost prevented by Ecutek??: [ame]http://youtu.be/yRzLkJ5W0LY[/ame]
Old 02-23-2015, 12:16 AM   #965
s2d4
s2d4's Avatar
I would highly suggest learning to provide logs, or learn to use gauges to monitor before considering FI, just my 0.02.
Old 02-23-2015, 12:21 AM   #966
texasbound972
USMC
Well I do know how to log and have done so in the past for the idle issue. I don't log all the time and this doesn't happen that often. I do have gauges and monitor them as I drive. So if you don't have any helpful input I'd suggest shutting the fuck up.
The Following User Says Thank You to texasbound972 For This Useful Post:
weederr33 (02-24-2015)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
