Old 02-18-2015, 05:01 AM   #1
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
JDM Cool Oil Filters
So while browsing on ft86speedfactory I came upon some oil filters from well known JDM companies (Cusco, Blitz, Greddy and HKS). I know the HKS and Cusco have neodymium magnets to help pull metal out of the oil.
So what's the verdict on these 4?
Please no "just use stock" etc etc etc. Not asking those opinions.
0351USMC is offline   Reply With Quote
Old 02-18-2015, 05:05 AM   #2
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
I use HKS, because it's pink. Looks good in my engine bay.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 02-18-2015, 05:13 AM   #3
0351USMC
0351USMC's Avatar
OK, 2 blue, one white and one pink. Let's factor the cool color factor in!!!
Old 02-18-2015, 05:15 AM   #4
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
My tuner recommended the HKS for his excellent history with them...great filtering and the magnet is a definite bonus.
killboy is offline   Reply With Quote
Old 02-20-2015, 08:20 AM   #5
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I can't speak to those but if you are looking for an upgraded filter the Amsoil Extended life oil filters have served us well over the years. Personally I would look at filters from companies that specialize in filters, rather than companies that re-market other filters. Take a look at the companies you listed above and what their core business is.
-mike
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
Koa (02-21-2015), sb (02-22-2015)
Old 02-20-2015, 10:33 AM   #6
was385
Drives: MT WRB BRZ Limited, 2007 911s
Asking about oil filters is like asking about oil. You're going to get a lot of opinions based on little more than "well I ran this type and my car didn't blow up so it's good" or "I ran this type and my car had issues so it's bad".
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
killboy (02-21-2015)
Old 02-20-2015, 11:33 AM   #7
0351USMC
0351USMC's Avatar
Well I ended up buying the HKS so after I change it out I'll do a cutaway and comparison.
The Following 3 Users Say Thank You to 0351USMC For This Useful Post:
chubky (02-21-2015), killboy (02-21-2015), Koa (02-21-2015)
Old 02-21-2015, 01:28 AM   #8
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I would not use aftermarket oil filter under the warranty period.
Muaddib is offline   Reply With Quote
Old 02-21-2015, 02:28 PM   #9
0351USMC
0351USMC's Avatar
Any particular reason?
Old 02-21-2015, 03:56 PM   #10
Koa
isn't it obvious? In case of catastrophic engine failure and you need to get it towed, dealership/corp can pull ANY sort of bs card if you use aftermarket safety parts. Yes, the oil filter is a safety part.
No, the HKS probably isn't worse than stock. But it's just red tape one needs to be cognisant of. Personally I would just keep a stock toyota filter on hand to screw in before the truck arrives if you're really worried about your engine. If it's stock don't worry about it
Old 02-21-2015, 06:39 PM   #11
0351USMC
0351USMC's Avatar
"Should something go wrong, the warranty provider will need to determine the cause of the problem. The Federal Trade Commission says, “The manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.” That means if the dealer can prove (the burden is on the dealer) the problem was caused by the wrong viscosity or a poor quality oil filter, your warranty can be denied. Warranty protection would still be in effect for other parts of the cars"
Let them try to prove an HKS filter under performed and caused damage
Old 02-21-2015, 07:38 PM   #12
Muaddib
Mentat
Muaddib's Avatar
You can try to act tough but if you have a blown motor. You would be at the mercy of your dealership. I work for Toyota and i know what to avoid if i know it could be avoided.
The Following User Says Thank You to Muaddib For This Useful Post:
Koa (02-22-2015)
Old 02-22-2015, 01:16 PM   #13
Koa
lol just trying to give you real advice.
doesn't matter whether or not you think it's a better product.
Old 02-22-2015, 04:48 PM   #14
BRZnut
Drives: BRZ DGM Limited
The do every thing they can to pass the costs to the owners....There is someone on the board who had rod knock and needed a new engine and the dealer denied his warrantee claim because he changed his own oil. (supposedly had receipts too!)
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 50 11-02-2015 11:03 AM
oil filters MonoRaven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 06-16-2015 09:01 AM
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 144 01-20-2015 12:37 PM
GTA - air filters BRZ vs FRS chenshuo CANADA 0 03-10-2014 12:39 AM
Air filters Ryan86 AFRICA 14 12-31-2012 05:35 AM
