#71 | |
Drives: 2013 Scion FR-S Ultramarine
That said, if you're trying to strip weight off the car, I see no season why you wouldn't jump on this for less than $400. It would be silly to do a lightweight flywheel, upgraded clutch, and not do the driveshaft since you're down there anyway.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
#72 | |
Some people love to throw money at things, others like to optimize their cost/benefit. It's no right or wrong answer, just one that 'works' given the goals and environment the system is in. "Down there anyway" the driveshaft is actually pretty far away from the clutch, FW (other side of tranny ) and literally takes 10 minutes to take out..
#73 | |
I agree that the money is better spent on other items, but once you have those done, why not pick up the last bits of easy hanging fruit? It's a cheap and pretty easy mod, and every little bit helps! Edit: is there a bbk that runs in the 800 range? Ones I've seen seem to all be 1200+, and at that price the money does better going into my superchager nest egg. If there is a quality bbk that cheap, might have to look into it!
#74 | |
The aluminum driveshafts are super cool, don't get me wrong.. would love to have one, even if it tricks my butt dyno and gives me that much more peace of mind that my severely underpowered engine won't ever twist it (jokes, stu, jokes, don't call that out!) but they are awesome. Especially if you want to go big, big power, it makes a lot of sense |
#75 | |
Kuruma Otaku
You've already said that you acknowledge there is a small benefit of reducing drive shaft mass. What you're doing now is coming off as a total fucking tool with your smarter than us attitude. With the only purpose of supporting your personal OPINION that it's not a terribly efficient mod from dollars to results. You don't get to make that decision for others. Basically, you're a d!ck.
Because titanium. |
#76 | |
Drives: 2013 GBS BRZ Limited
You DO know how stupid that makes YOU sound right? Or is it when I point out complete bullshit pseudo-science that others try to make sound like fact? You know what I GET sick of? Anytime someone mentions that they are an engineer, the pricks come out of the woodwork to piss all over them. So YES If you MUST know, I AM smarter than your average bear. AND I slept at a Holiday Inn express last night. And I am sorry if my grasp of physics is a threat to you. Piss off |
#77 | |
Kuruma Otaku
Tool.
Because titanium. |
#78 | |
I get the annoyance at going on butt dyno vs hard science and numbers. You remember that Top Gear where the Stig sets a laptime in a twingo and Clarkson says "Stig is here, I thought France made the stig violent" Every time I see a post about lightweight driveline components and I see the term rotational inertia I think "Rotational inertia...I thought that made Stu violent" Don't take anything on here too seriously, overall I think we can all appreciate solid reliable info backed up by numbers at the end of the day.
#79 | |
It's not an opinion if he's stating facts from a hard science. |
#80 | |
Kuruma Otaku
What facts? That Jimmy won't see as much a benefit from it as he thinks? Same as the NA vs Turbo argument. Not his business to bitch about how someone wants to spend mod money.
Because titanium. |
#81 | |
Drives: Raven Black
removing 15lbs from drive shaft vs removing 15lbs from spare tire Obviously removing 15lbs of rotational mass in the drive train will net a better performance increase, because either way, you are reducing 15lbs, but one option reduces rotational mass and helps put more power to the ground. I'll go for the drive shaft option every single day. I think you need to go back to school and learn some general laws of physics. |
#82 | |
Drives: '13 Ultramarine FR-S M/T
He is however pushing he opinion. "IMO the effect of the drive shaft is negligible." He also is implying that in his opinion lighter drive shafts are a waste of money for a "street car". This is his opinion based on what he believes to be negligible gains vs money spent. Again his opinion. on another note everyone i know that has gone with an aluminum drive shaft has already installed lighter wheels (and wider), crank pulley and flywheel. the drive shaft is just part of their effort to reduce the cars overall rotational mass. my opinion is to buy a light weight drive shaft if you are intending to lighten up more of the car. if its just a daily that you have fun with don't bother with a drive shaft and go straight for a flywheel and wheels.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
#83 | |
Sorry bud but you can't argue with physics. Love that you ignore everything in the forum and focus on what you can wrap your mind around
#84 |
He's just trying to enlighten us as to what the physics (HARD SCIENCE) says about this, and to help people not waste their money on non-performance gains when that $400 could do MILES better in other arenas. But hey, it's their money at the end of the day, you're right about that
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-04-2020 11:18 PM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 09:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 09:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
