Old 02-15-2015, 06:21 PM   #15
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by MRE View Post
The performance of aerodynamics works alongside with the other modifications done to a car. My wing has a large coefficient for creating downforce. This wing is functional at all speeds, on cars of all power/mod index.
The market is full of smaller wings. I am creating a wing that can output more noticeable downforce, the size of my wing is the by-product of that goal.
I'm fairly familiar with aero...what kind of drag penalty comes along with this wing? L/D?
The Following User Says Thank You to Gunman For This Useful Post:
fika84 (02-16-2015)
Old 02-15-2015, 07:04 PM   #16
MRE
Drives: scion
The wing alone, with its experimental endplate, at 120kph, makes 201.2lb lift and 49.6lb drag. I have yet to run simulations across different speeds to produce a reliable graph depicting L/D ratio.
MRE is offline   Reply With Quote
The Following User Says Thank You to MRE For This Useful Post:
Gunman (02-15-2015)
Old 02-15-2015, 07:36 PM   #17
Createddeleted
Drives: 2014 BRZ - 2004 GLI
And what does this do to the vehicles calculated CD?
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
fika84 (02-16-2015)
Old 02-15-2015, 07:40 PM   #18
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Might be useful IF it confirms with the regulations of an actual competition series. However, for the general public, it's probably not worth it.
Looks like the only real "difficulty" is getting the mounting bracket made. nothing a plasma cutter and a sheet of aluminum can't solve though. The wing itself, you can get carbon or aluminum pre-fabbed straight wings anywhere. End plates are as easy as mounting brackets.
If you make it, post pics. But I highly doubt there is a market for this...
Perhaps you can look of some regulations of actual race series, then market this to the teams there?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-15-2015, 07:48 PM   #19
MRE
Drives: scion
I have not performed simulations of the wing on the car yet. I don't have the proper 3D model to conduct the experimentation yet.
The wing's made for racing series and used in racing series are good enough as I see them. The market is saturated with them. I am creating something with an even higher performance coefficient, unbound by any regulation. My main target audience are people who are into track day and HPDE events and seek to modify their cars to be ever faster. I chose to tackle the aerodynamics sector first, because I see greater improvements can be made on current products.
Old 02-15-2015, 07:49 PM   #20
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
This car can't get going fast enough to necessitate a wing.
campy is offline   Reply With Quote
Old 02-15-2015, 08:05 PM   #21
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
How much will it unload the front end? Have you considered what effect your wing will have on the front?
Originally Posted by paulca View Post
Has anyone mentioned Hitler yet?
Hot Lava is offline   Reply With Quote
Old 02-15-2015, 08:08 PM   #22
MRE
Drives: scion
That statement is not true. Aerodynamics affects all speeds. Going beyond an arbitrary speed does not create a binary condition for when a wing functions or not. The efficiency of my wing allows much more noticeable effect in increased turning speeds and reduced braking distance, compared to the competing wings in the market. The biggest factor dictating the downforce goals I've set is the mass of the car. The wing, being shaped and sized the way it is, is a by-product of the performance goals I've set.
Tgionet (02-16-2015)
Old 02-15-2015, 08:50 PM   #23
Tromatic
So your claims, so far, are meaningless?
The Following 4 Users Say Thank You to Tromatic For This Useful Post:
Caspeed (02-16-2015), fika84 (02-16-2015), Tcoat (02-15-2015), Wise (02-15-2015)
Old 02-15-2015, 08:52 PM   #24
100% guaranteed to have people look at you and point!
8R6 (02-17-2015), Clipdat (02-16-2015)
Old 02-15-2015, 08:55 PM   #25
RockRoll
Drives: 2013 Civic Si
Money talks...Bullshit walks...
RockRoll is offline   Reply With Quote
Old 02-15-2015, 09:33 PM   #26
MRE
Drives: scion
Yes I have. Because of the wing placement, there wouldn't be enhanced lift anywhere, and yields only net downforce across length of the car.
Old 02-15-2015, 09:36 PM   #27
MRE
Drives: scion
Not meaningless at all. I've done experimenting on the wing on its own, and the wing on another vehicle. Because of that and the results I got from it, I can confidently say my wing will improve perform better than competitors—even without the more direct evidence of live-testing and CFD with the FRS. The flow dynamics and interaction of the wing from that test can be translated and extrapolated as a starting ground for the mount and wing place you see here now.
Old 02-15-2015, 09:44 PM   #28
Gunman
Any car can benefit from a wing, etc., top speed really has no bearing on if it will help cornering speeds or not.
Rear Wing White64Goat Cosmetic Modification (Interior/Exterior/Lighting) 1 10-05-2014 11:52 AM
Sti rear wing? steveoexige Cosmetic Modification (Interior/Exterior/Lighting) 1 05-16-2014 11:30 AM
What rear wing is this? switchlanez Cosmetic Modification (Interior/Exterior/Lighting) 9 02-08-2014 08:17 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
