Old 02-14-2015, 06:53 PM   #15
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by mynameis940 View Post
Alright so it's still happening and I bought a multimeter and when the car is off it's drawing .68 amps. I pulled the dcc fuse and it dropped down to .2, so then I unplugged my ca-fi dashlinq head unit inside the car and put the dcc back in and it was at .2. Why is this head unit drawing so much power when its off? I haven't seen anyone have a problem with this
The Ca-Fi stays in a standby mode that is user-configurable. I have mine set to 2 days, no problem. You can opt to turn that off completely and you'll just have to cold boot it each time you start the car, until you get a better battery that is.
Old 02-14-2015, 06:54 PM   #16
mynameis940
mynameis940's Avatar
Drives: WRX
Mines set on cold boot, I don't understand why it's drawing so much or is a .68 amp draw normal on an off car?
mynameis940 is offline   Reply With Quote
Old 02-14-2015, 07:01 PM   #17
Foobar
SLO NO MO
Foobar's Avatar
Spec is <70mA
Old 02-14-2015, 07:03 PM   #18
mynameis940
Drives: WRX
Spec is <70mA
My multimeter is on dc 10a. So .68 is 680 miliamps isn't it?
Old 02-14-2015, 07:08 PM   #19
Foobar
SLO NO MO
Foobar's Avatar
Unless my understanding is wrong, yes .68 amps would be 680 milliamps. Maybe the 10a means you have to step it down by a factor of 10, so it's really 68 mA? Not an electrics guy, sorry.
Just checked another thread - Subaru apparently told another owner that there really isn't a published spec for our car, but most of these cars should be < 70 mA. They tested another car on the dealer lot and it was 150 mA, Subaru said that was a normal condition at this time. So is it <70 or 150? Guess they don't really know either. Here's the link to that post: http://www.ft86club.com/forums/showp...2&postcount=38
But yeah, 680 seems high.
Old 02-14-2015, 08:16 PM   #20
quark
I had a similar issue, mine was due to the trunk not closiing properly and the light staying on.
I replaced the trunk light and dome light to a low power LED's
During the issue I measured the power consumption to get a better understanding on what was beeing consumed
Off , 12.70 V, 600mA
30 sec, 12.74 V, 140mA
60 sec, 12.79 V, 14mA
90 sec, 12.79 V, 13mA
So you need to wait for 60 seconds to get the true power consumption.
quark is offline   Reply With Quote
Old 02-18-2015, 10:15 AM   #21
arvidj
Drives: '93 MR2 Turbo
You did not say what year.
I have a 2015 with about 4500 miles on it. I had not driven it for about 5 days. Went out to go to work and the battery was dead. Not even enough energy to light up the clock.
Had Toyota Road Side Assistance so off to the dealer it went. They got it started with a jump and then measured the battery and the charging system. It seemed to be fine, with the battery showing 12.41 volts when the car was off. But the tech was not satisfied and brought out an old "carbon pile" [as he put it] tester and the battery failed miserably, dropping to 8.3 volts under load.
In short, it "looked like" it was good until it was asked to do some heavy lifting at which point it failed. They replace the battery under warranty.
He also measured the 'no key in the ignition' current flow. It would bounce between 22ma and 26ma. The bounce was the security LED turning on and off.
As a side note, when I got the car back they had reset the clock to the correct time .
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 02-22-2015, 11:06 AM   #22
mynameis940
Drives: WRX
Arvid
Mines a 2015 as well, I ended up buying the battery someone suggested earlier in this thread and it's working wonders.
Old 03-01-2015, 12:52 AM   #23
Razz
Razz's Avatar
Drives: Fast
I think Panasonic batteries are super cheap.
Never had a good one.
Razz is offline   Reply With Quote
Is there a DIY/FAQ on re-dying the interior stitching? Michael Blue Cosmetic Modification (Interior/Exterior/Lighting) 29 08-29-2014 01:34 PM
Aftermarket Header Dying Cricket Noise Squido3J Engine, Exhaust, Transmission 6 03-31-2014 07:07 AM
Dying to hear this!!! sweetfrs Engine, Exhaust, Transmission 8 09-19-2013 10:17 PM
I'm dying over here! coastertrav Scion FR-S / Toyota 86 GT86 General Forum 18 04-15-2013 07:41 PM
Forum is Dying #87 Scion FR-S / Toyota 86 GT86 General Forum 49 06-09-2010 12:36 AM
