Old 02-13-2015, 08:22 AM   #127
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by moto-mike View Post
Almost 3k so far. MPG varies, but about 25 on winter pump gas with snow tires, warm up cycles etc.... Maybe 1 less than the 210 kit. If you are easy on the throttle I'm sure you'll get more and we can tweak the open loop stuff to get more MPG for those that want it, but that isn't the goal of this car. I'm sure if you popped it in CC at 70 mph you could see 30 when not on snow tires with winter fuel.
We always include all the variations at no charge. I build the base maps with everything already included, then it is just a matter of checkboxes for the final order.
How are you getting 25 mpg with the bigger blower?? I can barely get 20 mpg on my 210 with the current delicious tune
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline
Old 02-13-2015, 08:44 AM   #128
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Can't answer that question since that isn't our tune. We see mid to high 20s on the 210, very high teens on e85.
Xero-Limit is offline
Old 02-13-2015, 11:21 AM   #129
CK_Bladesmith
Drives: Raven FR-S
10-4. I may be giving you a call soon.
Old 02-13-2015, 05:50 PM   #130
brianhj
Drives: 2017 Camaro 1SS
I thought I was the only one. Been driving more conservatively (Zzzzzzzzz) and I hit 21 mpg with same set up.
brianhj is offline
Old 02-13-2015, 06:51 PM   #131
sam69
Drives: GT 86
Jeeeezzz don't know what you guys are doing but I get as low as 6.4 Lt / 100 km on a long run and average about 8.5
I googled the conversion to US gallons and 6.5 works out at 36 mpg and 8.5 is still over 27 mpg
sam69 is offline
Old 02-13-2015, 07:09 PM   #132
Calum
That Guy
Drives: 2013 asphalt FRS MT
Which tune?
Calum is offline
Old 02-13-2015, 08:44 PM   #133
alexisfire02
Drives: 2013 Pearl White FRS
I have to wonder why all the numbers you have on your tests are so different than what I saw at the 3 different tuners that I had look at my car for the last 18 months with a 335.
For example, we saw about 16-17 pounds of boost with a 72mm pulley...
Nothing about your kit/numbers seems to be close to what my kit actually did.
alexisfire02 is offline
Old 02-13-2015, 08:52 PM   #134
djliquidsteele
Drives: Scion FR-S
If I remember correctly, They are purposely tuning it in a way to not reach maximum power but hit power in a particular rpm range to make it more trackable.
djliquidsteele is offline
The Following User Says Thank You to djliquidsteele For This Useful Post:
Xero-Limit (02-15-2015)
Old 02-13-2015, 10:54 PM   #135
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You might be over compensating on the fuel injection in the higher RPMs to stave off knock. Thats the only thing I can think of.
cdrazic93 is offline
Old 02-14-2015, 03:29 AM   #136
sam69
Drives: GT 86
Originally Posted by Calum View Post
Which tune?
MRT from Sydney but it isn't smooth low in the rev range which is a real pain .
sam69 is offline
Old 02-15-2015, 06:11 PM   #137
smudge
Drives: Supercharged GT86
Any issues in the 3k miles you've covered so far?
smudge is offline
Old 02-15-2015, 06:33 PM   #138
Xero-Limit
Xero-Limit's Avatar
Just burning up what's left of the snow tires. Waiting for the thaw so we can put back on the coilovers and 18x9.5 rpf1s and smoke some real rubber and break some axles. We'll run this in SM auto-x at the very least this season. Got what I think may be a lousy tank of gas the last time (noticed it was going a bit slower). Took out 2 degrees of timing and it was all back to normal.
Not sure what your tuners were doing. Not that they aren't qualified per se...but you really need to live with this kit for a long time to get a handle on how the twin screw reacts. Gotta keep in mind that boost is directly related to what kind of cam timing you run. With dual VVT this means we have a TON of flexibility considering there's about 50 degrees of sweep with both intake/exhaust. That means we can time things in such a way that the effective boost and combustion pressures are less for a given amount of air.
Old 02-15-2015, 06:45 PM   #139
smudge
Be interesting to see how far you get before axles/drive shafts get broken!
What's been/going to be done about additional cooling? I assume intake temps are much higher than that of the 210 kit?
I'm getting around 29mpg (UK) average on my 210 kit, good to see the 335 isn't too much different unless you're thrashing it
smudge is offline
Old 02-15-2015, 07:11 PM   #140
sam69
Drives: GT 86
Intake temps should be lower with the 335 .
sam69 is offline
The Following User Says Thank You to sam69 For This Useful Post:
Chad86 (02-15-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
