Old 02-11-2015, 09:02 AM   #15
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
IMO Mcgard SplineDrive is the best daily drive lug nuts.
The are reliable, and with spinning seat as @CSG David mentioned.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 02-11-2015, 04:01 PM   #16
CSG David
CSG David's Avatar
With sufficient heat and whatever particles/moisture stuffing into the cracks of the two surfaces, the spinning seat can seize and the lug nut becomes one unit. Not exactly the most ideal situation, but it is the common thing amongst our community. Just a different scene since I've heard others having absolute success with the Mcgard and the Project Kics setups. Hard to say, but personally, I opt for the safer option.
Old 02-13-2015, 07:22 PM   #17
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Got it off pretty easily actually. I took off the other lug nuts and then wiggled the wheel around a bit and the seat actually just fell off the lug after separating into two pieces.
After that, I simply took a pair of vice grips and clamped it to the piece still stuck on the wheel stud and twisted it off.
No damage to the wheel stud whatsoever except on the very top where the piece didn't want to come off. A tap and die set solved that.
In a place where are no harsh elements/weather(Southern California), and you're not taking the wheels off frequently, these would probably do very well. However here in Oklahoma where it changes from winter to summer nearly every day, and I take the wheels on and off a bunch at drift events and such, these simply aren't durable enough to last. Furthermore, thanks to the weather, every single one had seized, so the bottom no longer spins on any lug nuts.
Shitty that these are $300 lugs and they only lasted about a year but at least getting everything done and taken care of was painless.
Old 02-13-2015, 07:30 PM   #18
2much
I wanna go fast
Drives: 2013 FR-S 6MT
are the stock nuts problematic under tracking conditions?
is the only reason to not use stock nuts for [minimal] weight savings and aesthetics?
I just bought new wheels and changing the lug nuts did not even occur to me.
2much is offline   Reply With Quote
Old 02-13-2015, 08:01 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I estimate that between track events and me being vain, I swap wheels around once every 14 days.
All of my R40 lug issues were created by me, not by lug design.
YMMV.
-alex
Old 02-13-2015, 08:50 PM   #20
TylerLieberman
Drives: '24 GR86
YMMV.
-alex
Same here, though I also swap multiple times a day when at the track swapping between spare tires and stuff. Mix this with just awful weather and I believe I have the reasoning for my particular case.
They're awesome lugs; I iust wish that for the money they cost, they wouldn't be prone to failure like that.
I switched back to steel muteki nuts which I've used over the years and have never run into a single issue. I'll just stick with these from now on I suppose.
Project Kics R40 Lugnuts amazingbrz Northern California 5 11-27-2014 01:20 PM
FS project kics 40 lug nuts! jgonx213 Wheels and Tires 1 10-16-2014 06:06 PM
Project kics conversion spacers Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 3 08-25-2014 12:17 AM
Project Kics Lug Nuts BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-18-2014 02:19 PM
Project Kics R40 racing lug nuts HighbreadEH3 Wheels and Tires 0 09-03-2013 01:49 PM
